I installed Manjaro i3 few months ago. To play Steam games, I installed Vulkan, but when I run vulkaninfo it shows
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Failed to CreateInstance in ICD 0. Skipping ICD.
ERROR at /build/vulkan-tools/src/Vulkan-Tools-1.2.190/vulkaninfo/vulkaninfo.h:248:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
My GPU is an AMD Radeon R7 360, it should be Vulkan compatible.
I use Mesa drivers (https://archlinux.org/packages/?name=vulkan-radeon )
What could it be?
Welcome to the forum!
If you’re stuck with the legacy radeon driver, I’m afraid it is not compatible with Vulkan.
Please post your system info as outlined here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Thank you for your reply!
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=fbe23870-9f6c-46a5-8437-d147ae4111b6 rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F4 date: 01/25/2019
RAM: total: 7.78 GiB used: 1.93 GiB (24.8%)
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
bogomips: 102227
Speed: 1377 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 1377 2: 1378 3: 1377 4: 1384 5: 1377 6: 1375 7: 1515 8: 1546 9: 1377
10: 1379 11: 1377 12: 1381 13: 1373 14: 1372 15: 1377 16: 1381
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Tobago PRO [Radeon R7 360 / R9 360 OEM] vendor: ASUSTeK
driver: radeon v: kernel bus-ID: 06:00.0 chip-ID: 1002:665f class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.1x8.0")
s-diag: 412mm (16.2")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 216 size: 160x90mm (6.3x3.5")
diag: 184mm (7.2")
OpenGL: renderer: AMD BONAIRE (DRM 2.50.0 5.10.59-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.2.1 direct render: Yes
Device-1: AMD Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
vendor: ASUSTeK R7260X-DC2OC-2GD5 driver: snd_hda_intel v: kernel
bus-ID: 06:00.1 chip-ID: 1002:aac0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 08:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.96 TiB used: 62.82 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000VM003-1CT164
type: HDD rpm: 5900 serial: <filter> rev: SC23 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD2500JD-00HBB0
size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: 2D08 scheme: MBR
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 F rev: EL9M
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
used: 62.82 GiB (27.5%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: fbe23870-9f6c-46a5-8437-d147ae4111b6
ID-1: /dev/sda1 maj-min: 8:1 size: 350 MiB fs: ntfs
label: Reservado para el sistema uuid: D0C6FF29C6FF0E8A
ID-2: /dev/sda2 maj-min: 8:2 size: 976.05 GiB fs: ntfs label: N/A
uuid: 60A445D9A445B278
ID-3: /dev/sda3 maj-min: 8:3 size: 525 MiB fs: ntfs label: N/A
uuid: 9ED20D14D20CF277
ID-4: /dev/sda4 maj-min: 8:4 size: 886.11 GiB fs: ntfs label: N/A
uuid: 02AC8810AC880081
ID-5: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs
label: Reservado para el sistema uuid: 6AD861FAD861C4C3
ID-6: /dev/sdb2 maj-min: 8:18 size: 585.84 GiB fs: ntfs label: N/A
uuid: C652423652422B8D
ID-7: /dev/sdb3 maj-min: 8:19 size: 345.57 GiB fs: ntfs label: N/A
uuid: 7AFE60F1FE60A6DB
Device-1: 1-1:2 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: 16.8 C gpu: radeon temp: 49.0 C
Processes: 280 Uptime: 3h 13m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1251
lib: 372 Shell: Bash v: 5.1.8 running-in: urxvtd inxi: 3.3.06
tangra_m:
driver: radeon
As I mentioned above, Vulkan is not supported with the radeon driver.
However, you may be able to force it to use amdgpu. Install the amdgpu-experimental package and reboot. If it works, running inxi -G will now show driver: amdgpu.
If it does not boot properly, switch to a TTY, remove the package and reboot.
