I always update my system using pacman on terminal, I only use pamac to check and update flatpaks that I use.
Today when I opened pamac it shows a warning 2 or 3 times saying “failed to synchronize database” but it still shows the packages that need updates! I updated my system today in terminal with sucess but when I remember “well let me check the flatpaks” that warning appeared on pamac!
I did sudo pacman-mirrors -f5 && sudo pacman -Syyu and all went fine but the warning still appears…
Please post the output of the following using preformatted text:
pamac update
Here the output:
https://aur.manjaro.org/packages-meta-ext-v1.json.gz: Unacceptable TLS certificate
Failed to synchronize AUR database
Nothing to do.
Have patience. After a while it will work again.
So I don’t need to do anything just wait and eventually will work correctly?
Normally yes. I don’t know if it’s overloaded or has connection problems. Every now and then I get the same error and after a while it works without problems.
To avoid those issues with AUR database - disable the check for AUR changes.
I suggest using a script and a user service to do that check instead
Today pamac is fine, thank you for the clarification since it was the first time this happened to me!
