vulkaninfo ✔
ERROR: [../mesa-22.3.5/src/amd/vulkan/radv_device.c:741] Code 0 : Device '/dev/dri/renderD128' is not using the AMDGPU kernel driver: Invalid argument (VK_ERROR_INCOMPATIBLE_DRIVER)
VULKANINFO
Vulkan Instance Version: 1.3.240
Instance Extensions: count = 20
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 4
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (Intel(R) HD Graphics 520 (SKL GT2))
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (Intel(R) HD Graphics 520 (SKL GT2)):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
Device Groups:
Group 0:
Properties:
physicalDevices: count = 1
Intel(R) HD Graphics 520 (SKL GT2) (ID: 0)
subsetAllocation = 0
Present Capabilities:
Intel(R) HD Graphics 520 (SKL GT2) (ID: 0):
Can present images from the following devices: count = 1
Present modes: count = 1
DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 1.3.230 (4206822)
driverVersion = 22.3.5 (92286981)
vendorID = 0x8086
deviceID = 0x1916
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = Intel(R) HD Graphics 520 (SKL GT2)
pipelineCacheUUID = 46f0ed16-1808-3860-7a56-48027c0c6192
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 134217728
maxStorageBufferRange = 1073741824
maxPushConstantsSize = 128
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000001
sparseAddressSpaceSize = 0x00000000
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 65535
maxPerStageDescriptorUniformBuffers = 64
maxPerStageDescriptorStorageBuffers = 65535
maxPerStageDescriptorSampledImages = 65535
maxPerStageDescriptorStorageImages = 65535
maxPerStageDescriptorInputAttachments = 64
maxPerStageResources = 4294967295
maxDescriptorSetSamplers = 393210
maxDescriptorSetUniformBuffers = 384
maxDescriptorSetUniformBuffersDynamic = 8
maxDescriptorSetStorageBuffers = 393210
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 393210
maxDescriptorSetStorageImages = 393210
maxDescriptorSetInputAttachments = 256
maxVertexInputAttributes = 29
maxVertexInputBindings = 31
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 4095
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 128
maxTessellationControlTotalOutputComponents = 2048
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 116
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 131078
maxComputeSharedMemorySize = 65536
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 1024
maxComputeWorkGroupSize: count = 3
1024
1024
1024
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 16
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32767
viewportSubPixelBits = 13
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000040
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferDepthSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
framebufferNoAttachmentsSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageIntegerSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageDepthSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
sampledImageStencilSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
storageImageSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 83.3333
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0.125
255.875
lineWidthRange: count = 2
0
8
pointSizeGranularity = 0.125
lineWidthGranularity = 0.0078125
strictLines = false
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000080
optimalBufferCopyRowPitchAlignment = 0x00000080
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = false
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = false
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
primitiveOverestimationSize = 0.00195312
maxExtraPrimitiveOverestimationSize = 0
extraPrimitiveOverestimationSizeGranularity = 0
primitiveUnderestimation = false
conservativePointAndLineRasterization = false
degenerateTrianglesRasterized = true
degenerateLinesRasterized = false
fullyCoveredFragmentShaderInputVariable = false
conservativeRasterizationPostDepthCoverage = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 3
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 1048576
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 64
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 4294967295
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 64
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 384
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindStorageBuffers = 4294967295
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 256
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
driverName = Intel open-source Mesa driver
driverInfo = Mesa 22.3.5
conformanceVersion:
major = 1
minor = 3
subminor = 0
patch = 0
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 1
renderMajor = 226
renderMinor = 129
VkPhysicalDeviceExtendedDynamicState3PropertiesEXT:
dynamicPrimitiveTopologyUnrestricted = true
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_NONE
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = true
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = e95d4a74-02b8-da35-9627-b555fcb36d23
driverUUID = e8674fed-23fc-441b-be4c-fbac0b0c4786
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockProperties:
maxInlineUniformBlockSize = 4096
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 1024
