Waking from suspend, not restoring session
When waking up my Manjaro system from suspend, i get a gdm login screen and then a new desktop session after login.
My previous desktop state is not there…
What can cause this to happen?
But when i first lock the desktop screen with: Super + L or “loginctl lock-session” then the suspending and wake up is correct!
Extra info:
Manjaro 6.12 installed on Btrfs and luks2. Using a modern UEFI ESP partition for booting. With Gnome running on Wayland.
GPU: Intel Arc DG2/A380
I tried suspending with both fast boot setting on and off. Same results as above.
Addition: with my previous install Ubuntu 24.04 (also Gnome) there where no issues relating suspend and wake-up, same hardware setup.
Only the glorious journal can reveal a hint.
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Output of inxi -zv8
  Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=UUID-002 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=UUID-004:luks-UUID-001
    root=/dev/mapper/luks-UUID-001 splash
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Desktop System: Gigabyte product: A520M S2H v: -CF serial: N/A
  Mobo: Gigabyte model: A520M S2H v: x.x serial: N/A
    uuid: UUID-7 UEFI: American Megatrends LLC.
    v: F19d date: 09/02/2024
  System RAM: total: 32 GiB available: 31.27 GiB used: 7.17 GiB (22.9%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3
    bus-ID: 00:03.1 children: 1: 05:00.0 class-ID: 0604 type: bridge children:
    1: 06:01.0 class-ID: 0604 type: bridge children: 1: 07:00.0 class-ID: 0300
    type: display 2: 06:04.0 class-ID: 0604 type: bridge children: 1: 08:00.0
    class-ID: 0403 type: audio
  Slot: 14 type: PCIe status: in use info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0108
    type: mass-storage
  Slot: 128 type: PCIe status: available info: J3708 length: short
    volts: 3.3 bus-ID: 00:1f.7
  Info: model: AMD Ryzen 5 5600 socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
    gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1750 min/max: 550/4468 boost: enabled
    base/boost: 3500/4450 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1750 2: 1750 3: 1750 4: 1750
    5: 1750 6: 1750 7: 1750 8: 1750 9: 1750 10: 1750 11: 1750 12: 1750
    bogomips: 83857
    xsaves xtopology
    affected
  Device-1: Intel DG2 [Arc A380] vendor: ASRock driver: i915 v: kernel
    alternate: xe arch: Xe-HPG code: Alchemist process: TSMC n6 (7nm)
    built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-2
    empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3, HDMI-A-4 bus-ID: 07:00.0
    chip-ID: x class-ID: 0300
  Device-2: Camera Microphone
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 3-4:3 chip-ID: x class-ID: 0102 serial: <filter>
  Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell driver: gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) MP59G
    serial: <filter> built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.306
    y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A380 Graphics (DG2)
    device-ID: x memory: 5.81 GiB unified: no
  Info: Tools: api: eglinfo,glxinfo gpu: gputop, intel_gpu_top, lsgpu
    x11: xprop,xrandr
  Device-1: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: x
    class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0a:00.4 chip-ID: x class-ID: 0403
  Device-3: Camera Microphone
    mode: 2.0 bus-ID: 3-4:3 chip-ID: x class-ID: x serial: <filter>
  API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: n/a (root, process) with:
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: x class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Device-1: luks-UUID-003 maj-min: 254:1
    type: LUKS dm: dm-1 size: 238.46 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 238.47 GiB
  Device-2: ssddata_crypt maj-min: 254:2 type: LUKS dm: dm-2
  Components:
  p-1: sdc maj-min: 8:32 size: 476.94 GiB
  Device-3: keystore-rpool maj-min: 254:3 type: LUKS dm: dm-3 size: 4 MiB
  Components:
  p-1: zd0 maj-min: 230:0 size: 20 MiB
  Device-4: luks-UUID-001 maj-min: 254:0
    type: LUKS dm: dm-0 size: 445.68 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 445.68 GiB
  Device-1: bpool type: zfs status: ONLINE level: linear raw: size: 1.88 GiB
    free: 1.48 GiB allocated: 403 MiB zfs-fs: size: 1.75 GiB free: 1.36 GiB
  Components: Online:
  1: sdb2 maj-min: 8:18 size: 2 GiB
  Device-2: rpool type: zfs status: ONLINE level: linear raw: size: 440 GiB
    free: 321 GiB allocated: 119 GiB zfs-fs: size: 426.38 GiB free: 301.9 GiB
  Components: Online:
  1: sdb4 maj-min: 8:20 size: 441.13 GiB
  Local Storage: total: 1.6 TiB used: 581.16 GiB (35.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSD 512GB size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> temp: 44.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: SSD 256GB size: 238.47 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 model: 480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 model: 500GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  ID-1: / raw-size: 445.68 GiB size: 445.68 GiB (100.00%)
    used: 65.4 GiB (14.7%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-UUID-001
    label: linux uuid: UUID-002
  ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 764 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p4
    maj-min: 259:4 label: BOOT uuid: 45B7-EDF1
  ID-3: /home raw-size: 445.68 GiB size: 445.68 GiB (100.00%)
  ID-4: /mnt/mnt/ubuntu24 raw-size: N/A size: 308.7 GiB used: 6.8 GiB (2.2%)
    fs: zfs logical: rpool/ROOT/ubuntu_abcde
  ID-5: /mnt/mnt/ubuntu24/srv raw-size: N/A size: 301.9 GiB
    used: 256 KiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/srv
  ID-6: /mnt/mnt/ubuntu24/usr/local raw-size: N/A size: 301.9 GiB
    used: 896 KiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/usr/local
  ID-7: /mnt/mnt/ubuntu24/var/games raw-size: N/A size: 301.9 GiB
    fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/games
  ID-8: /mnt/mnt/ubuntu24/var/lib raw-size: N/A size: 334.79 GiB
    used: 32.88 GiB (9.8%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/lib
  ID-9: /mnt/mnt/ubuntu24/var/lib/AccountsService raw-size: N/A
    size: 301.9 GiB used: 256 KiB (0.0%) fs: zfs
    logical: rpool/ROOT/ubuntu_abcde/var/lib/AccountsService
  ID-10: /mnt/mnt/ubuntu24/var/lib/NetworkManager raw-size: N/A
    size: 301.9 GiB used: 384 KiB (0.0%) fs: zfs
    logical: rpool/ROOT/ubuntu_abcde/var/lib/NetworkManager
  ID-11: /mnt/mnt/ubuntu24/var/lib/apt raw-size: N/A size: 302.01 GiB
    used: 109 MiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/lib/apt
  ID-12: /mnt/mnt/ubuntu24/var/lib/dpkg raw-size: N/A size: 301.99 GiB
    used: 85 MiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/lib/dpkg
  ID-13: /mnt/mnt/ubuntu24/var/log raw-size: N/A size: 302.04 GiB
    used: 140 MiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/log
  ID-14: /mnt/mnt/ubuntu24/var/mail raw-size: N/A size: 301.9 GiB
    used: 256 KiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/mail
  ID-15: /mnt/mnt/ubuntu24/var/snap raw-size: N/A size: 301.91 GiB
    used: 6.6 MiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/snap
  ID-16: /mnt/mnt/ubuntu24/var/spool raw-size: N/A size: 301.9 GiB
    used: 384 KiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/spool
  ID-17: /mnt/mnt/ubuntu24/var/www raw-size: N/A size: 301.9 GiB
    used: 256 KiB (0.0%) fs: zfs logical: rpool/ROOT/ubuntu_abcde/var/www
  ID-18: /mnt/mnt/ubuntu24_home raw-size: N/A size: 364.82 GiB
    used: 62.92 GiB (17.2%) fs: zfs logical: rpool/USERDATA/home_msi9bw
  ID-19: /mnt/mnt/ubuntu24_root raw-size: N/A size: 301.94 GiB
    used: 34.1 MiB (0.0%) fs: zfs logical: rpool/USERDATA/root_msi9bw
  ID-20: /mnt/ssddata raw-size: 476.92 GiB size: 476.92 GiB (100.00%)
    used: 208.73 GiB (43.8%) fs: btrfs block-size: 4096 B dev: /dev/dm-2
    maj-min: 254:2 mapped: ssddata_crypt label: N/A uuid: N/A
  ID-21: /mnt/ubuntu raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
    used: 204.06 GiB (85.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-UUID-003
    label: N/A uuid: UUID-005
  ID-22: /swap raw-size: 445.68 GiB size: 445.68 GiB (100.00%)
  ID-23: /tmp/keystore raw-size: 4 MiB size: 3.7 MiB (93.36%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-3
    maj-min: 254:3 mapped: keystore-rpool label: N/A uuid: N/A
  ID-24: /var/cache raw-size: 445.68 GiB size: 445.68 GiB (100.00%)
  ID-25: /var/log raw-size: 445.68 GiB size: 445.68 GiB (100.00%)
  ID-1: swap-1 type: file size: 20 GiB used: 12 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: x
    class-ID: x
  Device-1: 1-3:2 info: Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: x class-ID: x
  Device-2: 1-4:3 info: Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 1.1
  Device-3: 1-9:4 info: Integrated Express RGB LED Controller type: HID
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: x
    class-ID: x
    class-ID: x
  Device-1: 3-3:2 info: Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
  Device-2: 3-4:3 info: Camera Microphone
    type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    chip-ID: <filter>
    class-ID: x
  System Temperatures: cpu: 35.4 C mobo: 26.0 C
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 1218 libs: 354 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
  Processes: 620 Power: uptime: 21h 8m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.49 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2 default: Bash
    v: 5.2.37 running-in: gnome-terminal inxi: 3.3.38
Are you booting from a USB device, or have USB device(s) connected when this happens?
