# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(usbhid xhci_hcd)
MODULES=(crc32c)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No RAID, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect modconf block filesystems fsck)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev modconf block filesystems fsck)
## This setup assembles a mdadm array with an encrypted root file system.
## Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
# HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
## This setup loads an lvm2 volume group.
# HOOKS=(base udev modconf block lvm2 filesystems fsck)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr and fsck hooks.
HOOKS=(base udev autodetect kms modconf block keyboard keymap consolefont encrypt plymouth filesystems)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
I got the exact same message from pacman (as @oneno describres) when updating the february bundle package with sudo pacman -Syu:
“WARNING: The ‘plymouth-encrypt’ and ‘sd-plymouth’ hooks are depreciated. You should replace them with ‘encrypt’ and ‘plymouth’ hooks in your ‘mkinitcpio.conf’. The ‘lxdm-plymouth.service’, ‘lightdm-plymouth.service’ and ‘sddm-plymouth.service’ systemd service files are no longer recommended. You should enable ‘lxdm.service’, ‘lightdm.service’ or ‘sddm.service’ instead.”
Hours after my update a depriciated plymouth package became available as per philm revised accouncment notes. After installing this package with sudo pacman -Syuu all was good again.
@oneno
As always, context is important and from the context here it is quite clear what the message meant - of which you apparently only read the last sentence.
The meaning was:
systemd services with names like: lxdm-plymouth.service, lightdm-plymouth.service and sddm-plymouth.service
should be replaced with: 'lxdm.service', 'lightdm.service' or 'sddm.service'
stop/disable the former and start/enable the other instead - if you have the older variant still
… although I never saw anything else than the latter being used and recommended
these have always been the “default”