maxMemoryAllocationSize = 0x80000000
VkPhysicalDeviceMaintenance4Properties:
maxBufferSize = 0x40000000
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 16
maxMultiviewInstanceIndex = 268435455
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 0
pciDevice = 2
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000040
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
maxSampleLocationGridSize:
width = 1
height = 1
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = true
filterMinmaxImageComponentMapping = true
VkPhysicalDeviceShaderIntegerDotProductProperties:
integerDotProduct8BitUnsignedAccelerated = false
integerDotProduct8BitSignedAccelerated = false
integerDotProduct8BitMixedSignednessAccelerated = false
integerDotProduct4x8BitPackedUnsignedAccelerated = false
integerDotProduct4x8BitPackedSignedAccelerated = false
integerDotProduct4x8BitPackedMixedSignednessAccelerated = false
integerDotProduct16BitUnsignedAccelerated = false
integerDotProduct16BitSignedAccelerated = false
integerDotProduct16BitMixedSignednessAccelerated = false
integerDotProduct32BitUnsignedAccelerated = false
integerDotProduct32BitSignedAccelerated = false
integerDotProduct32BitMixedSignednessAccelerated = false
integerDotProduct64BitUnsignedAccelerated = false
integerDotProduct64BitSignedAccelerated = false
integerDotProduct64BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating8BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating8BitSignedAccelerated = false
integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating16BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating16BitSignedAccelerated = false
integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating32BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating32BitSignedAccelerated = false
integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating64BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating64BitSignedAccelerated = false
integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated = false
VkPhysicalDeviceShaderModuleIdentifierPropertiesEXT:
shaderModuleIdentifierAlgorithmUUID = 4d455341-2d53-4841-3100-000000000000
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 32
supportedStages: count = 6
SHADER_STAGE_VERTEX_BIT
SHADER_STAGE_TESSELLATION_CONTROL_BIT
SHADER_STAGE_TESSELLATION_EVALUATION_BIT
SHADER_STAGE_GEOMETRY_BIT
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
supportedOperations: count = 8
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_ARITHMETIC_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_CLUSTERED_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlProperties:
minSubgroupSize = 8
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 56
requiredSubgroupSizeStages: count = 3
SHADER_STAGE_TASK_BIT_EXT
SHADER_STAGE_MESH_BIT_EXT
VkPhysicalDeviceTexelBufferAlignmentProperties:
storageTexelBufferOffsetAlignmentBytes = 0x00000010
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000001
uniformTexelBufferOffsetSingleTexelAlignment = false
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0x100000000
maxTransformFeedbackStreamDataSize = 512
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = false
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 268435455
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 32
subgroupSupportedStages: count = 6
subgroupSupportedOperations: count = 8
subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
conformanceVersion:
major = 1
minor = 3
subminor = 0
patch = 0
framebufferIntegerColorSampleCounts: count = 5
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
SAMPLE_COUNT_16_BIT
VkPhysicalDeviceVulkan13Properties:
minSubgroupSize = 8
maxInlineUniformTotalSize = 65535
Device Extensions: count = 126
VK_EXT_4444_formats : extension revision 1
VK_EXT_border_color_swizzle : extension revision 1
VK_EXT_buffer_device_address : extension revision 2
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_conservative_rasterization : extension revision 1
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clamp_zero_one : extension revision 1
VK_EXT_depth_clip_control : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_descriptor_indexing : extension revision 2
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_extended_dynamic_state3 : extension revision 2
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_fragment_shader_interlock : extension revision 1
VK_EXT_global_priority : extension revision 2
VK_EXT_global_priority_query : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_2d_view_of_3d : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 2
VK_EXT_image_robustness : extension revision 1
VK_EXT_image_view_min_lod : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_mutable_descriptor_type : extension revision 1
VK_EXT_non_seamless_cube_map : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_post_depth_coverage : extension revision 1
VK_EXT_primitive_topology_list_restart : extension revision 1
VK_EXT_primitives_generated_query : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_sampler_filter_minmax : extension revision 2
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_atomic_float2 : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_module_identifier : extension revision 1