I notice errors in the logs regarding touchegg, but whether that and losing power to the root hub is related, is only speculation.
I’m afraid I don’t know what to do with that if they are.
The first log is normal, so actually the suspend process is normal, but the second one gives a hint:
Well here it looks like that the gnome-shell crashes before you suspend, therefore no sessions will be restored, since it crashed on suspend.
Since GJS and some theme functions are involved, I would conclude it is related to some modification like a non-default theme or some extensions. I would recommend deactivating the extensions completely, use the stock theme Adwaita. See if that solves the issue. If so, then activate them step by step again and see what actually causes it.
Thanks for looking into that.
There are some USB devices connected like keyboard, mouse receiver, Bluetooth receiver and webcam. Nothing special I think.
The system is booting from NVME drive, not from USB.
Not booting Manjaro on a USB disk then, that’s the main thing.
Thank you for a deep dive into the logs!
Looks like there is some crash before suspend with a gnome extension.
I did not change the stock theme (Adwaita), only installed 3 gnome extensions.
New user account
To be sure: i made a new user with a fresh desktop to test this out!
Opened some already installed gnome desktop apps and did a suspend by clicking the suspend button in the gnome power menu.
Result: Disappointed! Waking up with a new login session (gdm).
Disabled all gnome extensions
So i disabled all default enabled gnome extensions and unplugged the usb camera and usb bluetooth receiver, just to be sure.
Now the system does wake-up with the same session! (so there is something there…!!)
Second try
Then a few minutes later i tried it again. Left some apps open on the desktop and suspend the system.
Something different happened: the desktop session was still there, but the monitor says: out of range! Then flickers for a millisecond showing the lockscreen so i logged in, again message: out of range! Flickering again showing the saved session for a millisecond and again and again…
At least 10 to 20 times! Not good for my LG IPS 27" FullHD LCD monitor i guess?
Then finally just showing the saved desktop session normally.
Third try
So i did suspend again: same with all the monitor out of range and flickering…
Different test
Then i tried suspend with first locking the screen with Super + L
Wake-up works great: no out of range and session restored!
(to be sure: this was all tested on the newly made user account)
But this last test also works on my own user account as well, with all the gnome extensions enabled.
journalctl -b -r -p warning:
apr 18 23:57:25 desktop-pc gnome-shell[28748]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:57:23 desktop-pc gnome-shell[28748]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:32:23 desktop-pc /usr/lib/gdm-wayland-session[28632]: discover_other_daemon: 1
apr 18 23:32:23 desktop-pc xdg-document-po[28571]: Error releasing name org.freedesktop.portal.Documents: The connection is closed
apr 18 23:32:22 desktop-pc gsd-media-keys[28881]: Unable to get default sink
apr 18 23:32:22 desktop-pc gsd-xsettings[29269]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
apr 18 23:32:22 desktop-pc gsd-media-keys[28881]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 18 23:32:22 desktop-pc gsd-media-keys[28881]: Failed to grab accelerator for keybinding settings:hibernate
apr 18 23:32:22 desktop-pc gsd-color[28853]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 18 23:32:22 desktop-pc gnome-shell[28748]: [FREON] Unable to find smart devices: GLib.SpawnError: Failed to execute child process “null” (No such file or directory)
                                               Stack trace:
                                                 getSmartData@file:///home/user-x/.local/share/gnome-shell/extensions/freon@UshakovVasilii_Github.yahoo.com/smartctlUtil.js:5:54
                                                 SmartctlUtil@file:///home/user-x/.local/share/gnome-shell/extensions/freon@UshakovVasilii_Github.yahoo.com/smartctlUtil.js:13:34
                                                 _initSmartctlUtility@file:///home/user-x/.local/share/gnome-shell/extensions/freon@UshakovVasilii_Github.yahoo.com/extension.js:445:36
                                                 FreonMenuButton@file:///home/user-x/.local/share/gnome-shell/extensions/freon@UshakovVasilii_Github.yahoo.com/extension.js:88:14
                                                 enable@file:///home/user-x/.local/share/gnome-shell/extensions/freon@UshakovVasilii_Github.yahoo.com/extension.js:1044:27
                                                 _callExtensionEnable@resource:///org/gnome/shell/ui/extensionSystem.js:266:38
                                                 loadExtension@resource:///org/gnome/shell/ui/extensionSystem.js:433:32
                                                 async*_loadExtensions@resource:///org/gnome/shell/ui/extensionSystem.js:741:24
                                                 async*_enableAllExtensions@resource:///org/gnome/shell/ui/extensionSystem.js:747:48
                                                 _sessionUpdated@resource:///org/gnome/shell/ui/extensionSystem.js:782:20
                                                 async*init@resource:///org/gnome/shell/ui/extensionSystem.js:76:14
                                                 _initializeUI@resource:///org/gnome/shell/ui/main.js:329:22
                                                 start@resource:///org/gnome/shell/ui/main.js:180:11
                                                 @resource:///org/gnome/shell/ui/init.js:12:47
                                                 @resource:///org/gnome/shell/ui/init.js:21:20
apr 18 23:32:22 desktop-pc gsd-usb-protect[28925]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 18 23:32:22 desktop-pc systemd[28656]: Failed to start Application launched by gnome-session-binary.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-28974.scope: Failed with result 'resources'.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-28974.scope: No PIDs left to attach to the scope's control group, refusing.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-create\x2dtemplate-28992.scope: Failed with result 'resources'.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-create\x2dtemplate-28992.scope: No PIDs left to attach to the scope's control group, refusing.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-xapp\x2dsn\x2dwatcher-28879.scope: Failed with result 'resources'.
apr 18 23:32:22 desktop-pc systemd[28656]: app-gnome-xapp\x2dsn\x2dwatcher-28879.scope: No PIDs left to attach to the scope's control group, refusing.
apr 18 23:32:21 desktop-pc wireplumber[26530]: pw.core: 0x602b4ca2ab10: leaked proxy 0x602b4ccb1490 id:11
apr 18 23:32:21 desktop-pc wireplumber[26530]: pw.core: 0x602b4ca2ab10: leaked proxy 0x602b4cce7020 id:10
apr 18 23:32:21 desktop-pc wireplumber[26530]: pw.core: 0x602b4ca2ab10: leaked proxy 0x602b4cb185f0 id:9
apr 18 23:32:21 desktop-pc wireplumber[26530]: pw.core: 0x602b4ca2ab10: leaked proxy 0x602b4c96ad40 id:7
apr 18 23:32:21 desktop-pc wireplumber[26530]: pw.core: 0x602b4ca2ab10: leaked proxy 0x602b4ca33f40 id:4
apr 18 23:32:21 desktop-pc systemd[28656]: Dependency failed for GNOME XSettings service.
