Wacom problem after updates
After the two latest major updates my Wacom pen has not been working well with Gnome. I hoped that the second update would fix it. In Xorg sessions the cursor will not let go of the window, if I’m trying to move it. The Xorg session also crashes in a few minutes with the white “Oh no … you have to log out” screen. It doesn’t seem to have anything to do with the Wacom pen, as it also does so when only a mouse is connected.
So I have been forced to use Wayland. It works so and so. Drag and drop does not work for most applications, for instance Nautilus and Librewriter. But it does work for Freeoffice Textmaker. In Nautilus, when I click on an icon in the main window, I do get the rolldown menu, but if I click on a folder in the sidepanel the rolldown menu does not show. I have to use Ctrl+N to create a new window. If a new windows opens inside a program, the whole window freezes and I have to click outside of it on the desktop or another program to make it unfreeze. It is a lot of back and forth.
If I open Nautilus and Librewriter in a sudo session, drag and drop works. But if I log in as root in a session, drag and drop does not work.
I have a laptop that works fine, also with Manjaro. But as soon as I attach my Wacom pen to it, it also starts to behave like described above.
I have tried EndeavourOs, Fedora and Ubuntu, but they have the same issues. I have also tried Manjaro KDE on at USB stick and it seems to work with the Wacom pen without any problems. So it is probably a Gnome issue. Mutter-related?
As far as I can see I have installed all the Wacom pen related packages.
Here are some data:
inxi --admin --verbosity=7 --filter --no-host --width            ✔
  Kernel: 6.6.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=88fba7ef-c6d1-41dd-ad85-92de6e8e88f7 rw quiet splash apparmor=1
  Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
  Mobo: ASUSTeK model: PRIME H410M-E v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 1401 date: 07/27/2020
  System RAM: total: 16 GiB available: 15.46 GiB used: 3.61 GiB (23.4%)
  Info: model: Intel Core i5-10600K bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF8
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 3125 high: 4805 min/max: 800/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4801 2: 800 3: 4800 4: 800
    5: 4778 6: 800 7: 800 8: 4738 9: 4799 10: 4783 11: 800 12: 4805
    bogomips: 98441
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
    rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: DP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc5
    class-ID: 0300
  Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 046d:0843
    class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: LG (GoldStar) L1715S serial: <filter> built: 2005
    res: 1280x1024 dpi: 96 gamma: 1.2 size: 338x270mm (13.31x10.63")
    diag: 433mm (17") ratio: 5:4 modes: max: 1280x1024 min: 720x400
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CML GT2)
    device-ID: 8086:9bc5 memory: 15.1 GiB unified: yes display-ID: :0.0
  Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:a3f0 class-ID: 0403
  API: ALSA v: k6.6.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: ASUSTeK
    driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14e4:43a0 class-ID: 0280
    vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Local Storage: total: 2.27 TiB used: 1.63 TiB (71.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 33.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EFAX-68FB5N0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A82 scheme: MBR
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 358.95 GiB (78.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 88fba7ef-c6d1-41dd-ad85-92de6e8e88f7
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 55D9-BE44
  ID-3: /mnt/3f54cfa8-c6e8-41c2-b8ef-f1ea5c2b4113 raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 1.28 TiB (71.3%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: 3f54cfa8-c6e8-41c2-b8ef-f1ea5c2b4113
  Device-1: 1-4:2 info: Logitech Webcam C930e type: video,audio
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Device-2: 1-5:3 info: Wacom CTL-490 [Intuos Draw (S)] type: HID,mouse
    driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 498mA chip-ID: 056a:033b class-ID: 0301
  Hub-2: 1-6:4 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
  Device-1: 1-6.4:6 info: Metadot Das Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:204a class-ID: 0300
  Device-2: 1-9:5 info: Logitech M90/M100 Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c05a class-ID: 0301
  Device-3: 1-10:7 info: HP HP OfficeJet Pro 8020 series type: printer
    driver: usblp interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 2mA chip-ID: 03f0:2754 class-ID: 0701 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 31.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 291 Uptime: 2h 7m wakeups: 1 Init: systemd v: 254
  Packages: 1404 pm: pacman pkgs: 1392 libs: 371 tools: gnome-software,pamac
  pm: flatpak pkgs: 12 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.31
Help would be very much appreciated
Mod edit: Add codeblock
