Recently I was trying to set up sunshine/moonlight for connecting to my PC from my laptop. After trying it out, and also trying out some other options (possibly something something vnc, nomachine, remmina), I was getting xord coredumps all over the place. Removing nomachine from my system fixed the issue. Now, when trying to play steam games, nothing happens. I go try vkcube, I get
vkEnumeratePhysicalDevices reported zero accessible devices.
Do you have a compatible Vulkan installable client driver (ICD) installed?
Please look at the Getting Started guide for additional information.
I go try vulkaninfo, I get
ERROR: [../mesa-24.0.2/src/amd/vulkan/radv_physical_device.c:1813] Code 0 : Could not open device /dev/dri/renderD128: Permission denied (VK_ERROR_INCOMPATIBLE_DRIVER)
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs: Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.3.269/vulkaninfo/./vulkaninfo.h:237:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
However both commands work perfectly fine with sudo. Also, before running into this issue, I’ve updated from kernel 6.5 to 6.6. Reinstalling all amdgpu, vulkan, mesa etc. packages did not fix the issue, as well as removing amdvlk. Booting up 6.5 does not affect the issue. vulkan-radeon is and was always installed and I have gone through initial amdgpu setup as per archwiki docs when I installed the system half a year ago (everything was working flawlessly before my remote access / kernel update shenanigans)
Another thread on this forum discussed similar problem, and someone asked whether xorg config has been modified, but unfortunately OP didn’t answer (that’s why I described the premise for the situation).
I would sincerely appreciate any help! Thank you!
inxi -Fazy:
Summary
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=ac37aa3b-2733-4f56-bcac-8fe141ddda25 rw quiet splash
resume=UUID=3598205a-fe30-4702-acdf-ba411c83570e udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 with: latte-dock vt: 2 dm: SDDM Distro: Manjaro
base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 3205 date: 08/14/2023
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: discharging
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2467 high: 4413 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4413 2: 3676
3: 2200 4: 3387 5: 3737 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2199 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200
20: 2199 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177686
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,HDMI-A-2 empty: DP-2,HDMI-A-1 bus-ID: 0d:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 17ef:4831
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right model: Dell P2319H
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: left model: Dell S2319H
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 1 drv: swrast
surfaceless: drv: swrast x11: drv: radeonsi inactive: gbm,wayland,device-0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 16.0.6 DRM 3.54 6.5.13-7-MANJARO) device-ID: 1002:747e
memory: 15.62 GiB unified: no
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Nano driver: N/A type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: b58e:0005
class-ID: 0000 serial: <filter>
Device-4: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
chip-ID: 10ec:818b class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp10s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-d1649514334b state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth27efe08 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth2b9637e state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth6c5066e state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: veth9c973c3 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vethb5264de state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: vethc3f933d state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-9: vethc888fe1 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-10: vethe7f6ec0 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: vethf04f6d9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: vethf5ebe79 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: mld, NetworkManager, nginx, systemd-timesyncd
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7.1:5 chip-ID: 0b05:190e
Local Storage: total: 1.82 TiB used: 795.19 GiB (42.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 34.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 39.9 C
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 794.44 GiB (87.6%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: partition size: 8.8 GiB used: 769.2 MiB (8.5%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
System Temperatures: cpu: 37.0 C mobo: 28.0 C gpu: amdgpu temp: 39.0 C
mem: 56.0 C
Fan Speeds (rpm): fan-1: 1137 fan-2: 797 fan-3: 555 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 0 gpu: amdgpu fan: 0
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 11.37 GiB (18.1%)
Processes: 494 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1644 pm: pacman pkgs: 1609 libs: 418 tools: pamac pm: flatpak
pkgs: 35 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
Here is a pacman log for today. Somewhere in between I was testing how game streaming through sunshine/moonlight would run and it ran just fine as always. I’m struggling to figure out what could I do to break vulkan
Summary
[2024-04-30T01:18:56+0300] [PAMAC] synchronizing package lists
[2024-04-30T01:19:39+0300] [ALPM] transaction started
[2024-04-30T01:19:39+0300] [ALPM] installed webkit2gtk-4.1 (2.42.5-2)
[2024-04-30T01:19:39+0300] [ALPM] installed phodav (3.0-2)
[2024-04-30T01:19:39+0300] [ALPM] installed usbredir (0.13.0-1)
[2024-04-30T01:19:39+0300] [ALPM] installed gtk-vnc (1.3.1-1)
[2024-04-30T01:19:39+0300] [ALPM] installed libcacard (2.7.0-3)
[2024-04-30T01:19:39+0300] [ALPM] installed gnome-terminal (3.50.1-1)
[2024-04-30T01:19:39+0300] [ALPM] installed remmina (1:1.4.35-1)
[2024-04-30T01:19:39+0300] [ALPM] installed spice-protocol (0.14.4-1)
[2024-04-30T01:19:39+0300] [ALPM] installed spice-gtk (0.42-3)
[2024-04-30T01:19:39+0300] [ALPM] installed libvncserver (0.9.14-2)
[2024-04-30T01:19:39+0300] [ALPM] installed freerdp (2:2.11.4-1)
[2024-04-30T01:19:39+0300] [ALPM] transaction completed
[2024-04-30T01:19:39+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-04-30T01:19:39+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-04-30T01:19:39+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running '30-update-mime-database.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running 'glib-compile-schemas.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T01:19:40+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T01:26:55+0300] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-04-30T01:26:55+0300] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-04-30T01:26:55+0300] [ALPM] transaction started
[2024-04-30T01:26:55+0300] [ALPM] upgraded coolercontrol (1.2.2-1 -> 1.2.2-2)
[2024-04-30T01:26:55+0300] [ALPM] transaction completed
[2024-04-30T01:26:55+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-04-30T01:26:56+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T01:26:56+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T01:26:56+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T01:26:56+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T01:27:38+0300] [ALPM] transaction started
[2024-04-30T01:27:38+0300] [ALPM] installed rpm-sequoia (1.6.0-1)
[2024-04-30T01:27:38+0300] [ALPM] installed rpm-tools (4.19.1.1-1)
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] rpm-tools installs RedHat package manager for you.