apr 18 23:32:21 desktop-pc gnome-keyring-daemon[28745]: discover_other_daemon: 1
apr 18 23:32:21 desktop-pc gnome-keyring-daemon[28744]: discover_other_daemon: 1
apr 18 23:32:21 desktop-pc gnome-session-binary[28730]: WARNING: Desktop file /home/user-x/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
apr 18 23:32:21 desktop-pc gsd-media-keys[28305]: Unable to get default sink
apr 18 23:32:21 desktop-pc gsd-media-keys[28305]: Unable to get default source
apr 18 23:32:20 desktop-pc gdm-password][28647]: gkr-pam: unable to locate daemon control file
apr 18 23:32:13 desktop-pc gnome-keyring-daemon[28632]: discover_other_daemon: 1
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28632]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.44' (uid=120 pid=28564 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
apr 18 23:32:13 desktop-pc xdg-desktop-por[28623]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28623]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28623]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.44' (uid=120 pid=28564 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:32:13 desktop-pc xdg-desktop-por[28564]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28564]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28564]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
apr 18 23:32:13 desktop-pc gsd-media-keys[28305]: Unable to get default sink
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
apr 18 23:32:13 desktop-pc gnome-control-c[28612]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc gnome-control-c[28612]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc gnome-control-c[28612]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.48' (uid=120 pid=28586 comm="/usr/lib/xdg-desktop-portal-gnome")
apr 18 23:32:13 desktop-pc xdg-desktop-por[28586]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28586]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc xdg-desktop-por[28586]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.44' (uid=120 pid=28564 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.44' (uid=120 pid=28564 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.43' (uid=120 pid=28477 comm="/usr/lib/mutter-x11-frames")
apr 18 23:32:13 desktop-pc gsd-media-keys[28305]: Failed to grab accelerator for keybinding settings:hibernate
apr 18 23:32:13 desktop-pc gsd-media-keys[28305]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 18 23:32:13 desktop-pc gsd-xsettings[28336]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc gsd-xsettings[28336]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc gsd-xsettings[28336]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:13 desktop-pc geoclue[28476]: Failed to connect to avahi service: Daemon not running
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=28488 comm="ibus-daemon --panel disable -r --xim")
apr 18 23:32:13 desktop-pc gsd-color[28260]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 18 23:32:13 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
apr 18 23:32:12 desktop-pc gsd-usb-protect[28257]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
apr 18 23:32:12 desktop-pc gsd-power[28355]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-power[28355]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-power[28355]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sharing[28247]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.24' (uid=120 pid=28347 comm="/usr/lib/gsd-housekeeping")
apr 18 23:32:12 desktop-pc gsd-housekeepin[28347]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-housekeepin[28347]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-housekeepin[28347]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-media-keys[28305]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-media-keys[28305]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-media-keys[28305]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=28257 comm="/usr/lib/gsd-usb-protection")
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 18 23:32:12 desktop-pc gsd-usb-protect[28257]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-usb-protect[28257]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-usb-protect[28257]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-a11y-settin[28327]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-a11y-settin[28327]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-a11y-settin[28327]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-datetime[28299]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-datetime[28299]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-datetime[28299]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-smartcard[28285]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-smartcard[28285]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-smartcard[28285]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
apr 18 23:32:12 desktop-pc gsd-sound[28319]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sound[28319]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sound[28319]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.20' (uid=120 pid=28262 comm="ibus-daemon --panel disable")
apr 18 23:32:12 desktop-pc gjs[28219]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gjs[28219]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gjs[28219]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-wacom[28289]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-wacom[28289]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-wacom[28289]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-color[28260]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-color[28260]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-color[28260]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-keyboard[28264]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-keyboard[28264]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-keyboard[28264]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sharing[28247]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sharing[28247]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsd-sharing[28247]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-shell[28160]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10a8db2201ece438174501193232154000000281480000.ms”: No such file or directory
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=28160 comm="/usr/bin/gnome-shell")
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=28160 comm="/usr/bin/gnome-shell")
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=28160 comm="/usr/bin/gnome-shell")
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28206]: dbus-daemon[28206]: Successfully activated service 'org.a11y.atspi.Registry'
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28206]: dbus-daemon[28206]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=28160 comm="/usr/bin/gnome-shell")
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Successfully activated service 'org.a11y.Bus'
apr 18 23:32:12 desktop-pc at-spi-bus-laun[28200]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc at-spi-bus-laun[28200]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc at-spi-bus-laun[28200]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=28160 comm="/usr/bin/gnome-shell")
apr 18 23:32:12 desktop-pc gnome-shell[28160]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-shell[28160]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-shell[28160]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-session-binary[28148]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
apr 18 23:32:12 desktop-pc gnome-session-binary[28148]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:32:12 desktop-pc /usr/lib/gdm-wayland-session[28147]: dbus-daemon[28147]: [session uid=120 pid=28147 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=28148 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
apr 18 23:32:12 desktop-pc gnome-session-b[28148]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-session-b[28148]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gnome-session-b[28148]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsettings[28149]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsettings[28149]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:12 desktop-pc gsettings[28149]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:32:11 desktop-pc systemd[26011]: dbus-:1.2-org.gnome.Nautilus@0.service: Failed with result 'exit-code'.
apr 18 23:32:11 desktop-pc systemd[26011]: dbus-:1.2-org.gnome.Lollypop.SearchProvider@0.service: Failed with result 'exit-code'.
apr 18 23:32:11 desktop-pc systemd[26011]: dbus-:1.2-org.gnome.Calendar@0.service: Failed with result 'exit-code'.
apr 18 23:32:11 desktop-pc localsearch-3[26855]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc nautilus[26827]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc localsearch-3[26855]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc localsearch-3[26855]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc localsearch-3[26855]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc nautilus[26827]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc nautilus[26827]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc nautilus[26827]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc localsearch-3[26855]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:32:11 desktop-pc nautilus[26827]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:30:57 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 18 23:30:57 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 18 23:30:57 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 18 23:30:56 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 18 23:30:56 desktop-pc dbus-broker[1053]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.1100.
apr 18 23:30:56 desktop-pc kernel: usb 1-4: WARN: invalid context state for evaluate context command.
apr 18 23:30:56 desktop-pc kernel: usb 1-9: WARN: invalid context state for evaluate context command.
apr 18 23:30:56 desktop-pc kernel: usb 1-3: WARN: invalid context state for evaluate context command.
apr 18 23:30:56 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 18 23:26:04 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 18 23:26:04 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 18 23:26:04 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 18 23:26:03 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 18 23:26:03 desktop-pc dbus-broker[1053]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.1100.
apr 18 23:26:03 desktop-pc kernel: usb 1-9: WARN: invalid context state for evaluate context command.
apr 18 23:26:03 desktop-pc kernel: usb 1-4: WARN: invalid context state for evaluate context command.
apr 18 23:26:03 desktop-pc kernel: usb 1-3: WARN: invalid context state for evaluate context command.
apr 18 23:26:03 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 18 23:21:29 desktop-pc gnome-shell[26103]: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: Set global engine failed: Operation was cancelled
                                               Stack trace:
                                                 _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:453:45
                                                 ### Promise created here: ###
                                                 _setEngine@resource:///org/gnome/shell/misc/ibusManager.js:286:30
                                                 setEngine@resource:///org/gnome/shell/misc/ibusManager.js:299:24
                                                 activateInputSource@resource:///org/gnome/shell/ui/status/keyboard.js:525:27
                                                 _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
                                                 _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
                                                 activate@resource:///org/gnome/shell/ui/status/keyboard.js:66:14
                                                 _inputSourcesChanged@resource:///org/gnome/shell/ui/status/keyboard.js:663:33
                                                 reload@resource:///org/gnome/shell/ui/status/keyboard.js:396:14
                                                 _ibusSetContentType@resource:///org/gnome/shell/ui/status/keyboard.js:738:14
                                                 _setContentType@resource:///org/gnome/shell/misc/ibusManager.js:264:14
apr 18 23:20:57 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 18 23:20:57 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 18 23:20:57 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 18 23:20:57 desktop-pc kernel: Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
apr 18 23:20:57 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 18 23:20:57 desktop-pc dbus-broker[1053]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.1100.
apr 18 23:20:57 desktop-pc rtkit-daemon[1210]: The canary thread is apparently starving. Taking action.
apr 18 23:20:57 desktop-pc kernel: usb 1-9: WARN: invalid context state for evaluate context command.
apr 18 23:20:57 desktop-pc kernel: usb 1-4: WARN: invalid context state for evaluate context command.
apr 18 23:20:57 desktop-pc kernel: usb 1-3: WARN: invalid context state for evaluate context command.