VK_EXT_shader_stencil_export : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_tooling_info : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_INTEL_shader_integer_functions2 : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_dynamic_rendering : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_format_feature_flags2 : extension revision 2
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_maintenance4 : extension revision 2
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_pipeline_library : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_atomic_int64 : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_float16_int8 : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_integer_dot_product : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_extended_types : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VK_VALVE_mutable_descriptor_type : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER
timestampValidBits = 36
present support = true
VkQueueFamilyGlobalPriorityPropertiesKHR:
priorityCount = 2
priorities: count = 2
QUEUE_GLOBAL_PRIORITY_LOW_KHR
QUEUE_GLOBAL_PRIORITY_MEDIUM_KHR
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 1
memoryHeaps[0]:
size = 6065104896 (0x169822800) (5.65 GiB)
budget = 4508876800 (0x10cc00000) (4.20 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 1
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x000f: count = 4
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D24_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
(non-sparse)
IMAGE_TILING_LINEAR:
color images
(non-sparse)
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = false
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = true
textureCompressionASTC_LDR = true
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = false
shaderStorageImageReadWithoutFormat = false
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = true
shaderResourceResidency = false
shaderResourceMinLod = true
sparseBinding = false
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = false
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceBorderColorSwizzleFeaturesEXT:
borderColorSwizzle = true
borderColorSwizzleFromImage = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = true
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
bufferDeviceAddressCaptureReplay = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClampZeroOneFeaturesEXT:
depthClampZeroOne = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = false
shaderUniformTexelBufferArrayDynamicIndexing = true
shaderStorageTexelBufferArrayDynamicIndexing = true
shaderUniformBufferArrayNonUniformIndexing = false
shaderSampledImageArrayNonUniformIndexing = true
shaderStorageBufferArrayNonUniformIndexing = true
shaderStorageImageArrayNonUniformIndexing = true
shaderInputAttachmentArrayNonUniformIndexing = false
shaderUniformTexelBufferArrayNonUniformIndexing = true
shaderStorageTexelBufferArrayNonUniformIndexing = true
descriptorBindingUniformBufferUpdateAfterBind = true
descriptorBindingSampledImageUpdateAfterBind = true
descriptorBindingStorageImageUpdateAfterBind = true
descriptorBindingStorageBufferUpdateAfterBind = true
descriptorBindingUniformTexelBufferUpdateAfterBind = true
descriptorBindingStorageTexelBufferUpdateAfterBind = true
descriptorBindingUpdateUnusedWhilePending = true
descriptorBindingPartiallyBound = true
descriptorBindingVariableDescriptorCount = true
runtimeDescriptorArray = true
VkPhysicalDeviceDynamicRenderingFeatures:
dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicState3FeaturesEXT:
extendedDynamicState3TessellationDomainOrigin = true
extendedDynamicState3DepthClampEnable = true
extendedDynamicState3PolygonMode = true
extendedDynamicState3RasterizationSamples = false
extendedDynamicState3SampleMask = true
extendedDynamicState3AlphaToCoverageEnable = false
extendedDynamicState3AlphaToOneEnable = true
extendedDynamicState3LogicOpEnable = true
extendedDynamicState3ColorBlendEnable = true
extendedDynamicState3ColorBlendEquation = true
extendedDynamicState3ColorWriteMask = true
extendedDynamicState3RasterizationStream = true
extendedDynamicState3ConservativeRasterizationMode = false
extendedDynamicState3ExtraPrimitiveOverestimationSize = false
extendedDynamicState3DepthClipEnable = true
extendedDynamicState3SampleLocationsEnable = false
extendedDynamicState3ColorBlendAdvanced = false
extendedDynamicState3ProvokingVertexMode = true
extendedDynamicState3LineRasterizationMode = true
extendedDynamicState3LineStippleEnable = true
extendedDynamicState3DepthClipNegativeOneToOne = true
extendedDynamicState3ViewportWScalingEnable = false
extendedDynamicState3ViewportSwizzle = false
extendedDynamicState3CoverageToColorEnable = false
extendedDynamicState3CoverageToColorLocation = false
extendedDynamicState3CoverageModulationMode = false
extendedDynamicState3CoverageModulationTableEnable = false
extendedDynamicState3CoverageModulationTable = false
extendedDynamicState3CoverageReductionMode = false
extendedDynamicState3RepresentativeFragmentTestEnable = false
extendedDynamicState3ShadingRateImageEnable = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
fragmentShaderSampleInterlock = true