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] It is useful for those who wants to create/modify RPM files.
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] But do not use rpm-tools to install RedHat packages at your ArchLinux machine.
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] It will break your system!
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] You will need to go back to Arch wiki and read the installation guide again.
[2024-04-30T01:27:38+0300] [ALPM-SCRIPTLET] You've been warned!
[2024-04-30T01:27:38+0300] [ALPM] installed nawk (20240122-1)
[2024-04-30T01:27:38+0300] [ALPM] transaction completed
[2024-04-30T01:27:38+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T01:27:38+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T01:27:58+0300] [ALPM] transaction started
[2024-04-30T01:27:58+0300] [ALPM] installed nomachine (8.11.3-1)
[2024-04-30T01:27:58+0300] [ALPM-SCRIPTLET] Running NX post_install script...
[2024-04-30T01:27:59+0300] [ALPM-SCRIPTLET] NX> 700 Starting installation at: Tue, 30 Apr 2024 01:27:59.
[2024-04-30T01:27:59+0300] [ALPM-SCRIPTLET] NX> 700 Using installation profile: Fedora.
[2024-04-30T01:27:59+0300] [ALPM-SCRIPTLET] NX> 700 Installation log is: /usr/NX/var/log/nxinstall.log.
[2024-04-30T01:27:59+0300] [ALPM-SCRIPTLET] NX> 700 Installing nxrunner version: 8.11.3.
[2024-04-30T01:28:01+0300] [ALPM-SCRIPTLET] NX> 700 Installing nxplayer version: 8.11.3.
[2024-04-30T01:28:01+0300] [ALPM-SCRIPTLET] NX> 700 Installing nxnode version: 8.11.3.
[2024-04-30T01:28:05+0300] [ALPM-SCRIPTLET] NX> 700 Installing nxserver version: 8.11.3.
[2024-04-30T01:28:09+0300] [ALPM-SCRIPTLET] NX> 700 Installation completed at: Tue, 30 Apr 2024 01:28:09.
[2024-04-30T01:28:09+0300] [ALPM-SCRIPTLET] NX> 700 NoMachine was configured to run the following services:
[2024-04-30T01:28:09+0300] [ALPM-SCRIPTLET] NX> 700 NX service on port: 4000
[2024-04-30T01:28:09+0300] [ALPM] transaction completed
[2024-04-30T01:28:09+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T01:28:09+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T11:22:01+0300] [ALPM] transaction started
[2024-04-30T11:22:02+0300] [ALPM] removed remmina (1:1.4.35-1)
[2024-04-30T11:22:02+0300] [ALPM] transaction completed
[2024-04-30T11:22:02+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T11:22:02+0300] [ALPM] running '30-update-mime-database.hook'...
[2024-04-30T11:22:03+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T11:22:03+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T11:22:03+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T11:50:24+0300] [PAMAC] synchronizing package lists
[2024-04-30T11:50:49+0300] [ALPM] running '00-timeshift-autosnap.hook'...
[2024-04-30T11:50:49+0300] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2024-04-30T11:50:49+0300] [ALPM] transaction started
[2024-04-30T11:50:50+0300] [ALPM] upgraded discord (0.0.51-1 -> 0.0.52-1)
[2024-04-30T11:50:50+0300] [ALPM] installed strongswan (5.9.13-1)
[2024-04-30T11:50:50+0300] [ALPM] installed openldap (2.6.6-2)
[2024-04-30T11:50:50+0300] [ALPM] transaction completed
[2024-04-30T11:50:50+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2024-04-30T11:50:50+0300] [ALPM-SCRIPTLET] Creating group 'ldap' with GID 439.
[2024-04-30T11:50:50+0300] [ALPM-SCRIPTLET] Creating user 'ldap' (LDAP Server) with UID 439 and GID 439.
[2024-04-30T11:50:50+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-04-30T11:50:50+0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2024-04-30T11:50:50+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T11:50:50+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T11:50:50+0300] [ALPM] running 'dbus-reload.hook'...
[2024-04-30T11:50:51+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T11:50:51+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T12:32:49+0300] [PAMAC] synchronizing package lists
[2024-04-30T12:33:11+0300] [ALPM] transaction started
[2024-04-30T12:33:11+0300] [ALPM] installed networkmanager-strongswan (1.6.0-1.0)
[2024-04-30T12:33:11+0300] [ALPM] installed gcr-4 (4.2.1-1)
[2024-04-30T12:33:11+0300] [ALPM-SCRIPTLET] Created symlink /etc/systemd/user/sockets.target.wants/gcr-ssh-agent.socket → /usr/lib/systemd/user/gcr-ssh-agent.socket.