apr 18 23:20:57 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 18 23:18:11 desktop-pc gnome-shell[26103]: Type gint32 of property AccountsService.User::password-mode does not match return type interface of getter get_password_mode. Falling back to slow path
apr 18 23:16:58 desktop-pc gsd-media-keys[26220]: Unable to get default sink
apr 18 23:16:58 desktop-pc gnome-shell[25452]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
apr 18 23:16:58 desktop-pc gnome-shell[25452]: Xwayland terminated, exiting since it was mandatory
apr 18 23:16:58 desktop-pc gnome-shell[25452]: Connection to xwayland lost
apr 18 23:16:58 desktop-pc gsd-xsettings[26602]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
apr 18 23:16:58 desktop-pc gsd-media-keys[26220]: Failed to grab accelerator for keybinding settings:hibernate
apr 18 23:16:58 desktop-pc gsd-media-keys[26220]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 18 23:16:58 desktop-pc gnome-shell[26103]: Failed to make thread 'KMS thread' high priority scheduled: Operation not permitted
apr 18 23:16:58 desktop-pc rtkit-daemon[1210]: Recovering from system lockup, not allowing further RT threads.
apr 18 23:16:58 desktop-pc geoclue[26535]: Failed to connect to avahi service: Daemon not running
apr 18 23:16:58 desktop-pc gsd-color[26200]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 18 23:16:57 desktop-pc gsd-usb-protect[26260]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 18 23:16:57 desktop-pc systemd[26011]: Failed to start Application launched by gnome-session-binary.
apr 18 23:16:57 desktop-pc systemd[26011]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-26319.scope: Failed with result 'resources'.
apr 18 23:16:57 desktop-pc systemd[26011]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-26319.scope: No PIDs left to attach to the scope's control group, refusing.
apr 18 23:16:57 desktop-pc systemd[26011]: app-gnome-xapp\x2dsn\x2dwatcher-26221.scope: Failed with result 'resources'.
apr 18 23:16:57 desktop-pc systemd[26011]: app-gnome-xapp\x2dsn\x2dwatcher-26221.scope: No PIDs left to attach to the scope's control group, refusing.
apr 18 23:16:57 desktop-pc systemd[26011]: Dependency failed for GNOME XSettings service.
apr 18 23:16:57 desktop-pc gnome-shell[26103]: Failed to make thread 'KMS thread' high priority scheduled: Operation not permitted
apr 18 23:16:57 desktop-pc rtkit-daemon[1210]: Recovering from system lockup, not allowing further RT threads.
apr 18 23:16:57 desktop-pc gnome-keyring-daemon[26100]: discover_other_daemon: 1
apr 18 23:16:57 desktop-pc gnome-keyring-daemon[26099]: discover_other_daemon: 1
apr 18 23:16:57 desktop-pc gnome-session-binary[26085]: WARNING: Desktop file /home/second/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
apr 18 23:16:56 desktop-pc gsd-media-keys[25589]: Unable to get default sink
apr 18 23:16:56 desktop-pc gsd-media-keys[25589]: Unable to get default source
apr 18 23:16:56 desktop-pc gdm-password][25980]: gkr-pam: unable to locate daemon control file
apr 18 23:15:56 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Failed to activate service 'org.freedesktop.secrets': timed out (service_start_timeout=120000ms)
apr 18 23:14:21 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.portal.Desktop'
apr 18 23:14:21 desktop-pc /usr/lib/gdm-wayland-session[25915]: discover_other_daemon: 1
apr 18 23:14:21 desktop-pc xdg-desktop-por[25856]: No skeleton to export
apr 18 23:14:21 desktop-pc xdg-desktop-por[25856]: Failed to create secret proxy: Error calling StartServiceByName for org.freedesktop.secrets: Timeout was reached
apr 18 23:14:20 desktop-pc mutter-x11-fram[25807]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:14:20 desktop-pc mutter-x11-fram[25807]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:14:20 desktop-pc mutter-x11-fram[25807]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:14:19 desktop-pc kernel: usb 3-4: [7] FU [Mic Capture Volume] ch = 1, val = 200/4096/1
apr 18 23:14:19 desktop-pc kernel: usb 3-4: Warning! Unlikely big volume range (=3896), cval->res is probably wrong.
apr 18 23:14:19 desktop-pc kernel: usb 3-4: 3:3: cannot get freq at ep 0x86
apr 18 23:14:19 desktop-pc kernel: usb 3-4: 3:2: cannot get freq at ep 0x86
apr 18 23:14:19 desktop-pc kernel: usb 3-4: 3:1: cannot get freq at ep 0x86
apr 18 23:14:11 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 18 23:14:11 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 18 23:14:11 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 18 23:14:10 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 18 23:14:04 desktop-pc wireplumber[18545]: pw.core: 0x62e76ef9c4b0: leaked proxy 0x62e76f0ffc70 id:7
apr 18 23:14:04 desktop-pc wireplumber[18545]: pw.core: 0x62e76ef9c4b0: leaked proxy 0x62e76eebc170 id:4
apr 18 23:13:56 desktop-pc gnome-keyring-daemon[25915]: discover_other_daemon: 1
apr 18 23:13:56 desktop-pc /usr/lib/gdm-wayland-session[25915]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
apr 18 23:13:56 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.44' (uid=120 pid=25856 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:13:56 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
apr 18 23:13:56 desktop-pc xdg-desktop-por[25906]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc xdg-desktop-por[25906]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc xdg-desktop-por[25906]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.44' (uid=120 pid=25856 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:13:56 desktop-pc xdg-desktop-por[25856]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc xdg-desktop-por[25856]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc xdg-desktop-por[25856]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:56 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: Unable to get default sink
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
apr 18 23:13:55 desktop-pc gnome-control-c[25895]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gnome-control-c[25895]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gnome-control-c[25895]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.48' (uid=120 pid=25876 comm="/usr/lib/xdg-desktop-portal-gnome")
apr 18 23:13:55 desktop-pc xdg-desktop-por[25876]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc xdg-desktop-por[25876]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc xdg-desktop-por[25876]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.44' (uid=120 pid=25856 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.44' (uid=120 pid=25856 comm="/usr/lib/xdg-desktop-portal")
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.43' (uid=120 pid=25807 comm="/usr/lib/mutter-x11-frames")
apr 18 23:13:55 desktop-pc gsd-xsettings[25619]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-xsettings[25619]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-xsettings[25619]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=25808 comm="ibus-daemon --panel disable -r --xim")
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: Failed to grab accelerator for keybinding settings:hibernate
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 18 23:13:55 desktop-pc gnome-shell[25452]: Failed to make thread 'KMS thread' high priority scheduled: Operation not permitted
apr 18 23:13:55 desktop-pc rtkit-daemon[1210]: Recovering from system lockup, not allowing further RT threads.
apr 18 23:13:55 desktop-pc gsd-color[25551]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 18 23:13:55 desktop-pc geoclue[25764]: Failed to connect to avahi service: Daemon not running
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
apr 18 23:13:55 desktop-pc gsd-usb-protect[25547]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
apr 18 23:13:55 desktop-pc gsd-sharing[25535]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=120 pid=25535 comm="/usr/lib/gsd-sharing")
apr 18 23:13:55 desktop-pc gsd-power[25644]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-power[25644]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-power[25644]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=25547 comm="/usr/lib/gsd-usb-protection")
apr 18 23:13:55 desktop-pc gsd-housekeepin[25630]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-housekeepin[25630]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-housekeepin[25630]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
apr 18 23:13:55 desktop-pc gjs[25506]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gjs[25506]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gjs[25506]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-usb-protect[25547]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-usb-protect[25547]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sound[25596]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-a11y-settin[25613]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-a11y-settin[25613]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sound[25596]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-a11y-settin[25613]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-usb-protect[25547]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-media-keys[25589]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-smartcard[25576]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-smartcard[25576]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-smartcard[25576]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sound[25596]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-datetime[25585]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-datetime[25585]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-datetime[25585]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-wacom[25578]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-wacom[25578]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-wacom[25578]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.20' (uid=120 pid=25553 comm="ibus-daemon --panel disable")
apr 18 23:13:55 desktop-pc gsd-keyboard[25555]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-keyboard[25555]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-keyboard[25555]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-color[25551]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-color[25551]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-color[25551]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sharing[25535]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sharing[25535]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gsd-sharing[25535]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:55 desktop-pc gnome-shell[25452]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/1085896e0078b6bacf174501083452163800000254400000.ms”: No such file or directory
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=25452 comm="/usr/bin/gnome-shell")
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=25452 comm="/usr/bin/gnome-shell")
apr 18 23:13:55 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=25452 comm="/usr/bin/gnome-shell")
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25497]: dbus-daemon[25497]: Successfully activated service 'org.a11y.atspi.Registry'
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25497]: dbus-daemon[25497]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=25452 comm="/usr/bin/gnome-shell")
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Successfully activated service 'org.a11y.Bus'
apr 18 23:13:54 desktop-pc at-spi-bus-laun[25491]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc at-spi-bus-laun[25491]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc at-spi-bus-laun[25491]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=25452 comm="/usr/bin/gnome-shell")
apr 18 23:13:54 desktop-pc gnome-shell[25452]: Failed to make thread 'KMS thread' high priority scheduled: Operation not permitted
apr 18 23:13:54 desktop-pc rtkit-daemon[1210]: Recovering from system lockup, not allowing further RT threads.