fragmentShaderPixelInterlock = true
fragmentShaderShadingRateInterlock = false
VkPhysicalDeviceGlobalPriorityQueryFeaturesKHR:
globalPriorityQuery = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImage2DViewOf3DFeaturesEXT:
image2DViewOf3D = true
sampler2DViewOf3D = true
VkPhysicalDeviceImageRobustnessFeatures:
robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeatures:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = false
bresenhamLines = true
smoothLines = true
stippledRectangularLines = false
stippledBresenhamLines = true
stippledSmoothLines = false
VkPhysicalDeviceMaintenance4Features:
maintenance4 = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDeviceMutableDescriptorTypeFeaturesEXT:
mutableDescriptorType = true
VkPhysicalDeviceNonSeamlessCubeMapFeaturesEXT:
nonSeamlessCubeMap = true
VkPhysicalDevicePipelineCreationCacheControlFeatures:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
primitiveTopologyListRestart = true
primitiveTopologyPatchListRestart = true
VkPhysicalDevicePrimitivesGeneratedQueryFeaturesEXT:
primitivesGeneratedQuery = true
primitivesGeneratedQueryWithRasterizerDiscard = false
primitivesGeneratedQueryWithNonZeroStreams = false
VkPhysicalDevicePrivateDataFeatures:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloat2FeaturesEXT:
shaderBufferFloat16Atomics = false
shaderBufferFloat16AtomicAdd = false
shaderBufferFloat16AtomicMinMax = false
shaderBufferFloat32AtomicMinMax = true
shaderBufferFloat64AtomicMinMax = false
shaderSharedFloat16Atomics = false
shaderSharedFloat16AtomicAdd = false
shaderSharedFloat16AtomicMinMax = false
shaderSharedFloat32AtomicMinMax = true
shaderSharedFloat64AtomicMinMax = false
shaderImageFloat32AtomicMinMax = false
sparseImageFloat32AtomicMinMax = false
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = false
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = false
shaderSharedFloat64Atomics = false
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = false
sparseImageFloat32AtomicAdd = false
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = true
shaderSharedInt64Atomics = false
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = false
VkPhysicalDeviceShaderDemoteToHelperInvocationFeatures:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = true
shaderInt8 = true
VkPhysicalDeviceShaderIntegerDotProductFeatures:
shaderIntegerDotProduct = true
VkPhysicalDeviceShaderModuleIdentifierFeaturesEXT:
shaderModuleIdentifier = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeatures:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeatures:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSynchronization2Features:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTextureCompressionASTCHDRFeatures:
textureCompressionASTC_HDR = false
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = true
descriptorIndexing = true
samplerFilterMinmax = true
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkan13Features:
privateData = true
shaderZeroInitializeWorkgroupMemory = true
maintenance4 = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeatures:
My system info:
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM
Type: Laptop System: Dell product: Inspiron 5459 v: N/A
Mobo: Dell model: 0F1J0W v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.0 date: 09/07/2020
ID-1: BAT0 charge: 27.6 Wh (100.0%) condition: 27.6/32.6 Wh (84.6%)
volts: 16.7 min: 14.8 model: SMP DELL VN3N047 serial: <filter> status: full
Info: dual core model: Intel Core i7-6500U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 2817 high: 3043 min/max: 400/3100 cores: 1: 2600 2: 3043
3: 2600 4: 3028 bogomips: 20810
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen-9 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:1916
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Dell driver: radeon v: kernel arch: GCN-1 pcie:
speed: 2.5 GT/s lanes: 4 bus-ID: 01:00.0 chip-ID: 1002:6660 temp: 47.0 C
Device-3: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:6712
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting,radeon
alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14c3 res: 1366x768 dpi: 112
diag: 354mm (13.9")
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d70
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b3
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8136
bus-ID: 1-8:5 chip-ID: 8087:07dc
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 418.1 GiB (44.9%)
ID-1: /dev/sda vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 168.24 GiB used: 110.78 GiB (65.8%) fs: ext4 dev: /dev/sda8
ID-2: /boot/efi size: 96 MiB used: 40.7 MiB (42.4%) fs: vfat
dev: /dev/sda2
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda9
System Temperatures: cpu: 53.0 C pch: 43.5 C mobo: 42.0 C sodimm: SODIMM C
gpu: radeon temp: 47.0 C
Fan Speeds (RPM): cpu: 0
Processes: 237 Uptime: 31m Memory: 7.53 GiB used: 3.4 GiB (45.1%)
Init: systemd v: 252 default: graphical Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1576 pm: pacman pkgs: 1568 pm: flatpak pkgs: 8 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.25
I have vulkan support and I can use it on Windows. But somehow in my Manjaro setup it is not working.
How can I fix this?