[2024-04-30T12:33:11+0300] [ALPM] installed libnma-common (1.10.6-2)
[2024-04-30T12:33:11+0300] [ALPM] installed libnma (1.10.6-2)
[2024-04-30T12:33:11+0300] [ALPM] transaction completed
[2024-04-30T12:33:11+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-04-30T12:33:11+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T12:33:11+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T12:33:12+0300] [ALPM] running 'glib-compile-schemas.hook'...
[2024-04-30T17:16:47+0300] [ALPM] transaction started
[2024-04-30T17:16:48+0300] [ALPM] removed sunshine (0.23.1-1)
[2024-04-30T17:16:48+0300] [ALPM] removed miniupnpc (2.2.6-1)
[2024-04-30T17:16:48+0300] [ALPM] transaction completed
[2024-04-30T17:16:48+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-04-30T17:16:48+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-04-30T17:16:48+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T17:16:48+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T17:16:48+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T17:16:48+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T17:17:10+0300] [ALPM] transaction started
[2024-04-30T17:17:10+0300] [ALPM] installed miniupnpc (2.2.6-1)
[2024-04-30T17:17:10+0300] [ALPM] transaction completed
[2024-04-30T17:17:10+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T17:17:10+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T17:22:14+0300] [ALPM] transaction started
[2024-04-30T17:22:14+0300] [ALPM] installed sunshine (0.23.1-1)
[2024-04-30T17:22:14+0300] [ALPM] transaction completed
[2024-04-30T17:22:14+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-04-30T17:22:14+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-04-30T17:22:15+0300] [ALPM] running '30-systemd-update.hook'...
[2024-04-30T17:22:15+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2024-04-30T17:22:15+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-04-30T17:22:15+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-04-30T20:14:35+0300] [ALPM] transaction started
[2024-04-30T20:14:35+0300] [ALPM-SCRIPTLET] Running NX pre_remove script...
[2024-04-30T20:14:35+0300] [ALPM-SCRIPTLET] NX> 702 Starting uninstallation at: Tue, 30 Apr 2024 20:14:35.
[2024-04-30T20:14:36+0300] [ALPM-SCRIPTLET] NX> 702 Uninstallation log is: /usr/NX/var/log/nxuninstall.log.
[2024-04-30T20:14:36+0300] [ALPM-SCRIPTLET] NX> 702 Uninstalling nxserver version: 8.11.3.
[2024-04-30T20:14:39+0300] [ALPM-SCRIPTLET] NX> 702 Uninstalling nxnode version: 8.11.3.
[2024-04-30T20:14:42+0300] [ALPM-SCRIPTLET] NX> 702 Uninstalling nxplayer version: 8.11.3.
[2024-04-30T20:14:45+0300] [ALPM-SCRIPTLET] NX> 702 Uninstalling nxrunner version: 8.11.3.
[2024-04-30T20:14:47+0300] [ALPM-SCRIPTLET] NX> 702 Uninstallation completed at: Tue, 30 Apr 2024 20:14:47.
[2024-04-30T20:14:48+0300] [ALPM] removed nomachine (8.11.3-1)
[2024-04-30T20:14:48+0300] [ALPM-SCRIPTLET] Removing /usr/NX...
[2024-04-30T20:14:48+0300] [ALPM] removed nawk (20240122-1)
[2024-04-30T20:14:48+0300] [ALPM] removed dkms (3.0.12-1)
[2024-04-30T20:14:48+0300] [ALPM] removed rpm-tools (4.19.1.1-1)
[2024-04-30T20:14:48+0300] [ALPM] removed elfutils (0.191-1)
[2024-04-30T20:14:48+0300] [ALPM] removed rpm-sequoia (1.6.0-1)
[2024-04-30T20:14:48+0300] [ALPM] transaction completed
cat /var/log/Xorg.0.log:
Summary
[ 12.728] (--) Log file renamed from "/var/log/Xorg.pid-906.log" to "/var/log/Xorg.0.log"
[ 12.729]
X.Org X Server 1.21.1.12
[ 12.729] Current Operating System: Linux ivan-workplace 6.6.26-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Apr 10 20:11:08 UTC 2024 x86_64
[ 12.729] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=ac37aa3b-2733-4f56-bcac-8fe141ddda25 rw radeon.si_support=0 amdgpu.si_support=1 radeon.cik_support=0 amdgpu.cik_support=1 quiet splash resume=UUID=3598205a-fe30-4702-acdf-ba411c83570e udev.log_priority=3
[ 12.729]
[ 12.729] Current version of pixman: 0.43.4
[ 12.729] Before reporting problems, check http://wiki.x.org
[ 12.729] Markers: (--) probed, (**) from config file, (==) default setting,
[ 12.729] (==) Log file: "/var/log/Xorg.0.log", Time: Wed May 1 00:13:46 2024
[ 12.732] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 12.732] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 12.734] (==) No Layout section. Using the first Screen section.
[ 12.734] (==) No screen section available. Using defaults.
[ 12.734] (**) |-->Screen "Default Screen Section" (0)
[ 12.734] (**) | |-->Monitor "<default monitor>"
[ 12.735] (==) No monitor specified for screen "Default Screen Section".
[ 12.735] (**) Allowing byte-swapped clients
[ 12.735] (==) Automatically adding devices
[ 12.735] (==) Automatically enabling devices
[ 12.735] (==) Automatically adding GPU devices
[ 12.735] (==) Automatically binding GPU devices
[ 12.735] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 12.736] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 12.736] Entry deleted from font path.