apr 18 23:13:54 desktop-pc gnome-shell[25452]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gnome-shell[25452]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gnome-shell[25452]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gnome-session-binary[25440]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
apr 18 23:13:54 desktop-pc gnome-session-binary[25440]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 18 23:13:54 desktop-pc /usr/lib/gdm-wayland-session[25439]: dbus-daemon[25439]: [session uid=120 pid=25439 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=25440 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
apr 18 23:13:54 desktop-pc gnome-session-b[25440]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gnome-session-b[25440]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gnome-session-b[25440]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gsettings[25441]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gsettings[25441]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc gsettings[25441]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 18 23:13:54 desktop-pc systemd[18000]: dbus-:1.2-org.gnome.Shell.Extensions.GSConnect@0.service: Failed with result 'exit-code'.
apr 18 23:13:53 desktop-pc systemd[18000]: dbus-:1.2-org.gnome.Lollypop.SearchProvider@0.service: Failed with result 'exit-code'.
apr 18 23:13:53 desktop-pc systemd[18000]: dbus-:1.2-org.gnome.Calendar@0.service: Failed with result 'exit-code'.
apr 18 23:13:53 desktop-pc localsearch-3[23224]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:13:53 desktop-pc localsearch-3[23224]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:13:53 desktop-pc localsearch-3[23224]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:13:53 desktop-pc localsearch-3[23224]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:13:53 desktop-pc localsearch-3[23224]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 18 23:12:30 desktop-pc rtkit-daemon[1210]: The canary thread is apparently starving. Taking action.
apr 18 23:12:30 desktop-pc kernel: usb 1-3: WARN: invalid context state for evaluate context command.
apr 18 23:12:30 desktop-pc kernel: usb 1-9: WARN: invalid context state for evaluate context command.
apr 18 23:12:30 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 18 23:07:00 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:06:59 desktop-pc gnome-shell[22597]: Type gint32 of property AccountsService.User::password-mode does not match return type interface of getter get_password_mode. Falling back to slow path
apr 18 23:06:55 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:06:54 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:49 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:48 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:47 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:46 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:38 desktop-pc gnome-shell[22597]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 18 23:05:31 desktop-pc gsd-media-keys[22708]: Unable to get default source
I can provide more logs if you need. But i hope this helps find some clue.
In Known Issues and Solutions (several months ago) there was a workaround posted for something similar. Now, the issue isn’t exactly as you have described yours, but it might be worth investigating, nonetheless.
It’s a longshot, and will not necessarilly solve the issue.
In KDE Plasma there is an option to “Start with an empty session” which worked around another similar issue.
Not being a Gnome user, I can’t say whether something similar might be helpful in Gnome.
Then it’s the resolution or frequency or something like that. The GPU is sending a signal that the monitor can’t handle.
Why does it work in the login screen? Because GDM (login) and GNOME don’t share the same monitor settings. I did this here: https://wiki.archlinux.org/title/GDM#Setup_default_monitor_settings to match that.
But in your case it may be rather counterproductive. Looks like a GPU problem to me now. The GPU is also relatively new in the kernel:
I would try a different resolution. Preferably the resolution that GDM uses. This may well be a bug.
There is no such feature in Gnome. For the sake of simplicity, Gnome only uses the standby mode to avoid clumping things together.
I did install Manjaro kernel 6.6 and boot from it, tested with a new user.
Results were the same, monitor signal out of range and flickering like 10 times before a normal images was on the screen.
The session was restored, like in kernel 6.12. So nothing new there.
Here the dmesg logs from the test:
[  361.496458] mei_gsc i915.mei-gscfi.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
[  361.497417] mei_gsc i915.mei-gsc.1792: FW not ready: resetting: dev_state = 2 pxp = 2
[  361.497448] mei_gsc i915.mei-gsc.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
[  361.721174] ata2: SATA link down (SStatus 0 SControl 300)
[  361.816947] usb 1-3: reset full-speed USB device number 2 using xhci_hcd
[  361.879933] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[  361.879939] ata1.00: Entering active power mode
[  361.879952] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[  361.879957] ata6.00: Entering active power mode
[  361.879969] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[  361.879974] ata5.00: Entering active power mode
[  361.882220] sd 4:0:0:0: [sdb] Starting disk
[  361.885622] ata5.00: configured for UDMA/133
[  361.891858] sd 5:0:0:0: [sdc] Starting disk
[  361.895649] sd 0:0:0:0: [sda] Starting disk
[  361.905667] ata1.00: configured for UDMA/133
[  361.915008] ata6.00: configured for UDMA/133
[  362.336808] usb 1-9: reset full-speed USB device number 4 using xhci_hcd
[  362.813330] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[  363.113731] OOM killer enabled.
[  363.113734] Restarting tasks ... done.
[  363.115475] random: crng reseeded on system resumption
[  363.115703] PM: suspend exit
[  363.129874] i915 0000:07:00.0: [drm] GT0: HuC: authenticated for all workloads
[  363.129880] mei_pxp i915.mei-gsc.UUID-012: bound 0000:07:00.0 (ops i915_pxp_tee_component_ops [i915])
[  363.131776] Bluetooth: hci0: CSR: Setting up dongle with HCI ver=6 rev=0812
[  363.131778] Bluetooth: hci0: LMP ver=6 subver=0812; manufacturer=10
[  363.131780] Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
[  363.131782] Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
[  363.131812] Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
[  363.131813] Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
[  363.131814] Bluetooth: hci0: HCI Set Event Filter command not supported.
[  363.206290] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
[  363.238900] Bluetooth: MGMT ver 1.22
[  363.403194] r8169 0000:04:00.0 enp4s0: Link is Down
[  366.806964] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  595.100879] rfkill: input handler enabled
[  596.436789] rfkill: input handler disabled
[  604.528379] rfkill: input handler enabled
[  605.290391] rfkill: input handler disabled
And the output of journalctl -b -r -p warning:
apr 19 21:23:38 desktop-pc /usr/lib/gdm-wayland-session[4866]: discover_other_daemon: 1
apr 19 21:23:38 desktop-pc gnome-shell[4384]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
                                              @resource:///org/gnome/shell/ui/init.js:21:20
apr 19 21:23:38 desktop-pc gnome-shell[4384]: Xwayland terminated, exiting since it was mandatory
apr 19 21:23:38 desktop-pc gnome-shell[4384]: Connection to xwayland lost
apr 19 21:23:38 desktop-pc gsd-media-keys[5119]: Unable to get default sink
apr 19 21:23:38 desktop-pc gsd-xsettings[5510]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
apr 19 21:23:38 desktop-pc gsd-media-keys[5119]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 19 21:23:38 desktop-pc gsd-media-keys[5119]: Failed to grab accelerator for keybinding settings:hibernate
apr 19 21:23:38 desktop-pc gsd-color[5102]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 19 21:23:37 desktop-pc gsd-usb-protect[5157]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 19 21:23:37 desktop-pc wireplumber[2273]: pw.core: 0x559ed9b8a230: leaked proxy 0x559ed9ac0320 id:13
apr 19 21:23:37 desktop-pc wireplumber[2273]: pw.core: 0x559ed9b8a230: leaked proxy 0x559ed9b49810 id:12
apr 19 21:23:37 desktop-pc wireplumber[2273]: pw.core: 0x559ed9b8a230: leaked proxy 0x559ed9de9540 id:10
apr 19 21:23:37 desktop-pc wireplumber[2273]: pw.core: 0x559ed9b8a230: leaked proxy 0x559ed9b31ab0 id:9
apr 19 21:23:37 desktop-pc wireplumber[2273]: pw.core: 0x559ed9b8a230: leaked proxy 0x559ed9abffc0 id:7
apr 19 21:23:37 desktop-pc systemd[4890]: Failed to start Application launched by gnome-session-binary.
apr 19 21:23:37 desktop-pc systemd[4890]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-5226.scope: Failed with result 'resources'.
apr 19 21:23:37 desktop-pc systemd[4890]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-5226.scope: No PIDs left to attach to the scope's control group, refusing.
