I was having the issue related to long time waiting to shutdown or restart the system associated with the message “Watchdog did not stop” so looking to the forum for help I found some threads with indication to a fix the issue as indicated below:
sudo nano /etc/modprobe.d/blacklist.conf
# Disable intel mei (including mei_watchdog).
blacklist intel_pmc_bxt
blacklist iTCO_vendor_support
# Do not load the 'iTCO_wdt' watchdog module on boot.
blacklist iTCO_wdt
Besides the message “Watchdog did not stop” didn’t’ show anymore, the long time remains the same, so I decided to revert the setting deleting the file backlist.conf, but when my system boot it still call the file witch suggest I didn’t made it in the right way. See attached image.
What is the right way to remove the blacklist.conf and the changes it made on the system?
Remove watchdog.conf or whatever you named the conf file. Also remove the nowatchdog kernel boot parameter from GRUB, assuming you are using GRUB. Then sudo update-grub.
none of proposed actions were able to remove the message during the boot.
bellow my current grub file
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=b136d668-4460-4cf7-9211-93b9a5283ab3 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
If you still have a file called blacklist.conf, can you post the contents of that file? It seems like you have a bad line in there somewhere. Deleting the bad line should, hopefully, fix the issue.
Then regenerate the intramfs: sudo mkinitcpio -P
I can’t precise tell what order I made that fixed the issue, but look likes order meter here.
Thanks for all suggestions.
I back with blacklist.conf and removed comments line (the ones started with #), rebooted the system.
Deleted the backlist.conf again and run sudo mkinitcpio -P.