[ 12.736] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 12.736] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 12.736] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 12.736] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 12.736] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 12.736] (II) The server relies on udev to provide the list of input devices.
[ 12.736] (II) Module ABI versions:
[ 12.736] X.Org ANSI C Emulation: 0.4
[ 12.736] X.Org Video Driver: 25.2
[ 12.736] X.Org XInput driver : 24.4
[ 12.736] X.Org Server Extension : 10.0
[ 12.736] (++) using VT number 2
[ 12.736] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 12.737] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 12.737] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:0b:00.0/0000:0c:00.0/0000:0d:00.0/drm/card1
[ 12.773] (--) PCI:*(13@0:0:0) 1002:747e:1da2:475d rev 200, Mem @ 0x7800000000/17179869184, 0x7c00000000/268435456, 0xfcc00000/1048576, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 12.773] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 12.773] (II) LoadModule: "glx"
[ 12.773] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 12.776] (II) Module glx: vendor="X.Org Foundation"
[ 12.776] compiled for 1.21.1.12, module version = 1.0.0
[ 12.776] ABI class: X.Org Server Extension, version 10.0
[ 12.776] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[ 12.776] loading driver: amdgpu
[ 12.776] (==) Matched amdgpu as autoconfigured driver 0
[ 12.776] (==) Matched ati as autoconfigured driver 1
[ 12.776] (==) Matched modesetting as autoconfigured driver 2
[ 12.776] (==) Matched fbdev as autoconfigured driver 3
[ 12.776] (==) Matched vesa as autoconfigured driver 4
[ 12.776] (==) Assigned the driver to the xf86ConfigLayout
[ 12.776] (II) LoadModule: "amdgpu"
[ 12.776] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 12.777] (II) Module amdgpu: vendor="X.Org Foundation"
[ 12.777] compiled for 1.21.1.7, module version = 23.0.0
[ 12.777] Module class: X.Org Video Driver
[ 12.777] ABI class: X.Org Video Driver, version 25.2
[ 12.777] (II) LoadModule: "ati"
[ 12.777] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 12.777] (II) Module ati: vendor="X.Org Foundation"
[ 12.777] compiled for 1.21.1.8, module version = 22.0.0
[ 13.069] (II) LoadModule: "radeon"
[ 13.069] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 13.070] (II) Module radeon: vendor="X.Org Foundation"
[ 13.070] compiled for 1.21.1.8, module version = 22.0.0
[ 13.070] Module class: X.Org Video Driver
[ 13.070] ABI class: X.Org Video Driver, version 25.2
[ 13.070] (II) LoadModule: "modesetting"
[ 13.070] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 13.071] (II) Module modesetting: vendor="X.Org Foundation"
[ 13.071] compiled for 1.21.1.12, module version = 1.21.1
[ 13.071] Module class: X.Org Video Driver
[ 13.071] ABI class: X.Org Video Driver, version 25.2
[ 13.071] (II) LoadModule: "fbdev"
[ 13.071] (WW) Warning, couldn't open module fbdev
[ 13.071] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 13.071] (II) LoadModule: "vesa"
[ 13.071] (WW) Warning, couldn't open module vesa
[ 13.071] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 13.071] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 13.071] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 13.071] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 13.074] (WW) Falling back to old probe method for modesetting
[ 13.074] (EE) open /dev/dri/card0: No such file or directory
[ 13.074] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 13.074] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 13.074] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 13.074] (==) AMDGPU(0): Default visual is TrueColor
[ 13.074] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[ 13.074] (==) AMDGPU(0): RGB weight 888
[ 13.074] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 13.074] (--) AMDGPU(0): Chipset: "AMD Radeon RX 7800 XT" (ChipID = 0x747e)
[ 13.074] (II) Loading sub module "fb"
[ 13.074] (II) LoadModule: "fb"
[ 13.074] (II) Module "fb" already built-in
[ 13.074] (II) Loading sub module "dri2"
[ 13.074] (II) LoadModule: "dri2"
[ 13.074] (II) Module "dri2" already built-in
[ 13.221] (II) Loading sub module "glamoregl"
[ 13.221] (II) LoadModule: "glamoregl"
[ 13.221] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 13.225] (II) Module glamoregl: vendor="X.Org Foundation"
[ 13.225] compiled for 1.21.1.12, module version = 1.0.1
[ 13.225] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.236] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 7800 XT (radeonsi, navi32, LLVM 16.0.6, DRM 3.54, 6.6.26-1-MANJARO)
[ 13.236] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 13.236] (==) AMDGPU(0): TearFree property default: auto
[ 13.236] (==) AMDGPU(0): VariableRefresh: disabled
[ 13.236] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[ 13.236] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 13.239] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 13.239] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 13.239] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 13.245] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[ 13.267] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 13.267] (II) AMDGPU(0): Manufacturer: DEL Model: d0d6 Serial#: 1112037698