apr 19 21:23:37 desktop-pc systemd[4890]: app-gnome-create\x2dtemplate-5240.scope: Failed with result 'resources'.
apr 19 21:23:37 desktop-pc systemd[4890]: app-gnome-create\x2dtemplate-5240.scope: No PIDs left to attach to the scope's control group, refusing.
apr 19 21:23:37 desktop-pc systemd[4890]: Dependency failed for GNOME XSettings service.
apr 19 21:23:37 desktop-pc gnome-keyring-daemon[4979]: discover_other_daemon: 1
apr 19 21:23:37 desktop-pc gnome-keyring-daemon[4978]: discover_other_daemon: 1
apr 19 21:23:37 desktop-pc gnome-session-binary[4964]: WARNING: Desktop file /home/user-x/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
apr 19 21:23:36 desktop-pc gsd-media-keys[4531]: Unable to get default source
apr 19 21:23:36 desktop-pc gsd-media-keys[4531]: Unable to get default sink
apr 19 21:23:36 desktop-pc gdm-password][4881]: gkr-pam: unable to locate daemon control file
apr 19 21:23:29 desktop-pc gnome-keyring-daemon[4866]: discover_other_daemon: 1
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4866]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.43' (uid=120 pid=4782 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
apr 19 21:23:29 desktop-pc xdg-desktop-por[4857]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4857]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4857]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.43' (uid=120 pid=4782 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:23:29 desktop-pc xdg-desktop-por[4782]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4782]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4782]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
apr 19 21:23:29 desktop-pc gsd-media-keys[4531]: Unable to get default sink
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
apr 19 21:23:29 desktop-pc gnome-control-c[4845]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc gnome-control-c[4845]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc gnome-control-c[4845]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.46' (uid=120 pid=4811 comm="/usr/lib/xdg-desktop-portal-gnome")
apr 19 21:23:29 desktop-pc gsd-media-keys[4531]: Failed to grab accelerator for keybinding settings:hibernate
apr 19 21:23:29 desktop-pc gsd-media-keys[4531]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 19 21:23:29 desktop-pc xdg-desktop-por[4811]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4811]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc xdg-desktop-por[4811]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.43' (uid=120 pid=4782 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.43' (uid=120 pid=4782 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.42' (uid=120 pid=4722 comm="/usr/lib/mutter-x11-frames")
apr 19 21:23:29 desktop-pc gsd-xsettings[4557]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc gsd-xsettings[4557]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc gsd-xsettings[4557]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=4726 comm="ibus-daemon --panel disable -r --xim")
apr 19 21:23:29 desktop-pc geoclue[4700]: Failed to connect to avahi service: Daemon not running
apr 19 21:23:29 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
apr 19 21:23:29 desktop-pc gsd-color[4487]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 19 21:23:28 desktop-pc gsd-usb-protect[4483]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 19 21:23:28 desktop-pc gsd-power[4576]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-power[4576]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-power[4576]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sharing[4474]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
apr 19 21:23:28 desktop-pc gsd-housekeepin[4569]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 19 21:23:28 desktop-pc gsd-housekeepin[4569]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-housekeepin[4569]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=120 pid=4474 comm="/usr/lib/gsd-sharing")
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 19 21:23:28 desktop-pc gsd-media-keys[4531]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-media-keys[4531]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-media-keys[4531]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=4483 comm="/usr/lib/gsd-usb-protection")
apr 19 21:23:28 desktop-pc gsd-a11y-settin[4550]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-a11y-settin[4550]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sound[4544]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sound[4544]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sound[4544]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-a11y-settin[4550]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-datetime[4527]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-datetime[4527]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-datetime[4527]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-usb-protect[4483]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-usb-protect[4483]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.23' (uid=120 pid=4510 comm="ibus-daemon --panel disable")
apr 19 21:23:28 desktop-pc gsd-usb-protect[4483]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-smartcard[4512]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-smartcard[4512]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-smartcard[4512]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gjs[4445]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gjs[4445]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gjs[4445]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
apr 19 21:23:28 desktop-pc gsd-wacom[4517]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-wacom[4517]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-wacom[4517]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-keyboard[4494]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-keyboard[4494]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-keyboard[4494]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-color[4487]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-color[4487]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-color[4487]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sharing[4474]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sharing[4474]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsd-sharing[4474]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-shell[4384]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10b8f0276f4e54bc5f174509060817371600000043720000.ms”: No such file or directory
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=4384 comm="/usr/bin/gnome-shell")
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=4384 comm="/usr/bin/gnome-shell")
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=4384 comm="/usr/bin/gnome-shell")
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4432]: dbus-daemon[4432]: Successfully activated service 'org.a11y.atspi.Registry'
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4432]: dbus-daemon[4432]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=4384 comm="/usr/bin/gnome-shell")
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Successfully activated service 'org.a11y.Bus'
apr 19 21:23:28 desktop-pc at-spi-bus-laun[4426]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc at-spi-bus-laun[4426]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc at-spi-bus-laun[4426]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=4384 comm="/usr/bin/gnome-shell")
apr 19 21:23:28 desktop-pc gnome-shell[4384]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-shell[4384]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-shell[4384]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-session-binary[4372]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
apr 19 21:23:28 desktop-pc gnome-session-binary[4372]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
apr 19 21:23:28 desktop-pc /usr/lib/gdm-wayland-session[4371]: dbus-daemon[4371]: [session uid=120 pid=4371 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=4372 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
apr 19 21:23:28 desktop-pc gnome-session-b[4372]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-session-b[4372]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gnome-session-b[4372]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsettings[4373]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsettings[4373]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:28 desktop-pc gsettings[4373]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:23:27 desktop-pc systemd[1739]: dbus-:1.2-org.gnome.Nautilus@1.service: Failed with result 'exit-code'.
apr 19 21:23:27 desktop-pc localsearch-3[2907]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc systemd[1739]: dbus-:1.2-org.gnome.Lollypop.SearchProvider@0.service: Failed with result 'exit-code'.
apr 19 21:23:27 desktop-pc systemd[1739]: dbus-:1.2-org.gnome.Calendar@0.service: Failed with result 'exit-code'.
apr 19 21:23:27 desktop-pc localsearch-3[2907]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc nautilus[3164]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc localsearch-3[2907]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc nautilus[3164]: Owner of volume monitor org.gtk.vfs.GPhoto2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc nautilus[3164]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc localsearch-3[2907]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc localsearch-3[2907]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:23:27 desktop-pc nautilus[3164]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
apr 19 21:22:55 desktop-pc sudo[4133]:   second : user NOT in sudoers ; TTY=pts/0 ; PWD=/home/second ; USER=root ; COMMAND=/usr/bin/dmesg
apr 19 21:19:35 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 19 21:19:35 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 19 21:19:35 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 19 21:19:35 desktop-pc kernel: Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
apr 19 21:19:35 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 19 21:19:34 desktop-pc dbus-broker[1031]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.121.
apr 19 21:19:34 desktop-pc kernel: mei_gsc i915.mei-gsc.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
apr 19 21:19:34 desktop-pc kernel: mei_gsc i915.mei-gsc.1792: FW not ready: resetting: dev_state = 2 pxp = 2
apr 19 21:19:34 desktop-pc kernel: mei_gsc i915.mei-gscfi.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
apr 19 21:19:34 desktop-pc kernel: mei_gsc i915.mei-gscfi.1792: FW not ready: resetting: dev_state = 2 pxp = 0
apr 19 21:19:34 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 19 21:14:53 desktop-pc kernel: Bluetooth: hci0: HCI Set Event Filter command not supported.
apr 19 21:14:53 desktop-pc kernel: Bluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported.
apr 19 21:14:53 desktop-pc kernel: Bluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported.
apr 19 21:14:53 desktop-pc kernel: Bluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround
apr 19 21:14:53 desktop-pc kernel: Bluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once...
apr 19 21:14:53 desktop-pc dbus-broker[1031]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.121.
