(150/322) upgrading gdm [######################] 100%
warning: directory permissions differ on /var/lib/gdm/.local/
filesystem: 755 package: 700
I got the above message during the last stable update. A message just like that was mentioned in the stable updates known issues section but for dhcpcd and not gdm.
So I just would like to know should I change the permissions on this folder to 700 and more generally should warnings like these be followed?
Thank you for the information!
