Hey guys I’m reporting a issue on a project and wanted to ask if the Raspberry pi 5 has vulkan support with the current driver as VKQuake cannot create a vulkan instance, I wasn’t sure on the answer so I wanted to ask you guys.
opened 04:50AM - 11 May 24 UTC
Hey I just want to report a issue, I am unable to launch vkquake2 on my Raspberr… y pi 5 and I have vulkan-headers installed
./quake2
Added packfile ./baseq2/pak0.pak (1106 files)
execing default.cfg
couldn't exec config.cfg
Console initialized.
------- sound initialization -------
Setting up ALSA driver .....
Low Performance 11KHz.
sound sampling rate: 11025
------- Loading ref_vk.so -------
LoadLibrary("/home/corey/stuff/projects/vkQuake2/linux/releaseaarch64-glibc/ref_vk.so")
ref_vk version: Vulkan (vkQuake2 v1.5.10)
Initializing Vulkan display
...setting fullscreen mode 11: 1920 1080
Using XFree86-VidModeExtension Version 2.2
Enabled extensions: VK_KHR_surface VK_KHR_xlib_surface
QVk_Init(): Could not create Vulkan instance: VK_ERROR_INCOMPATIBLE_DRIVER
ref_vk::R_Init() - could not initialize Vulkan!
ERROR: vkDeviceWaitIdle: Invalid device [VUID-vkDeviceWaitIdle-device-parameter]
Received signal 6, exiting...
