Hi, I recently installed Manjaro Plasma. I am pretty new to Manjaro and Linux in general.
The installation process went very smooth, everything runs good.
My Setup
I just bought a second SSD to install Manjaro as a new main OS on.
Before installing Manjaro on a separate drive i had Windows and Manjaro on one drive. I´ve deleted the Manjaro partition expanded the Windows partition again, and finally reinstalled Manjaro on the new second drive. Windows and Manjaro run as expected in dual boot again.
The laptop is connected via USB-C to a Monitor with a built in usb hub, power source and ethernet connection.
But here comes my problem
Every time i try to wake my Laptop, it takes a rather long time until it reaches the login screen.
What i have noticed while it tries to wake up
- the time it takes to wake up seems to be always the same
- during the time it tries to wake up the backlight is on
- pressing the shift lock or the num lock keys does not light up the corresponding LEDs
- there is no cursor visible
- this behavior does not change if i unplug it from the Monitor/Hub or try it in battery mode
This is my inxi
output:
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=94386a3d-3405-4309-b7cf-160c3983f4b3 rw quiet splash
resume=UUID=a79fca53-5faf-498d-bad0-1b0927fd3336 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 82A2 v: Yoga Slim 7 14ARE05
serial: <filter> Chassis: type: 10 v: Yoga Slim 7 14ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
part-nu: LENOVO_MT_82A2_BU_idea_FM_Yoga Slim 7 14ARE05
uuid: 573f8a96-8cb3-5b94-ec2a-4e6f74207965 UEFI: LENOVO v: DMCN32WW
date: 07/14/2020
ID-1: BAT1 charge: 50.6 Wh (100.0%) condition: 50.6/60.7 Wh (83.4%)
volts: 17.2 min: 15.4 model: Celxpert L19C4PF4 type: Li-poly serial: <filter>
status: full cycles: 266
Info: model: AMD Ryzen 7 4700U with Radeon Graphics socket: FP6 bits: 64
type: MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1625 high: 2000 min/max: 1400/2000 boost: enabled
base/boost: 2000/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 2000 3: 1400 4: 1400
5: 1400 6: 2000 7: 2000 8: 1400 bogomips: 31958
Type: spec_rstack_overflow mitigation: SMT disabled
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-2,eDP-1 off: DP-3
empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 55.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04f2:b6cb
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:7
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 5120x1800 s-dpi: 96 s-size: 1354x476mm (53.31x18.74")
s-diag: 1435mm (56.51")
Monitor-1: DP-2 pos: primary,top-left res: 3200x1800 hz: 60 dpi: 135
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: eDP-1 pos: bottom-r res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.69") diag: 354mm (13.92") modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.54 6.6.19-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Device-4: GYROCOM C&C Fiio E10 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2:5
chip-ID: 1852:7022 class-ID: 0102
Device-5: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
Device-6: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4:8
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1.3:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0f4u1u1u3 state: up speed: 100 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:10 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 953.88 GiB used: 29.48 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital model: PC SN730
SDBPNTY-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11130001 temp: 45.9 C scheme: GPT
SMART: yes health: PASSED on: 28d 16h cycles: 58,113
read-units: 29,006,304 [14.8 TB] written-units: 21,340,172 [10.9 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 model: INSSD512GM2242G3 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: H230606a temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 9 hrs cycles: 17 read-units: 22,161 [11.3 GB]
written-units: 107,678 [55.1 GB]
ID-1: / raw-size: 460.16 GiB size: 451.87 GiB (98.20%) used: 29.48 GiB (6.5%)
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:3
used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:2
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:4
System Temperatures: cpu: 73.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 14.98 GiB used: 6.96 GiB (46.4%)
Processes: 320 Power: uptime: 1h 19m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1228 libs: 386 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
i have also found this in another post (maybe it helps)
this was just after logging in
journalctl -p 3 -xb
Mär 18 22:26:09 pova kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20230628/dswload2-162)
Mär 18 22:26:09 pova kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
Mär 18 22:26:09 pova kernel: hid-generic 0003:0D8C:0005.0004: No inputs registered, leaving
Mär 18 22:26:09 pova kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
Mär 18 22:26:09 pova kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Mär 18 22:26:10 pova kernel: gspca_vc032x: reg_r err -32
Mär 18 22:26:10 pova kernel: Bluetooth: hci0: FW download error recovery failed (-19)
Mär 18 22:26:10 pova kernel: Bluetooth: hci0: sending frame failed (-19)
Mär 18 22:26:10 pova kernel: Bluetooth: hci0: Reading supported features failed (-19)
Mär 18 22:26:10 pova kernel: Bluetooth: hci0: Failed to read MSFT supported features (-19)
Mär 18 22:26:13 pova kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Mär 18 22:26:13 pova bluetoothd[532]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Mär 18 22:26:16 pova kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Mär 18 22:26:50 pova pipewire[1055]: spa.alsa: set_hw_params: No space left on device
Mär 18 22:26:50 pova pipewire[1055]: pw.node: (alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo-41) suspended -> error (Start error: No space left on device)
Mär 18 22:26:50 pova kernel: usb 3-1.2: 3:2: usb_set_interface failed (-28)
Mär 18 22:26:50 pova pipewire[1055]: pw.node: (alsa_output.usb-FiiO_DigiHug_USB_Audio-01.analog-stereo-41) idle -> error ((null))
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 41s! [swapper/7:0]
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#5 stuck for 41s! [kworker/u34:3:102]
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 41s! [swapper/4:0]
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 41s! [swapper/3:0]
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 41s! [swapper/2:0]
Mär 18 22:32:39 pova kernel: watchdog: BUG: soft lockup - CPU#1 stuck for 41s! [swapper/1:0]
Maybe a graphics driver problem?
I have read something about a BIOS version problem. But i think under windows it did automatically updated its BIOS.
What should I do now?
I am looking forward to any suggestions.
