Warthunder broken again
Running Steam on manjarolinux 21.1.2 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/bogi/.local/share/Steam/ubuntu12_32/steam
[2021-09-13 19:58:40] Startup - updater built Sep 10 2021 01:00:36
Installing breakpad exception handler for appid(steam)/version(1631237534)
[2021-09-13 19:58:40] Loading cached metrics from disk (/home/bogi/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-13 19:58:40] Using the following download hosts for Public, Realm steamglobal
[2021-09-13 19:58:40] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-13 19:58:40] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-13 19:58:40] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-09-13 19:58:40] Verifying installation...
[2021-09-13 19:58:40] Verification complete
Loaded SDL version 2.0.17-6744061
/usr/share/themes/Breath/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:44818): Gtk-WARNING **: 19:58:41.142: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breath/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Runtime for steamwebhelper: defaulting to /home/bogi/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
+ exec /home/bogi/.local/share/Steam/ubuntu12_64/steam-runtime-heavy.sh --unpack-dir=/home/bogi/.local/share/Steam/ubuntu12_64 --runtime=steam-runtime-heavy -- ./steamwebhelper -lang=en_US -cachedir=/home/bogi/.local/share/Steam/config/htmlcache -steampid=44818 -buildid=1631237534 -steamid=0 -cachedir=/home/bogi/.local/share/Steam/config/htmlcache -steamuniverse=Public -realm=Global -clientui=/home/bogi/.local/share/Steam/clientui --enable-blink-features=ResizeObserver,Worklet,AudioWorklet --enable-media-stream --enable-smooth-scrolling --password-store=basic --log-file=/home/bogi/.local/share/Steam/logs/cef_log.txt --disable-quick-menu
CAppInfoCacheReadFromDiskThread took 55 milliseconds to initialize
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
(steam:44818): Gtk-WARNING **: 19:58:43.185: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 301 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 4ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/bogi/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 6.63 seconds
BuildCompleteAppOverviewChange: 109
RegisterForAppOverview 1: 2ms
RegisterForAppOverview 2: 2ms
[236390]Non-Steam Controller Configs Enabled: 1
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to UpdatingAppInfo with ""
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 236390, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 236390, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 236390: 0
/bin/sh\0-c\0env LD_PRELOAD="" /home/bogi/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=236390 -- '/home/bogi/.local/share/Steam/steamapps/common/War Thunder/launcher' \0
Game update: AppID 236390 "", ProcID 45349, IP 0.0.0.0:0
ERROR: ld.so: object '/home/bogi/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
(launcher:45350): Gtk-WARNING **: 19:59:19.280: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
Game update: AppID 236390 "", ProcID 45350, IP 0.0.0.0:0
libpng warning: Interlace handling should be turned on when using png_read_image
Starting app 236390
RecordSteamInterfaceCreation (PID 45350): SteamUser017 / User
>>> Adding process 45349 for game ID 236390
RecordSteamInterfaceCreation (PID 45350): SteamFriends014 / Friends
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
RecordSteamInterfaceCreation (PID 45350): SteamUtils006 / Utils
RecordSteamInterfaceCreation (PID 45350): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 45350): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 45350): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 45350): STEAMAPPS_INTERFACE_VERSION006 / Apps
RecordSteamInterfaceCreation (PID 45350): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 45350): STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
RecordSteamInterfaceCreation (PID 45350): STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
RecordSteamInterfaceCreation (PID 45350): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 45350): STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
RecordSteamInterfaceCreation (PID 45350): STEAMCONTROLLER_INTERFACE_VERSION / Controller
RecordSteamInterfaceCreation (PID 45350): STEAMUGC_INTERFACE_VERSION001 / UGC
Setting breakpad minidump AppID = 236390
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198123160795 [API loaded no]
GameAction [AppID 236390, ActionID 1] : LaunchApp changed task to Completed with ""
Game update: AppID 236390 "", ProcID 45562, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 45562): SteamUser017 / User
RecordSteamInterfaceCreation (PID 45562): SteamFriends014 / Friends
RecordSteamInterfaceCreation (PID 45562): SteamUtils006 / Utils
RecordSteamInterfaceCreation (PID 45562): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 45562): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 45562): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 45562): STEAMAPPS_INTERFACE_VERSION006 / Apps
RecordSteamInterfaceCreation (PID 45562): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 45562): STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
RecordSteamInterfaceCreation (PID 45562): STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
RecordSteamInterfaceCreation (PID 45562): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 45562): STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
RecordSteamInterfaceCreation (PID 45562): STEAMCONTROLLER_INTERFACE_VERSION / Controller
RecordSteamInterfaceCreation (PID 45562): STEAMUGC_INTERFACE_VERSION001 / UGC
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
Fossilize INFO: Overriding serialization path: "/home/bogi/.local/share/Steam/steamapps/shadercache/236390/fozpipelinesv5/steamapprun_pipeline_cache".
