Wallpaper issue
INTRO
Hi, iam new to linux,
had some time using pop and ubuntu, decided to try out manjaro,
been using it for couple of weeks,
i really like it, thanks to the devs,
ISSUE
happened to extend my display but the wallpaper that i had set only shows up in the primary one,
the stock-wallpaper shows up in the extended display,
made a quick topic search in this forum can’t find any related topics,
tried restarting the display manager, not working.
Here are my specs,
OS: Manjaro Linux x86_64
Host: 81FS Lenovo E41-25
Kernel: 5.10.79-1-MANJARO
Uptime: 32 mins
Packages: 1254 (pacman)
Shell: bash 5.1.8
Resolution: 1366x768, 4096x2160
DE: Plasma 5.23.3
WM: KWin
Theme: Breath2 2021 Dark [Plasma], Breeze [GTK2/3]
Icons: breeze-dark [Plasma], breeze-dark Terminal: yakuake
CPU: AMD PRO A4-4350B R4 2C+3G (2) @ 2.500GHz
GPU: AMD ATI Radeon R2/R3/R4/R5 Graphics
Memory: 2365MiB / 3816MiB
Hello :smiley:
You need right click on the monitor you want to change the wallpaper on and then configure desktop and wallpaper then choose the one.
I believe it is better to do a google search because this is a desktop environment (kde ) related question .
A quick google search got me this
https://www.reddit.com/r/kde/comments/aeu4eu/how_to_set_a_wallpaper_for_secondary_screen/
Thank you very much for the solution,
i was expecting it to change by default,
but the solution is more straight than that
seems like i should use my common sense or google more often lol.
Thanks again
