pekod
November 20, 2022, 11:10am
1
Hi!
Here is my config:
OS: Manjaro Linux x86_64
Host: B550I AORUS PRO AX
Kernel: 5.15.78-1-MANJARO
Uptime: 18 mins
Packages: 1420 (pacman)
Shell: zsh 5.9
Resolution: 2560x1440
DE: GNOME 43.1
WM: Mutter
WM Theme: Adwaita
Theme: Adw [GTK2/3]
Icons: Papirus-Dark [GTK2/3]
Terminal: tmux
CPU: AMD Ryzen 7 3800X (16) @ 3.900GHz
GPU: AMD ATI Radeon RX 6600/6600 XT/6600M
Memory: 2672MiB / 32000Mi
When display is blanked for more than 10 minutes it’s not waking up, after hintin any key.
Other word no reactions, cpu working, but display is blacked (no even message “no signal”). Just turned off screen. Force button reset only helps. Suspend parametr is set for 1 hour when idle.
Btw same thing happends in Windows 11.
How can i fix this issue?
Zesko
November 20, 2022, 12:05pm
2
Did you try Kernel 6.0.9?
It fixed the issue of waking up after suspend or hibernation for AMD GPU.
But:
That seems no coincidence, the problem would probably be your hardware: Radeon 6600XT or the motherboard or ram?
Check: journalctl -p 3 -b -1
after reboot (Please use REISUB ) if the display does not wake up.
pekod
November 21, 2022, 6:38pm
3
Hi!
Tried to check the log, as i see something wrong with bluetooth. But the gpu seems to be ok.
ноя 20 22:00:07 aorusproax kernel: kvm: disabled by bios
ноя 20 22:00:08 aorusproax kernel: kvm: disabled by bios
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init vcp >
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init mcp >
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init bap >
ноя 20 22:00:09 aorusproax kernel: usb 3-3.1: 3:3: cannot set freq 24000 to ep 0x82
ноя 20 22:00:09 aorusproax kernel: kvm: disabled by bios
ноя 20 22:00:09 aorusproax kernel: sd 6:0:0:0: [sda] No Caching mode page found
ноя 20 22:00:09 aorusproax kernel: sd 6:0:0:0: [sda] Assuming drive cache: write through
ноя 20 22:00:10 aorusproax kernel: Bluetooth: hci0: command 0xfc01 tx timeout
ноя 20 22:00:18 aorusproax kernel: Bluetooth: hci0: FW download error recovery failed (-11>
ноя 20 22:00:18 aorusproax kernel: Bluetooth: hci0: sending frame failed (-19)
ноя 20 22:00:20 aorusproax kernel: Bluetooth: hci0: command 0xfc1e tx timeout
ноя 20 22:00:20 aorusproax kernel: Bluetooth: hci0: Failed to read MSFT supported features>
ноя 20 22:00:30 aorusproax gdm-password][1222]: gkr-pam: unable to locate daemon control f>
lines 1-22...skipping...
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init vcp plugin
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init mcp plugin
ноя 20 22:00:08 aorusproax bluetoothd[756]: src/plugin.c:plugin_init() Failed to init bap plugin
ноя 20 22:00:18 aorusproax kernel: Bluetooth: hci0: FW download error recovery failed (-110)
ноя 20 22:00:20 aorusproax kernel: Bluetooth: hci0: Failed to read MSFT supported features (-110)
ноя 20 22:00:30 aorusproax gdm-password][1222]: gkr-pam: unable to locate daemon control file
ноя 20 22:00:31 aorusproax systemd[1249]: Failed to start Application launched by gnome-session-binary.
ноя 20 22:00:35 aorusproax gdm-launch-environment][818]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
ноя 20 19:25:18 aorusproax kernel: FAT-fs (sda1): unable to read boot sector to mark fs as dirty
ноя 20 19:27:07 aorusproax systemd-coredump[6247]: Failed to connect to coredump service: Connection refused
ноя 20 19:27:08 aorusproax systemd-coredump[6426]: Failed to connect to coredump service: Connection refused
ноя 20 19:27:16 aorusproax kernel: watchdog: watchdog0: watchdog did not stop!
Zesko
November 21, 2022, 7:01pm
4
I think the “Waking up” issue has nothing to do with bluetooth.
What is the output:
$ journalctl -p err --since "3 days ago" --no-page
pekod
December 2, 2022, 5:05pm
5
kernel: usb 1-1: 3:3: cannot set freq 24000 to ep 0x82
bluetoothd[775]: src/plugin.c:plugin_init() Failed to init vcp plugin
bluetoothd[775]: src/plugin.c:plugin_init() Failed to init mcp plugin
bluetoothd[775]: src/plugin.c:plugin_init() Failed to init bap plugin
systemd[1]: Failed to start pkgfile database update.
gdm-password][1247]: gkr-pam: unable to locate daemon control file
systemd[1264]: Failed to start Application launched by gnome-session-binary.
gdm-launch-environment][821]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