Game removed: AppID 236390 "", ProcID 45562
Game 236390 created interface STEAMAPPS_INTERFACE_VERSION006 / Apps
Game 236390 created interface STEAMCONTROLLER_INTERFACE_VERSION / Controller
Game 236390 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 236390 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION012 / RemoteStorage
Game 236390 created interface STEAMSCREENSHOTS_INTERFACE_VERSION002 / Screenshots
Game 236390 created interface STEAMUGC_INTERFACE_VERSION001 / UGC
Game 236390 created interface STEAMUNIFIEDMESSAGES_INTERFACE_VERSION001 / UnifiedMessages
Game 236390 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 236390 created interface SteamFriends014 / Friends
Game 236390 created interface SteamMatchMaking009 / Matchmaking
Game 236390 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 236390 created interface SteamNetworking005 / Networking
Game 236390 created interface SteamUser017 / User
Game 236390 created interface SteamUtils006 / Utils
Game 236390 method call count for IClientUserStats::RequestCurrentStats : 1
Game 236390 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 236390 method call count for IClientAppManager::IsAppDlcInstalled : 62
Game 236390 method call count for IClientApps::BGetDLCDataByIndex : 62
Game 236390 method call count for IClientApps::GetDLCCount : 64
Game 236390 method call count for IClientUtils::RecordSteamInterfaceCreation : 15
Game 236390 method call count for IClientUtils::GetAppID : 19
Game 236390 method call count for IClientFriends::GetPersonaName : 1
Game 236390 method call count for IClientUser::CancelAuthTicket : 1
Game 236390 method call count for IClientUser::GetAuthSessionTicket : 1
Game 236390 method call count for IClientUser::GetSteamID : 3
Game 236390 method call count for IClientUser::BLoggedOn : 1
Uploaded AppInterfaceStats to Steam
Exiting app 236390
No cached sticky mapping in ActivateActionSet.Installing breakpad exception handler for appid(steam)/version(1631237534)
src/tier1/fileio.cpp (5015) : Assertion Failed: BIsOpen()
crash_20210913200026_40.dmp[45765]: Uploading dump (out-of-process)
/tmp/dumps/crash_20210913200026_40.dmp
src/clientdll/shadercachemanager/shadercacheimplfossilize.cpp (240) : Assertion Failed: IO error trying to write disk cache!
crash_20210913200026_40.dmp[45765]: Finished uploading minidump (out-of-process): success = yes
crash_20210913200026_40.dmp[45765]: response: CrashID=bp-5da292d2-1df0-4a73-b016-6e48e2210913
crash_20210913200026_40.dmp[45765]: file ''/tmp/dumps/crash_20210913200026_40.dmp'', upload yes: ''CrashID=bp-5da292d2-1df0-4a73-b016-6e48e2210913''
Fossilize INFO: Setting autogroup scheduling.
I tried to run the game myself and I have no problems at all, but I am running it with a nvidia card and not amd. It seems that there are issues with amd cards at the that game.
Seems you did not run it, with the suggested fix:
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.x86_64.json %command%
Add that to your startup options of this game.
Or run it with steam:
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.i686.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json steam
also add there AMD_VULKAN_ICD=RADV to switch from the default AMDVLK vulkan driver. Sometimes it has better performence and work better, but it depends on the game.
If that does not work, then consider to file a bug report here: https://forum.warthunder.com/index.php?/forum/920-linux/
this one worked.
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.i686.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json AMD_VULKAN_ICD=RADV steam
and the second one also worked, with better results ( no hiccups and freezes during the game )
Over many years I only had this happen once, and the reason was because steam was outdated compared to some libraries on the latest update in manjaro, so setting steam to beta solved it.
unfortunately the solution only worked for one day. steam would crash the moment warthunder tries to authenticate through it. sometimes i am able to use the web based authentication to play the game, but steam is effectively dead, both flatpack and native
Well, then report it to the devs of war thunder on the suggested forum. I would rather say it is a problem of the game…
