Wacom Intuos Pro not recognized by Kernel
I have been using my Wacom Intuos Pro tablet on a different Arch distro for a few years. Recently installed Manjaro. The tablet connects via bluetooth but is not recognized by the Kernel. Dmesg does not show anything related to the tablet. Neither does xinput. xsetwacom also shows nothing.
I’ve downloaded and installed input-wacom, libwacom, and xf86-input-wacom, with no changes. I’ve rebooted the system a number of times and I’ve made sure all my packages are up to date.
Happy to provide more information.
EDIT: Providing system info:
  Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=742a7514-5662-4d5d-a09d-b42af727d435 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Framework product: Laptop v: AB
    serial: <superuser required>
  Mobo: Framework model: FRANBMCP0B v: AB serial: <superuser required>
    part-nu: FRANBMCP0B uuid: <superuser required> UEFI: INSYDE v: 03.10
    date: 07/19/2022
  ID-1: BAT1 charge: 38.8 Wh (82.5%) condition: 47.1/55 Wh (85.6%) volts: 17.3
    min: 15.4 model: NVT Framewo type: Li-ion serial: <filter> charging:
    status: charging cycles: 192
  System RAM: total: 16 GiB available: 15.41 GiB used: 3.59 GiB (23.3%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Controller0-ChannelA-DIMM0 type: no module installed
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 16 GiB speed: 3200 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: Crucial Technology part-no: CT16G4SFRA32A.M16FR
    serial: <filter>
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 bogomips: 44864
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
    nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
    rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Framework
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Realtek Laptop Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:6 chip-ID: 0bda:5634
  Display: x11 server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2256x1504 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res:
    mode: 2256x1504 hz: 60 scale: 100% (1) dpi: 201 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
    ratio: 3:2 modes: 2256x1504
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 15.05 GiB unified: yes
    x11: xprop,xrandr
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Framework
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp170s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 465.76 GiB used: 63.47 GiB (13.6%)
    model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 111130WD temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 448.3 GiB size: 448.3 GiB (100.00%)
    used: 63.47 GiB (14.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 742a7514-5662-4d5d-a09d-b42af727d435
    used: 768 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: F5A7-B3F8
  ID-3: /home raw-size: 448.3 GiB size: 448.3 GiB (100.00%)
  ID-4: /var/cache raw-size: 448.3 GiB size: 448.3 GiB (100.00%)
  ID-5: /var/log raw-size: 448.3 GiB size: 448.3 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.95 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 197a6174-0815-4b6d-b6c8-f829855c0455
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: Framework HDMI Expansion Card type: billboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 32ac:0002 class-ID: 0300
    serial: <filter>
  Device-2: 3-7:6 info: Realtek Laptop Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 300mA chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
  Device-3: 3-9:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
  Device-4: 3-10:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0032 class-ID: e001
  System Temperatures: cpu: 30.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1361 libs: 380 tools: pamac pm: flatpak pkgs: 0
    1: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    4: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    5: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    6: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    8: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 293
  1: cpu: 22.6% command: firefox pid: 1761 mem: 767.6 MiB (4.8%)
  2: cpu: 6.5% command: firefox pid: 1939 mem: 546.9 MiB (3.4%)
  3: cpu: 4.1% command: firefox pid: 3040 mem: 321.3 MiB (2.0%)
  4: cpu: 4.0% command: localsearch-extractor-3 pid: 3369
    mem: 38.7 MiB (0.2%)
  5: cpu: 3.0% command: firefox pid: 2161 mem: 229.0 MiB (1.4%)
  Memory top: 5 of 293
  1: mem: 767.6 MiB (4.8%) command: firefox pid: 1761 cpu: 22.6%
  2: mem: 546.9 MiB (3.4%) command: firefox pid: 1939 cpu: 6.5%
  3: mem: 433.8 MiB (2.7%) command: krita pid: 1661 cpu: 0.8%
  4: mem: 323.4 MiB (2.0%) command: firefox pid: 2659 cpu: 1.0%
  5: mem: 321.3 MiB (2.0%) command: firefox pid: 3040 cpu: 4.1%
  Processes: 293 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.15 GiB services: upowerd,xfce4-power-manager
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
    inxi: 3.3.39
Did you try an older lts kernel? Like 5.15 for example?
System information is usually expected. Please provide inxi output as described (below) and formatted according to forum guidelines (follow the relevant links, also given below).
I’m sure someone will help when they are able.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