apr 19 21:14:53 desktop-pc kernel: mei_gsc i915.mei-gsc.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
apr 19 21:14:53 desktop-pc kernel: mei_gsc i915.mei-gsc.1792: FW not ready: resetting: dev_state = 2 pxp = 2
apr 19 21:14:53 desktop-pc kernel: mei_gsc i915.mei-gscfi.1792: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
apr 19 21:14:53 desktop-pc kernel: mei_gsc i915.mei-gscfi.1792: FW not ready: resetting: dev_state = 2 pxp = 0
apr 19 21:14:53 desktop-pc kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
apr 19 21:13:03 desktop-pc gnome-shell[1831]: Type gint32 of property AccountsService.User::password-mode does not match return type interface of getter get_password_mode. Falling back to slow path
apr 19 21:10:31 desktop-pc gsd-media-keys[1955]: Unable to get default sink
apr 19 21:10:30 desktop-pc /usr/lib/gdm-wayland-session[1712]: discover_other_daemon: 1
apr 19 21:10:30 desktop-pc gsd-xsettings[2348]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
apr 19 21:10:30 desktop-pc gsd-media-keys[1955]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 19 21:10:30 desktop-pc gsd-media-keys[1955]: Failed to grab accelerator for keybinding settings:hibernate
apr 19 21:10:30 desktop-pc gsd-color[1943]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 19 21:10:30 desktop-pc gsd-usb-protect[2020]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 19 21:10:30 desktop-pc systemd[1739]: Failed to start Application launched by gnome-session-binary.
apr 19 21:10:30 desktop-pc systemd[1739]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-2058.scope: Failed with result 'resources'.
apr 19 21:10:30 desktop-pc systemd[1739]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-2058.scope: No PIDs left to attach to the scope's control group, refusing.
apr 19 21:10:30 desktop-pc gnome-session-binary[1813]: GnomeDesktop-WARNING: Could not create transient scope for PID 2069: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
apr 19 21:10:30 desktop-pc gnome-session-binary[1813]: GnomeDesktop-WARNING: Could not create transient scope for PID 1957: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
apr 19 21:10:29 desktop-pc systemd[1739]: Dependency failed for GNOME XSettings service.
apr 19 21:10:29 desktop-pc gnome-keyring-daemon[1829]: discover_other_daemon: 1
apr 19 21:10:29 desktop-pc systemd[1739]: Failed to start Application launched by gnome-session-binary.
apr 19 21:10:29 desktop-pc systemd[1739]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1820.scope: Failed with result 'resources'.
apr 19 21:10:29 desktop-pc systemd[1739]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1820.scope: No PIDs left to attach to the scope's control group, refusing.
apr 19 21:10:29 desktop-pc gnome-keyring-daemon[1827]: discover_other_daemon: 1
apr 19 21:10:29 desktop-pc gnome-session-binary[1813]: WARNING: Desktop file /home/second/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
apr 19 21:10:29 desktop-pc gsd-media-keys[1342]: Unable to get default source
apr 19 21:10:29 desktop-pc gsd-media-keys[1342]: Unable to get default sink
apr 19 21:10:28 desktop-pc gdm-password][1727]: gkr-pam: unable to locate daemon control file
apr 19 21:10:20 desktop-pc gnome-keyring-daemon[1712]: discover_other_daemon: 1
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1712]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.46' (uid=120 pid=1637 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
apr 19 21:10:20 desktop-pc xdg-desktop-por[1702]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc xdg-desktop-por[1702]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc xdg-desktop-por[1702]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.46' (uid=120 pid=1637 comm="/usr/lib/xdg-desktop-portal")
apr 19 21:10:20 desktop-pc xdg-desktop-por[1637]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc xdg-desktop-por[1637]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc xdg-desktop-por[1637]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 19 21:10:20 desktop-pc gsd-sharing[1287]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=1287 comm="/usr/lib/gsd-sharing")
apr 19 21:10:20 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
apr 19 21:10:20 desktop-pc dbus-broker-launch[1030]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
apr 19 21:10:20 desktop-pc gsd-media-keys[1342]: Unable to get default sink
apr 19 21:10:19 desktop-pc /usr/lib/gdm-wayland-session[1156]: dbus-daemon[1156]: [session uid=120 pid=1156 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
Like you said: I could be a bug in the Intel Arc GPU drivers in combiation with the kernel.
But in Ubuntu 24.04 LTS with Gnome (running on the same hardware) there was no issue related to suspend and waking up. Maybe because an older kernel version?
Probably this module makes trouble? It is the “Intel(R) Management Engine Interface”.
echo "blacklist mei" | sudo tee /etc/modprobe.d/blacklist-mei.conf
echo "blacklist mei_gsc" | sudo tee /etc/modprobe.d/blacklist-mei.conf
echo "blacklist mei_me" | sudo tee /etc/modprobe.d/blacklist-mei.conf
sudo mkinitcpio -P
reboot
A complex situation. Your suggestion does not seem to make a difference. But i did keep it enabled on all other tests.
I’ve tried a lot of things these days, have so many logs of crashes. But i did see this error often in the logs:
gnome-shell cogl_framebuffer_set_viewport: assertion ‘width > 0 && height > 0’ failed
I made a script to first lock the screen and then suspend, because that was working for me (instead of suspending it directly from the menu):
loginctl lock-session
sleep 3
systemctl suspend
give it execute permissions and run it as root:
chmod +x lock_suspend.sh
sudo ./lock_suspend.sh
Or place suspend in sudo visudo to allow it to run by any user:
user ALL=(ALL) NOPASSWD: /bin/systemctl suspend
After more testing the shell crashes now after every lockscreen operation when at least 1 or more gnome extensions were enabled. That’s a bad thing and it did not do that before…
Then i noticed that the shell only crashed when i run the script, not when actually pressing the hotkeys: Super + L (is that weird?)
But when running the tests on a new user, there was no crash at all!
So on the current user i did: (reset shell config and reinstall gnome-shell and gdm packages)
dconf reset -f /org/gnome/shell/
sudo pacman -S gmd
sudo pacman -S gnome-shell
logout
Unfortunately with no improvements…
One of the many journalctl logs:
apr 23 03:43:32 desktop-pc gnome-shell[65764]: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: Set global engine failed: Operation was cancelled
                                               Stack trace:
                                                 _promisify/proto[asyncFunc]/</<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:453:45
                                                 ### Promise created here: ###
                                                 _setEngine@resource:///org/gnome/shell/misc/ibusManager.js:286:30
                                                 setEngine@resource:///org/gnome/shell/misc/ibusManager.js:299:24
                                                 activateInputSource@resource:///org/gnome/shell/ui/status/keyboard.js:525:27
                                                 _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
                                                 _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
                                                 activate@resource:///org/gnome/shell/ui/status/keyboard.js:66:14
                                                 _inputSourcesChanged@resource:///org/gnome/shell/ui/status/keyboard.js:663:33
                                                 reload@resource:///org/gnome/shell/ui/status/keyboard.js:396:14
                                                 _ibusSetContentType@resource:///org/gnome/shell/ui/status/keyboard.js:738:14
                                                 _setContentType@resource:///org/gnome/shell/misc/ibusManager.js:264:14
apr 23 03:43:18 desktop-pc gsd-media-keys[65881]: Unable to get default sink
apr 23 03:43:18 desktop-pc gnome-shell[65764]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 23 03:43:18 desktop-pc gnome-shell[65764]: Type gint32 of property AccountsService.User::password-mode does not match return type interface of getter get_password_mode. Falling back to slow path
apr 23 03:43:16 desktop-pc gnome-shell[65764]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 23 03:43:14 desktop-pc gnome-shell[65764]: cogl_framebuffer_set_viewport: assertion 'width > 0 && height > 0' failed
apr 23 03:42:34 desktop-pc /usr/lib/gdm-wayland-session[65678]: discover_other_daemon: 1
apr 23 03:42:34 desktop-pc xdg-document-po[65629]: Error releasing name org.freedesktop.portal.Documents: The connection is closed
apr 23 03:42:34 desktop-pc gnome-shell[65236]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
apr 23 03:42:34 desktop-pc gnome-shell[65236]: Xwayland terminated, exiting since it was mandatory
apr 23 03:42:34 desktop-pc gnome-shell[65236]: Connection to xwayland lost
apr 23 03:42:34 desktop-pc gsd-xsettings[66255]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
apr 23 03:42:34 desktop-pc gsd-media-keys[65881]: Failed to grab accelerator for keybinding settings:hibernate
apr 23 03:42:34 desktop-pc gsd-media-keys[65881]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 23 03:42:34 desktop-pc gsd-color[65858]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 23 03:42:34 desktop-pc gsd-usb-protect[65921]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 23 03:42:33 desktop-pc systemd[3687]: Failed to start Application launched by gnome-session-binary.
apr 23 03:42:33 desktop-pc systemd[3687]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-65971.scope: Failed with result 'resources'.
apr 23 03:42:33 desktop-pc systemd[3687]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-65971.scope: No PIDs left to attach to the scope's control group, refusing.
