Waking from sleep hangs linux
This started with the most recent update, about 3-4 days ago. Running release Manjaro on a Lenova Legion 5 with an LG 32 hdmi external monitor. This combo had been working well up until the time of this upgrade. Symptoms are:
Combo boots ok, however once it goes to sleep upon trying to wake up it restores the built in screen but then hangs before the hdmi screen comes up. Animation stops on windows on the built in screen and mouse is dead. Only a hard reboot seems to fix it.
In experimenting I found that, if I boot without the hdmi and then plug in the hdmi monitor linux will similarly hang.
Also tried using a smaller hdmi monitor (lower res) and that seems to be OK; no problems.
So judging from these first pass findings, it seems that the new update is having issues with higher res hdmi monitors and initializing the nvidia graphics for them when they are plugged in or in waking from sleep.
Wanted to report this. And if anyone knows of a work around that would be great.
As a relatively new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
inxi --filter --verbosity=8
inxi -zv8
OK. I have pasted the output of the inxi -zv8 command below. Note this was run with a working monitor (the smaller LG one described below) as when the problem exists the system hangs. I admittedly don’t know that much about linux, so there might be some useful logs of the crash somewhere, which I can send; if someone can point me to the files of interest.
I did do some more investigating. I found no sleep-wake issues with a smaller LG monitor, which has lower res than the big one. Tried config’ing the big one for the lower res, and it would get further when waking but still hung. From the outside it appears to be hanging during the HW config of the hdmi monitor.
Here is the cut and paste of the inxi cmd.
sudo inxi -zv8
[sudo] password for steve2:
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=e1988331-6b85-48e6-8160-a806f025d022 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
    serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
    serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
    part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5 15ARH05
    uuid: 410e8c23-4367-11eb-80ea-8c8caa5c58dc Firmware: UEFI vendor: LENOVO
    v: EUCN41WW date: 09/20/2023
  ID-1: BAT0 charge: 55.4 Wh (100%) condition: 55.4/60 Wh (92.3%) volts: 17.13
    min: 15.44 model: SMP L19M4PC0 type: Li-poly serial: <filter> charging:
    status: full cycles: 46
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    status: discharging
  System RAM: total: 16 GiB available: 15 GiB used: 2.71 GiB (18.1%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1K43DB1-CWE serial: <filter>
  Slot: 1 type: PCIe status: available info: J10 length: short volts: 3.3
    bus-ID: 0200:00:01.1
  Slot: 2 type: PCIe status: available info: J79 length: short volts: 3.3
    bus-ID: 0200:00:01.6
  Slot: N/A type: N/A status: available info: M.2, J92 length: short
    volts: 3.3 bus-ID: 0200:00:01.2
  Slot: N/A type: N/A status: available info: M.2, J90 length: short
    volts: 3.3 bus-ID: 0200:00:01.4
  Slot: N/A type: N/A status: available info: M.2, J19 length: short
    volts: 3.3 bus-ID: 0200:00:01.7
  Slot: 6 type: PCIe status: available length: short volts: 3.3
    bus-ID: 0200:00:01.5
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/3000 boost: enabled
    base/boost: 3000/4000 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
    5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    bogomips: 71898
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nouveau v: kernel non-free: 550-580.xx+ status: current (as of
    2025-11; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,eDP-1
    bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none off: eDP-2 empty: none bus-ID: 05:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 36.0 C
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 174f:244c
  Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: radeonsi,zink gpu: amdgpu,nouveau
    display-ID: :1 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: LG (GoldStar) FULL HD built: 2016
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.306 y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: eDP-2 model: AU Optronics 0xd1ed built: 2019 res: 1920x1080
    dpi: 142 gamma: 1.2 chroma: red: x: 0.561 y: 0.341 green: x: 0.349 y: 0.573
    blue: x: 0.161 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
    device: 1 drv: zink device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    renoir ACO DRM 3.61 6.12.61-1-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:1636 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 (NVK TU117) driver: mesa nvk
    v: 25.3.1-arch1.2 device-ID: 10de:1f99 surfaces: N/A
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:4 chip-ID: 8087:0029
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
  Local Storage: total: 238.47 GiB used: 24.08 GiB (10.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFS256GD9TNI-L2A0B size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 11010C10 temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 96.18 GiB size: 96.18 GiB (100.00%)
    used: 24.03 GiB (25.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
    maj-min: 259:6 label: N/A uuid: e1988331-6b85-48e6-8160-a806f025d022
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 48.3 MiB (18.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: SYSTEM_DRV uuid: 3698-2169
  ID-3: /home raw-size: 96.18 GiB size: 96.18 GiB (100.00%)
  ID-4: /var/cache raw-size: 96.18 GiB size: 96.18 GiB (100.00%)
  ID-5: /var/log raw-size: 96.18 GiB size: 96.18 GiB (100.00%)
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 139.57 GiB fs: ntfs
    label: Windows-SSD uuid: 5E4298AE42988C81
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 488 MiB fs: vfat label: N/A
    uuid: 2B41-16BD
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: BA7E99697E991F67
  Device-1: 1-3:2 info: Syntek Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:244c class-ID: 0e02
    serial: <filter>
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
  Device-1: 3-2:3 info: Logitech Nano Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-2: 3-3:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-3: 3-4:5 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  System Temperatures: cpu: 51.9 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1311 libs: 359 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
  CPU top: 5 of 344
  1: cpu: 9.7% command: firefox pid: 1695 mem: 528.2 MiB (3.4%)
  2: cpu: 6.2% command: kwin_wayland pid: 943 mem: 209.0 MiB (1.3%)
  3: cpu: 4.3% command: [kworker/u50:8-btrfs-endio] pid: 3240
    mem: 0.00 MiB (0.0%)
  4: cpu: 4.2% command: firefox pid: 2601 mem: 375.0 MiB (2.4%)
  5: cpu: 4.1% command: [kworker/u50:9-btrfs-compressed-write] pid: 3802
  Memory top: 5 of 344
  1: mem: 528.2 MiB (3.4%) command: firefox pid: 1695 cpu: 9.7%
  2: mem: 438.7 MiB (2.8%) command: plasmashell pid: 1224 cpu: 0.2%
  3: mem: 375.0 MiB (2.4%) command: firefox pid: 2601 cpu: 4.2%
  4: mem: 251.4 MiB (1.6%) command: firefox pid: 2098 cpu: 2.4%
  5: mem: 240.0 MiB (1.5%) command: konsole pid: 4060 cpu: 1.3%
  Processes: 344 Power: uptime: 35m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 5.96 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Bash v: 5.3.8 running-in: konsole inxi: 3.3.40
Mod edit: changed output to preformatted text
