Hi, after this update vulkan stopped working, when I type vulkaninfo I get the following message:
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs: Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.3.255/vulkaninfo/vulkaninfo.h:237:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
Also Corectrl does not recognize my video card, as well as screenfecth, in the same way steam, lutris, etc… does not work.
I tried reinstalling the video drivers, vulkan, etc… and none of that works. Also when I start the system I get the following error:
My card is AMD RX 580
This appears after running: systemctl status systemd-modules-load.service:
× systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static)
Active: failed (Result: exit-code) since Tue 2023-07-25 11:46:13 -05; 16min ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 425 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 425 (code=exited, status=1/FAILURE)
CPU: 72ms
jul 25 11:46:11 DeskCore systemd[1]: Starting Load Kernel Modules...
jul 25 11:46:13 DeskCore systemd-modules-load[425]: Failed to insert module 'amdgpu': Device or resource busy
jul 25 11:46:13 DeskCore systemd-modules-load[425]: Failed to find module 'nvidia-uvm'
jul 25 11:46:13 DeskCore systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
jul 25 11:46:13 DeskCore systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
jul 25 11:46:13 DeskCore systemd[1]: Failed to start Load Kernel Modules.