apr 23 03:42:33 desktop-pc gnome-session-binary[65746]: GnomeDesktop-WARNING: Could not create transient scope for PID 65991: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
apr 23 03:42:33 desktop-pc gnome-session-binary[65746]: GnomeDesktop-WARNING: Could not create transient scope for PID 65882: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
apr 23 03:42:33 desktop-pc systemd[3687]: Dependency failed for GNOME XSettings service.
apr 23 03:42:33 desktop-pc gnome-keyring-daemon[65762]: discover_other_daemon: 1
apr 23 03:42:33 desktop-pc systemd[3687]: app-gnome-gnome\x2dkeyring\x2dpkcs11-65753.scope: Failed with result 'resources'.
apr 23 03:42:33 desktop-pc systemd[3687]: app-gnome-gnome\x2dkeyring\x2dpkcs11-65753.scope: No PIDs left to attach to the scope's control group, refusing.
apr 23 03:42:33 desktop-pc gnome-keyring-daemon[65760]: discover_other_daemon: 1
apr 23 03:42:33 desktop-pc gnome-session-binary[65746]: WARNING: Desktop file /home/user-x/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
apr 23 03:42:33 desktop-pc wireplumber[9464]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
apr 23 03:42:33 desktop-pc gsd-media-keys[65378]: Unable to get default sink
apr 23 03:42:33 desktop-pc gsd-media-keys[65378]: Unable to get default source
apr 23 03:42:32 desktop-pc gdm-password][65683]: gkr-pam: unable to locate daemon control file
apr 23 03:42:27 desktop-pc gnome-keyring-daemon[65678]: discover_other_daemon: 1
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65678]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.45' (uid=120 pid=65620 comm="/usr/lib/xdg-desktop-portal")
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
apr 23 03:42:27 desktop-pc xdg-desktop-por[65669]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65669]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65669]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.45' (uid=120 pid=65620 comm="/usr/lib/xdg-desktop-portal")
apr 23 03:42:27 desktop-pc xdg-desktop-por[65620]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65620]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65620]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
apr 23 03:42:27 desktop-pc gnome-control-c[65659]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc gnome-control-c[65659]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc gnome-control-c[65659]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.48' (uid=120 pid=65644 comm="/usr/lib/xdg-desktop-portal-gnome")
apr 23 03:42:27 desktop-pc xdg-desktop-por[65644]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65644]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc xdg-desktop-por[65644]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.45' (uid=120 pid=65620 comm="/usr/lib/xdg-desktop-portal")
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.45' (uid=120 pid=65620 comm="/usr/lib/xdg-desktop-portal")
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.44' (uid=120 pid=65555 comm="/usr/lib/mutter-x11-frames")
apr 23 03:42:27 desktop-pc gsd-media-keys[65378]: Failed to grab accelerator for keybinding settings:playback-repeat
apr 23 03:42:27 desktop-pc gsd-media-keys[65378]: Failed to grab accelerator for keybinding settings:hibernate
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
apr 23 03:42:27 desktop-pc gsd-xsettings[65404]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc gsd-xsettings[65404]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc gsd-xsettings[65404]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:27 desktop-pc geoclue[65546]: Failed to connect to avahi service: Daemon not running
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 23 03:42:27 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=65556 comm="ibus-daemon --panel disable -r --xim")
apr 23 03:42:26 desktop-pc gsd-color[65335]: gtk_main_quit: assertion 'main_loops != NULL' failed
apr 23 03:42:26 desktop-pc gsd-usb-protect[65332]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.23' (uid=120 pid=65416 comm="/usr/lib/gsd-housekeeping")
apr 23 03:42:26 desktop-pc gsd-housekeepin[65416]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-housekeepin[65416]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-housekeepin[65416]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sharing[65320]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
apr 23 03:42:26 desktop-pc gsd-power[65417]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-power[65417]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-power[65417]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
apr 23 03:42:26 desktop-pc gsd-a11y-settin[65399]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-a11y-settin[65399]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-a11y-settin[65399]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-media-keys[65378]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-media-keys[65378]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-media-keys[65378]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.24' (uid=120 pid=65363 comm="ibus-daemon --panel disable")
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=65320 comm="/usr/lib/gsd-sharing")
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
apr 23 03:42:26 desktop-pc gjs[65290]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gjs[65290]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gjs[65290]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.9' (uid=120 pid=65332 comm="/usr/lib/gsd-usb-protection")
apr 23 03:42:26 desktop-pc gsd-datetime[65374]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-datetime[65374]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-datetime[65374]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-smartcard[65360]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-smartcard[65360]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-smartcard[65360]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sound[65394]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sound[65394]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sound[65394]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-usb-protect[65332]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-usb-protect[65332]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-usb-protect[65332]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-wacom[65366]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-wacom[65366]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-wacom[65366]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-color[65335]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-color[65335]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-color[65335]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-keyboard[65338]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-keyboard[65338]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-keyboard[65338]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sharing[65320]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sharing[65320]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsd-sharing[65320]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc wireplumber[64225]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
apr 23 03:42:26 desktop-pc gnome-shell[65236]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10605dc4a841b17bc7174537254622908000000652240000.ms”: No such file or directory
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=65236 comm="/usr/bin/gnome-shell")
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=65236 comm="/usr/bin/gnome-shell")
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=65236 comm="/usr/bin/gnome-shell")
apr 23 03:42:26 desktop-pc wireplumber[9464]: s-monitors: Failed to create alsa_output.pci-0000_0a_00.4.analog-stereo: Object activation aborted: PipeWire proxy destroyed
apr 23 03:42:26 desktop-pc pipewire[9463]: mod.adapter: 0x61df8d90b430: can't get format: Device or resource busy
apr 23 03:42:26 desktop-pc pipewire[9463]: spa.alsa: 'front:1': playback open failed: Device or resource busy
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65282]: dbus-daemon[65282]: Successfully activated service 'org.a11y.atspi.Registry'
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65282]: dbus-daemon[65282]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=65236 comm="/usr/bin/gnome-shell")
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Successfully activated service 'org.a11y.Bus'
apr 23 03:42:26 desktop-pc at-spi-bus-laun[65276]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc at-spi-bus-laun[65276]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc at-spi-bus-laun[65276]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=65236 comm="/usr/bin/gnome-shell")
apr 23 03:42:26 desktop-pc gnome-shell[65236]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gnome-shell[65236]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gnome-shell[65236]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gnome-session-binary[65224]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
apr 23 03:42:26 desktop-pc gnome-session-binary[65224]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
apr 23 03:42:26 desktop-pc /usr/lib/gdm-wayland-session[65223]: dbus-daemon[65223]: [session uid=120 pid=65223 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=65224 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
apr 23 03:42:26 desktop-pc gnome-session-b[65224]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gnome-session-b[65224]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gnome-session-b[65224]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsettings[65225]: unable to open file '/etc/dconf/db/distro': Failed to map /etc/dconf/db/distro' /etc/dconf/db/distro': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsettings[65225]: unable to open file '/etc/dconf/db/site': Failed to map /etc/dconf/db/site' /etc/dconf/db/site': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:26 desktop-pc gsettings[65225]: unable to open file '/etc/dconf/db/gdm': Failed to map /etc/dconf/db/gdm' /etc/dconf/db/gdm': mmap() failed: Invalid argument; expect degraded performance
apr 23 03:42:25 desktop-pc systemd[3687]: dbus-:1.3-org.gnome.Settings.GlobalShortcutsProvider@0.service: Failed with result 'exit-code'.
Setting this variable seems to give better results for me:
export MUTTER_DEBUG_KMS_THREAD_TYPE=user
Or adding it to the environment for all users:
sudo nano /etc/environment
Since my last forum post, I haven’t experienced any more crashes with the GNOME Shell. It’s difficult to pinpoint exactly what resolved the issue, but it seems to be a combination of the following actions (as mentioned in my previous post):
  • Executing echo “blacklist mei” (etc…)
  • Running: dconf reset -f /org/gnome/shell/
  • Setting: export MUTTER_DEBUG_KMS_THREAD_TYPE=user
  • Adding a new user
  • Or temporarily disabling GNOME extensions (for testing)
Additionally, both the suspend button in GNOME and the sequence of locking the screen followed by suspend are now functioning properly. The bash script I previously needed is no longer necessary.
Thank you for your time to help debugging the problem.
I am glad that there is always a support forum with the knowledge and expertise to rely on.
Also happy that GNOME 48 runs smooth on Wayland with my Intel Arc A380