[ 13.267] (II) AMDGPU(0): Year: 2021 Week: 15
[ 13.267] (II) AMDGPU(0): EDID Version: 1.4
[ 13.267] (II) AMDGPU(0): Digital Display Input
[ 13.267] (II) AMDGPU(0): 8 bits per channel
[ 13.267] (II) AMDGPU(0): Digital interface is DisplayPort
[ 13.267] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 51 vert.: 29
[ 13.267] (II) AMDGPU(0): Gamma: 2.20
[ 13.267] (II) AMDGPU(0): DPMS capabilities: Off
[ 13.267] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 13.267] (II) AMDGPU(0): First detailed timing is preferred mode
[ 13.267] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 13.267] (II) AMDGPU(0): redX: 0.651 redY: 0.338 greenX: 0.318 greenY: 0.612
[ 13.267] (II) AMDGPU(0): blueX: 0.151 blueY: 0.065 whiteX: 0.313 whiteY: 0.329
[ 13.267] (II) AMDGPU(0): Supported established timings:
[ 13.267] (II) AMDGPU(0): 720x400@70Hz
[ 13.267] (II) AMDGPU(0): 640x480@60Hz
[ 13.267] (II) AMDGPU(0): 640x480@75Hz
[ 13.267] (II) AMDGPU(0): 800x600@60Hz
[ 13.267] (II) AMDGPU(0): 800x600@75Hz
[ 13.267] (II) AMDGPU(0): 1024x768@60Hz
[ 13.267] (II) AMDGPU(0): 1024x768@75Hz
[ 13.267] (II) AMDGPU(0): 1280x1024@75Hz
[ 13.267] (II) AMDGPU(0): Manufacturer's mask: 0
[ 13.267] (II) AMDGPU(0): Supported standard timings:
[ 13.267] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 13.267] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 13.267] (II) AMDGPU(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 13.267] (II) AMDGPU(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 13.267] (II) AMDGPU(0): Supported detailed timing:
[ 13.267] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 13.267] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 13.267] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 13.267] (II) AMDGPU(0): Serial No: 8CR3S83
[ 13.267] (II) AMDGPU(0): Monitor name: DELL P2319H
[ 13.267] (II) AMDGPU(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 13.267] (II) AMDGPU(0): EDID (in hex):
[ 13.267] (II) AMDGPU(0): 00ffffffffffff0010acd6d042594842
[ 13.267] (II) AMDGPU(0): 0f1f0104a5331d783aebf5a656519c26
[ 13.267] (II) AMDGPU(0): 105054a54b00714f8180a9c0d1c00101
[ 13.267] (II) AMDGPU(0): 010101010101023a801871382d40582c
[ 13.267] (II) AMDGPU(0): 4500fd1e1100001e000000ff00384352
[ 13.267] (II) AMDGPU(0): 335338330a2020202020000000fc0044
[ 13.267] (II) AMDGPU(0): 454c4c205032333139480a20000000fd
[ 13.267] (II) AMDGPU(0): 00384c1e5311010a202020202020004f
[ 13.267] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[ 13.267] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 13.267] (II) AMDGPU(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1440x900"x60.0 148.50 1440 2008 2052 2200 900 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1280x800"x60.0 148.50 1280 2008 2052 2200 800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1280x720"x60.0 148.50 1280 2008 2052 2200 720 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.267] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.267] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 13.267] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 13.273] (II) AMDGPU(0): EDID for output HDMI-A-1
[ 13.273] (II) AMDGPU(0): Manufacturer: DEL Model: d0ca Serial#: 809972546
[ 13.273] (II) AMDGPU(0): Year: 2018 Week: 50
[ 13.273] (II) AMDGPU(0): EDID Version: 1.3
[ 13.273] (II) AMDGPU(0): Digital Display Input
[ 13.273] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 51 vert.: 29
[ 13.273] (II) AMDGPU(0): Gamma: 2.20
[ 13.273] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 13.273] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 13.273] (II) AMDGPU(0): First detailed timing is preferred mode
[ 13.273] (II) AMDGPU(0): redX: 0.651 redY: 0.338 greenX: 0.318 greenY: 0.612
[ 13.273] (II) AMDGPU(0): blueX: 0.151 blueY: 0.065 whiteX: 0.313 whiteY: 0.329
[ 13.273] (II) AMDGPU(0): Supported established timings:
[ 13.273] (II) AMDGPU(0): 720x400@70Hz
[ 13.273] (II) AMDGPU(0): 640x480@60Hz
[ 13.273] (II) AMDGPU(0): 640x480@75Hz
[ 13.273] (II) AMDGPU(0): 800x600@60Hz
[ 13.273] (II) AMDGPU(0): 800x600@75Hz
[ 13.273] (II) AMDGPU(0): 1024x768@60Hz
[ 13.273] (II) AMDGPU(0): 1024x768@75Hz
[ 13.273] (II) AMDGPU(0): 1280x1024@75Hz
[ 13.273] (II) AMDGPU(0): Manufacturer's mask: 0
[ 13.273] (II) AMDGPU(0): Supported standard timings:
[ 13.273] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 13.273] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 13.273] (II) AMDGPU(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 13.273] (II) AMDGPU(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 13.273] (II) AMDGPU(0): Supported detailed timing:
[ 13.273] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 509 x 286 mm
[ 13.273] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 13.273] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 13.273] (II) AMDGPU(0): Serial No: T7XVW8CA0G3B
[ 13.273] (II) AMDGPU(0): Monitor name: DELL S2319H
[ 13.273] (II) AMDGPU(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 13.273] (II) AMDGPU(0): clock: 74.2 MHz Image Size: 509 x 286 mm
[ 13.273] (II) AMDGPU(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 13.273] (II) AMDGPU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 13.273] (II) AMDGPU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 13.273] (II) AMDGPU(0): clock: 27.0 MHz Image Size: 509 x 286 mm
