Hello,
its my first time that i try to run a non-Native Linux game under Manjaro KDE and what can i say… nothing is working
I have no idea, why this game won’t load, ProtonDB showed me Platinum for Warpips.
https://www.protondb.com/app/1291010
I have activated Steam Play, i had choosed under Game properties between Proton Experimental/Proton 7.0 and Proton 6.3 but no success, i clicked on play, the Steambutton changed to starting/running for 5sec but nothing comes up, no loading screen or anything, only my HD LED doing some work but nothing really happening.
I have installed Warpips on a NTFS Partition (Samsung 860 Pro 1TB) SSD, that i normaly use for gaming under Windows, i created there a new Steam Library (just for Linux)… could be there a problem related to NTFS and Proton gaming?
Or is it maybe my nvidia 2080Ti that need some tweaks, somewhere else?
I only had a single native Linux game (Sky Force Anniversary) under Steam running and its installed in my Home folder and working flawless.
Please help me out.
inxi --admin --verbosity=7 --filter --no-host --width:
Summary
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
security=apparmor resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
RAM: total: 15.58 GiB used: 4.26 GiB (27.3%)
RAM Report:
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94)
stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4500 high: 4501 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4500 2: 4500 3: 4501
4: 4500 5: 4500 6: 4501 7: 4500 8: 4500 bogomips: 64026
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
s-diag: 612mm (24.08")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.57 TiB used: 468.41 GiB (10.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 26.1 GiB (30.1%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%)
used: 61.7 MiB (32.8%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
used: 15.98 GiB (4.9%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 23.27 GiB (37.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
ID-5: /run/media/koboldx/games raw-size: 585.94 GiB
size: 585.94 GiB (100.00%) used: 403 GiB (68.8%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: games uuid: 165692E31D7ADAF2
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 1.8 MiB (0.1%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: a44dd3c4-f5f1-4587-8934-6f7413d28d4f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
uuid: AE7EDC0696B158FD
ID-2: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: System-reserviert uuid: B2286A122869D5BF
ID-3: /dev/sda2 maj-min: 8:2 size: 293.16 GiB fs: ntfs label: win10
uuid: 5E60C09860C077F3
ID-4: /dev/sda3 maj-min: 8:3 size: 515 MiB fs: ntfs label: N/A
uuid: 20E8D914E8D8E954
ID-5: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
label: N/A uuid: N/A
ID-6: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-9:2 info: Endor AG ClubSportPedal type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0eb7:183b class-ID: 0300
Device-2: 1-13:3 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-5:2 info: Samsung Portable SSD T5 type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 04e8:61f5 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 257 Uptime: 1h 1m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1388 pacman: 1383 lib: 412 flatpak: 5 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
