Whenever my screen locks/turns off or the entire system goes to sleep the power manager service seems to crash. I also have an issue with artifacting on my second screen. It appears to be random color blocking where a section horizontally across the screen is mostly white with some random colors, this flickers mostly randomly, but is more consistent when I move windows around. These don’t always happen, but the power service crashing is more common with the artifacting only happening if the power service crashed. The artifacting has been an issue for as long as I have had the AMD GPU, but it was quite new at the time so I figured it would be resolved at some point through natural updates while the power management issue has been persistent since KDE 6 IIRC.
Both issues are solved by a restart, however I have found that I can fix the power manager service by running:
systemctl restart --user plasma-powerdevil.service
I have only really found
https://wiki.archlinux.org/title/AMDGPU#Screen_artifacts_and_frequency_problem
regarding the artifacting, but I am using a kernel version higher than the one listed and the problem persists.
inxi -Farz ✔
Kernel: 6.14.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=3e6e4c0f-26d2-4b14-af4a-9bee693e02f7 rw quiet splash
udev.log_priority=3 amdgpu.dcdebugmask=0x10
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0
wm: kwin_wayland vt: 3 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: H.H0 date: 05/19/2022
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3537 min/max: 550/5321 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3537 2: 3537 3: 3537
4: 3537 5: 3537 6: 3537 7: 3537 8: 3537 9: 3537 10: 3537 11: 3537 12: 3537
13: 3537 14: 3537 15: 3537 16: 3537 bogomips: 127206
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: HDMI-A-1,HDMI-A-2,Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:744c
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 6400x2160 display-ID: 0
Monitor-1: DP-1 pos: right model: LG (GoldStar) Ultra HD serial: <filter>
built: 2017 res: mode: 3840x2160 hz: 60 scale: 150% (1.5) to: 2560x1440
dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39") diag: 690mm (27.2")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-2 pos: primary,left model: LG (GoldStar) HDR QHD
serial: <filter> built: 2019 res: mode: 2560x1440 hz: 144 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
navi31 LLVM 19.1.7 DRM 3.61 6.14.6-2-MANJARO) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 25.0.5-arch1.1
device-ID: 1002:744c surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: lact,radeontop wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
vendor: Micro-Star MSI X570-A PRO driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Samson Q2U handheld mic with XLR
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-3:2 chip-ID: 17a0:0304 class-ID: 0300
API: ALSA v: k6.14.6-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.2 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 610.41 GiB (32.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 41.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 3B2QEXM7 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 610.41 GiB (66.7%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 40.0 C mobo: 43.0 C gpu: amdgpu temp: 62.0 C
mem: 68.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 700 fan-3: 0 fan-4: 623 fan-5: 953
fan-6: 809 fan-7: 702 gpu: amdgpu fan: 150
Packages: 1669 pm: dpkg pkgs: 0 pm: pacman pkgs: 1651 libs: 464
tools: pamac,yay pm: flatpak pkgs: 18
1: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
2: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
4: http://manjaro.grena.ge/stable/$repo/$arch
5: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
6: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
7: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
8: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
9: https://mirror.easyname.at/manjaro/stable/$repo/$arch
10: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
11: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
12: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
13: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
14: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
15: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
16: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
17: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
18: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
19: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
20: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
21: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
22: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
26: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
27: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
28: https://manjaro.kurdy.org/stable/$repo/$arch
29: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
30: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
31: https://manjaro.ynh.ovh/stable/$repo/$arch
32: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
33: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
35: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
36: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
37: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
38: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
39: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
40: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
41: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
42: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
43: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
44: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
45: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
46: https://mirrors.manjaro.org/repo/stable/$repo/$arch
47: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
48: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
49: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
50: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
51: https://linorg.usp.br/manjaro/stable/$repo/$arch
52: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
53: https://mirror.23m.com/manjaro/stable/$repo/$arch
54: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
55: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
56: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
57: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
58: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
59: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
60: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
61: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
62: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
63: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
64: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
65: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
66: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
67: http://mirror.fcix.net/manjaro/stable/$repo/$arch
68: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
69: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
70: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
71: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
72: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
73: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
74: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
75: https://muug.ca/mirror/manjaro/stable/$repo/$arch
76: https://mirror.koddos.net/manjaro/stable/$repo/$arch
77: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
78: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
79: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://mirrors2.manjaro.org/stable/$repo/$arch
81: https://mirror.dc.uz/manjaro/stable/$repo/$arch
82: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
83: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
85: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
86: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
87: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
88: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
89: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
90: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
91: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
92: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
93: https://mirror.init7.net/manjaro/stable/$repo/$arch
94: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
95: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
96: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
98: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
99: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
100: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Memory: total: 32 GiB available: 31.26 GiB used: 9.77 GiB (31.2%)
Processes: 385 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.38