[ 13.273] (II) AMDGPU(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 13.273] (II) AMDGPU(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 13.273] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 13.273] (II) AMDGPU(0): EDID (in hex):
[ 13.273] (II) AMDGPU(0): 00ffffffffffff0010accad042334730
[ 13.273] (II) AMDGPU(0): 321c010380331d78eaebf5a656519c26
[ 13.273] (II) AMDGPU(0): 105054a54b00714f8180a9c0d1c00101
[ 13.273] (II) AMDGPU(0): 010101010101023a801871382d40582c
[ 13.273] (II) AMDGPU(0): 4500fd1e1100001e000000ff00543758
[ 13.273] (II) AMDGPU(0): 5657384341304733420a000000fc0044
[ 13.273] (II) AMDGPU(0): 454c4c205332333139480a20000000fd
[ 13.273] (II) AMDGPU(0): 00384c1e5311000a202020202020010d
[ 13.273] (II) AMDGPU(0): 020322f14f9005040302071601061112
[ 13.273] (II) AMDGPU(0): 1513141f230907078301000065030c00
[ 13.273] (II) AMDGPU(0): 1000023a801871382d40582c4500fd1e
[ 13.273] (II) AMDGPU(0): 1100001e011d8018711c1620582c2500
[ 13.273] (II) AMDGPU(0): fd1e1100009e011d007251d01e206e28
[ 13.273] (II) AMDGPU(0): 5500fd1e1100001e8c0ad08a20e02d10
[ 13.273] (II) AMDGPU(0): 103e9600fd1e11000018000000000000
[ 13.273] (II) AMDGPU(0): 000000000000000000000000000000b5
[ 13.273] (II) AMDGPU(0): Printing probed modes for output HDMI-A-1
[ 13.273] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 13.273] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1440x900"x60.0 148.50 1440 2008 2052 2200 900 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x800"x60.0 148.50 1280 2008 2052 2200 800 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.273] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.273] (II) AMDGPU(0): Output DisplayPort-0 connected
[ 13.273] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 13.273] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 13.273] (II) AMDGPU(0): Output HDMI-A-1 connected
[ 13.273] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 13.273] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 1920x1080 +0+0
[ 13.273] (II) AMDGPU(0): Output HDMI-A-1 using initial mode 1920x1080 +1920+0
[ 13.273] (II) AMDGPU(0): mem size init: gart size :7d5c5c000 vram size: s:3f3186000 visible:3f3186000
[ 13.273] (==) AMDGPU(0): DPI set to (96, 96)
[ 13.273] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 13.273] (II) Loading sub module "ramdac"
[ 13.273] (II) LoadModule: "ramdac"
[ 13.273] (II) Module "ramdac" already built-in
[ 13.273] (II) UnloadModule: "radeon"
[ 13.273] (II) Unloading radeon
[ 13.273] (II) UnloadModule: "modesetting"
[ 13.273] (II) Unloading modesetting
[ 13.273] (II) AMDGPU(0): [DRI2] Setup complete
[ 13.273] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 13.273] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 13.301] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[ 13.302] (II) AMDGPU(0): SYNC extension fences enabled
[ 13.302] (II) AMDGPU(0): Present extension enabled
[ 13.302] (==) AMDGPU(0): DRI3 enabled
[ 13.302] (==) AMDGPU(0): Backing store enabled
[ 13.302] (II) AMDGPU(0): Direct rendering enabled
[ 13.322] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 13.322] (II) AMDGPU(0): Acceleration enabled
[ 13.322] (==) AMDGPU(0): DPMS enabled
[ 13.322] (==) AMDGPU(0): Silken mouse enabled
[ 13.322] (II) AMDGPU(0): Set up textured video (glamor)
[ 13.348] (WW) AMDGPU(0): Option "HotplugDriver" is not used
[ 13.348] (II) Initializing extension Generic Event Extension
[ 13.348] (II) Initializing extension SHAPE
[ 13.348] (II) Initializing extension MIT-SHM
[ 13.348] (II) Initializing extension XInputExtension
[ 13.348] (II) Initializing extension XTEST
[ 13.349] (II) Initializing extension BIG-REQUESTS
[ 13.349] (II) Initializing extension SYNC
[ 13.349] (II) Initializing extension XKEYBOARD
[ 13.349] (II) Initializing extension XC-MISC
[ 13.349] (II) Initializing extension SECURITY
[ 13.349] (II) Initializing extension XFIXES
[ 13.349] (II) Initializing extension RENDER
[ 13.349] (II) Initializing extension RANDR
[ 13.349] (II) Initializing extension COMPOSITE
[ 13.349] (II) Initializing extension DAMAGE
[ 13.349] (II) Initializing extension MIT-SCREEN-SAVER
[ 13.349] (II) Initializing extension DOUBLE-BUFFER
[ 13.349] (II) Initializing extension RECORD
[ 13.349] (II) Initializing extension DPMS
[ 13.349] (II) Initializing extension Present
[ 13.349] (II) Initializing extension DRI3
[ 13.349] (II) Initializing extension X-Resource
[ 13.350] (II) Initializing extension XVideo
[ 13.350] (II) Initializing extension XVideo-MotionCompensation
[ 13.350] (II) Initializing extension GLX
[ 13.354] (II) AIGLX: Loaded and initialized radeonsi
[ 13.354] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 13.354] (II) Initializing extension XFree86-VidModeExtension
[ 13.354] (II) Initializing extension XFree86-DGA
[ 13.354] (II) Initializing extension XFree86-DRI
[ 13.354] (II) Initializing extension DRI2
[ 13.355] (II) AMDGPU(0): Setting screen physical size to 1016 x 285
[ 13.440] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 13.440] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 13.440] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 13.440] (**) Power Button: Applying InputClass "system-keyboard"
[ 13.440] (II) LoadModule: "libinput"
[ 13.440] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 13.442] (II) Module libinput: vendor="X.Org Foundation"
