Hello everyone,
I am trying to set up wake on lan on my vaio laptop following the Archlinux guide https://wiki.archlinux.org/index.php/Wake-on-LAN but I have not had any success, even after trying the troubleshooting sections regarding realtek ethernet cards. Using ethtool I have verified that the wake on lan with a magic word setting persists after each boot. I know is possible to wake on lan with the laptop’s hardware configuration because I have managed to do it with Windows OS, now I have deleted Windows and only have Manjaro but I have not managed to get it working. the output of ethtool enp14s0 is:
Settings for enp14s0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Half 1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: g
Link detected: yes
The output of inxi -Fazy is:
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=cf6a9828-1609-4ace-96c2-328ade52d34b rw quiet
resume=UUID=259bd480-9c31-45c7-9bc7-ac83b8f3bf15 udev.log_priority=3
r8169.s5wol=1 iommu=soft
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Sony product: SVF1521N6EW v: C10J2KDE serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Sony model: VAIO serial: <filter> UEFI: Insyde v: R0250DA
date: 07/19/2016
Info: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 14373
Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 854 2: 830
3: 1064 4: 1223
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Sony driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Sony driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1292
Device-3: Chicony type: USB driver: uvcvideo bus ID: 2-1.3:4
chip ID: 04f2:b3aa serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n vendor: Foxconn
driver: wl v: kernel port: 3000 bus ID: 07:00.0 chip ID: 14e4:4365
IF: wlp7s0 state: dormant mac: <filter>
vendor: Sony driver: r8169 v: kernel modules: r8168 port: 2000
bus ID: 0e:00.0 chip ID: 10ec:8168
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 698.64 GiB used: 7.46 GiB (1.1%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD075 size: 698.64 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 5H scheme: GPT
ID-1: / raw size: 689.54 GiB size: 677.72 GiB (98.29%) used: 7.46 GiB (1.1%)
fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 44.0 C
Processes: 171 Uptime: 8m Memory: 5.69 GiB used: 1.06 GiB (18.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1030 lib: 293
Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
Thank you very much!