[ 13.442] compiled for 1.21.1.8, module version = 1.4.0
[ 13.442] Module class: X.Org XInput Driver
[ 13.442] ABI class: X.Org XInput driver, version 24.4
[ 13.442] (II) Using input driver 'libinput' for 'Power Button'
[ 13.442] (**) Power Button: always reports core events
[ 13.442] (**) Option "Device" "/dev/input/event1"
[ 13.445] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 13.445] (II) event1 - Power Button: device is a keyboard
[ 13.445] (II) event1 - Power Button: device removed
[ 13.476] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 13.476] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 13.476] (**) Option "xkb_layout" "us"
[ 13.477] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 13.477] (II) event1 - Power Button: device is a keyboard
[ 13.477] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 13.477] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 13.477] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 13.477] (**) Power Button: Applying InputClass "system-keyboard"
[ 13.477] (II) Using input driver 'libinput' for 'Power Button'
[ 13.477] (**) Power Button: always reports core events
[ 13.477] (**) Option "Device" "/dev/input/event0"
[ 13.478] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 13.478] (II) event0 - Power Button: device is a keyboard
[ 13.478] (II) event0 - Power Button: device removed
[ 13.523] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 13.523] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 13.523] (**) Option "xkb_layout" "us"
[ 13.524] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 13.524] (II) event0 - Power Button: device is a keyboard
[ 13.524] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/event14)
[ 13.524] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[ 13.524] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[ 13.524] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[ 13.524] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[ 13.524] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 13.524] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[ 13.524] (**) Logitech MX Master 3: always reports core events
[ 13.524] (**) Option "Device" "/dev/input/event14"
[ 13.525] (II) event14 - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[ 13.526] (II) event14 - Logitech MX Master 3: device is a pointer
[ 13.526] (II) event14 - Logitech MX Master 3: device is a keyboard
[ 13.526] (II) event14 - Logitech MX Master 3: device removed
[ 13.573] (II) libinput: Logitech MX Master 3: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.573] (II) libinput: Logitech MX Master 3: needs a virtual subdevice
[ 13.573] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.2/1-7.2:1.2/0003:046D:C52B.0004/0003:046D:4082.0005/input/input29/event14"
[ 13.573] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: MOUSE, id 8)
[ 13.573] (**) Option "AccelerationScheme" "none"
[ 13.573] (**) Logitech MX Master 3: (accel) selected scheme none/0
[ 13.573] (**) Logitech MX Master 3: (accel) acceleration factor: 2.000
[ 13.573] (**) Logitech MX Master 3: (accel) acceleration threshold: 4
[ 13.575] (II) event14 - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[ 13.575] (II) event14 - Logitech MX Master 3: device is a pointer
[ 13.575] (II) event14 - Logitech MX Master 3: device is a keyboard
[ 13.576] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/mouse0)
[ 13.576] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 13.576] (II) No input driver specified, ignoring this device.
[ 13.576] (II) This device may have been added with another device file.
[ 13.577] (II) config/udev: Adding input device Logitech MX Keys (/dev/input/event15)
[ 13.577] (**) Logitech MX Keys: Applying InputClass "evdev keyboard catchall"
[ 13.577] (**) Logitech MX Keys: Applying InputClass "libinput keyboard catchall"
[ 13.577] (**) Logitech MX Keys: Applying InputClass "system-keyboard"
[ 13.577] (II) Using input driver 'libinput' for 'Logitech MX Keys'
[ 13.577] (**) Logitech MX Keys: always reports core events
[ 13.577] (**) Option "Device" "/dev/input/event15"
[ 13.578] (II) event15 - Logitech MX Keys: is tagged by udev as: Keyboard
[ 13.578] (II) event15 - Logitech MX Keys: device is a keyboard
[ 13.578] (II) event15 - Logitech MX Keys: device removed
[ 13.610] (II) libinput: Logitech MX Keys: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.610] (II) libinput: Logitech MX Keys: needs a virtual subdevice
[ 13.610] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.2/1-7.2:1.2/0003:046D:C52B.0004/0003:046D:408A.0006/input/input30/event15"
[ 13.610] (II) XINPUT: Adding extended input device "Logitech MX Keys" (type: MOUSE, id 9)
[ 13.610] (**) Option "AccelerationScheme" "none"
[ 13.610] (**) Logitech MX Keys: (accel) selected scheme none/0
[ 13.610] (**) Logitech MX Keys: (accel) acceleration factor: 2.000
[ 13.610] (**) Logitech MX Keys: (accel) acceleration threshold: 4
[ 13.611] (II) event15 - Logitech MX Keys: is tagged by udev as: Keyboard
[ 13.611] (II) event15 - Logitech MX Keys: device is a keyboard
[ 13.612] (II) config/udev: Adding input device Logitech MX Keys (/dev/input/mouse1)
[ 13.612] (**) Logitech MX Keys: Applying InputClass "system-keyboard"
[ 13.612] (II) No input driver specified, ignoring this device.
[ 13.612] (II) This device may have been added with another device file.
[ 13.612] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event3)
[ 13.613] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event4)
[ 13.613] (II) No input driver specified, ignoring this device.
[ 13.613] (II) This device may have been added with another device file.
[ 13.613] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event5)
[ 13.613] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event6)
[ 13.613] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event10)
[ 13.614] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event11)
[ 13.614] (II) No input driver specified, ignoring this device.
[ 13.614] (II) This device may have been added with another device file.
[ 13.614] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event12)
[ 13.614] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event13)
[ 13.614] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event7)
[ 13.615] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event8)
[ 13.615] (II) No input driver specified, ignoring this device.
[ 13.615] (II) This device may have been added with another device file.
[ 13.615] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event9)
[ 13.615] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event2)
[ 13.615] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 13.615] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 13.615] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 13.615] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 13.615] (**) Eee PC WMI hotkeys: always reports core events
[ 13.615] (**) Option "Device" "/dev/input/event2"
[ 13.615] (II) event2 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 13.616] (II) event2 - Eee PC WMI hotkeys: device is a keyboard
[ 13.616] (II) event2 - Eee PC WMI hotkeys: device removed
[ 13.700] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input2/event2"
[ 13.700] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 10)
[ 13.700] (**) Option "xkb_layout" "us"
[ 13.700] (II) event2 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 13.701] (II) event2 - Eee PC WMI hotkeys: device is a keyboard
[ 13.708] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[ 13.708] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[ 13.708] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[ 13.708] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[ 13.708] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 13.708] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[ 13.708] (**) Logitech MX Master 3: always reports core events
[ 13.708] (**) Option "Device" "/dev/input/event14"
[ 13.708] (II) libinput: Logitech MX Master 3: is a virtual subdevice
[ 13.708] (II) libinput: Logitech MX Master 3: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.708] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.2/1-7.2:1.2/0003:046D:C52B.0004/0003:046D:4082.0005/input/input29/event14"
[ 13.708] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: KEYBOARD, id 11)
[ 13.708] (**) Option "xkb_layout" "us"
[ 13.708] (**) Logitech MX Keys: Applying InputClass "evdev keyboard catchall"
[ 13.708] (**) Logitech MX Keys: Applying InputClass "libinput keyboard catchall"
[ 13.708] (**) Logitech MX Keys: Applying InputClass "system-keyboard"
[ 13.708] (II) Using input driver 'libinput' for 'Logitech MX Keys'
[ 13.708] (**) Logitech MX Keys: always reports core events
[ 13.708] (**) Option "Device" "/dev/input/event15"
[ 13.708] (II) libinput: Logitech MX Keys: is a virtual subdevice
[ 13.708] (II) libinput: Logitech MX Keys: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 13.708] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/usb1/1-7/1-7.2/1-7.2:1.2/0003:046D:C52B.0004/0003:046D:408A.0006/input/input30/event15"
[ 13.708] (II) XINPUT: Adding extended input device "Logitech MX Keys" (type: KEYBOARD, id 12)
[ 19.961] (II) AMDGPU(0): EDID vendor "DEL", prod id 53462
[ 19.961] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 19.961] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 19.961] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 19.961] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 19.961] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 19.961] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 20.425] (II) AMDGPU(0): EDID vendor "DEL", prod id 53462
[ 20.425] (II) AMDGPU(0): Using hsync ranges from config file
[ 20.425] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 20.425] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 20.425] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 20.425] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 20.425] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 24.663] (II) config/udev: Adding input device WH-1000XM5 (AVRCP) (/dev/input/event16)
[ 24.663] (**) WH-1000XM5 (AVRCP): Applying InputClass "evdev keyboard catchall"
[ 24.663] (**) WH-1000XM5 (AVRCP): Applying InputClass "libinput keyboard catchall"
[ 24.663] (**) WH-1000XM5 (AVRCP): Applying InputClass "system-keyboard"
[ 24.663] (II) Using input driver 'libinput' for 'WH-1000XM5 (AVRCP)'
[ 24.663] (**) WH-1000XM5 (AVRCP): always reports core events
[ 24.663] (**) Option "Device" "/dev/input/event16"
[ 24.663] (II) event16 - WH-1000XM5 (AVRCP): is tagged by udev as: Keyboard
[ 24.663] (II) event16 - WH-1000XM5 (AVRCP): device is a keyboard
[ 24.663] (II) event16 - WH-1000XM5 (AVRCP): device removed
[ 24.693] (**) Option "config_info" "udev:/sys/devices/virtual/input/input31/event16"
[ 24.693] (II) XINPUT: Adding extended input device "WH-1000XM5 (AVRCP)" (type: KEYBOARD, id 13)
[ 24.693] (**) Option "xkb_layout" "us"
[ 24.694] (II) event16 - WH-1000XM5 (AVRCP): is tagged by udev as: Keyboard
[ 24.694] (II) event16 - WH-1000XM5 (AVRCP): device is a keyboard
[ 28.109] (II) AMDGPU(0): EDID vendor "DEL", prod id 53462
[ 28.109] (II) AMDGPU(0): Using hsync ranges from config file
[ 28.109] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 28.109] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 28.109] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 28.109] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 28.109] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
