Greetings.
Linux gaming is hard…
Then I’m trying to run native games in Vulkan, they just freeze or crash.
DotA 2 for example freezes in the menu after like 1 sec, but mouse pointer still works.
Also, none of non-native games run at all, using any version of Proton.
Game is “running” as my Steam states, but it doesn’t.
I use Steam for all my games.
Googled all the google, and nothing helps.
If I understand it properly according to the internet, Proton uses DXVK which is a Vulkan-based translation of DirectX, so my guess that Vulkan is the root of problem with Proton.
Please help me to have at least an acceptable gaming experience with Manjaro… I fell in love with this OS and it’s stability, but this issues make me cry
Of course I can just use OpenGL like I do now, but I really wonder if the Vulkan would make a difference, and still I’m not getting Proton games.
inxi -Fazy output
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=f9e30e18-ea52-4fa7-9c67-3a9b9fbd28e2 rw quiet
resume=UUID=1e56f1c3-1aca-4ea8-9555-5ec616b8f28e udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 20217 v: Lenovo IdeaPad Y510P
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad Y510P serial: <filter>
Mobo: LENOVO model: VIQY0Y1 v: 31900059STD serial: <filter> UEFI: LENOVO
v: 74CN47WW(V3.08) date: 1/30/2015
Info: Quad Core model: Intel Core i7-4700MQ bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 6 MiB
bogomips: 38328
Speed: 2396 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2396 2: 2395
3: 2395 4: 2400 5: 2395 6: 2399 7: 2396 8: 2395
Type: l1tf
Device-1: NVIDIA GK107M [GeForce GT 755M] vendor: Lenovo driver: nvidia
v: 390.141 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:0fcd
class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 755M] vendor: Lenovo driver: nvidia
v: 390.141 alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:0fcd
class-ID: 0302
Device-3: Syntek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 174f:1474 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1680x1050 s-dpi: 144 s-size: 297x185mm (11.7x7.3")
s-diag: 350mm (13.8")
Monitor-1: VGA-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7")
diag: 559mm (22")
OpenGL: renderer: GeForce GT 755M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.141
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Lenovo
driver: alx v: kernel port: 3000 bus-ID: 08:00.0 chip-ID: 1969:10a1
class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
port: 3000 bus-ID: 09:00.0 chip-ID: 8086:0888 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 3-7:5 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 931.51 GiB used: 117.22 GiB (12.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-SSHD-8GB
rotation: 5400 rpm serial: <filter> rev: LVD3 scheme: GPT
ID-1: / raw-size: 914.08 GiB size: 898.65 GiB (98.31%)
used: 117.22 GiB (13.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.14 GiB used: 1.5 MiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 267 Uptime: 11h 18m wakeups: 1 Memory: 15.58 GiB
used: 3.46 GiB (22.2%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1300 lib: 424 Shell: Bash
v: 5.1.0 running-in: konsole inxi: 3.3.03
vulkaninfo output
VULKANINFO
Vulkan Instance Version: 1.2.172
Instance Extensions: count = 14
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_display : extension revision 21
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 4
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (GeForce GT 755M)
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.2.136, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (GeForce GT 755M):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_UNORM
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_SRGB
Present Modes: count = 3
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
PRESENT_MODE_IMMEDIATE_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 2
maxImageCount = 8
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 1
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters: count = 0
None
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 4194369 (1.0.65)
driverVersion = 1638088704 (0x61a34000)
vendorID = 0x10de
deviceID = 0x0fcd
deviceType = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
deviceName = GeForce GT 755M
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 16384
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 65536
maxStorageBufferRange = 4294967295
maxPushConstantsSize = 256
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 4000
bufferImageGranularity = 0x00010000
sparseAddressSpaceSize = 0xffffffffffffffff
maxBoundDescriptorSets = 8
maxPerStageDescriptorSamplers = 4000
maxPerStageDescriptorUniformBuffers = 12
maxPerStageDescriptorStorageBuffers = 4096
maxPerStageDescriptorSampledImages = 16384
maxPerStageDescriptorStorageImages = 16384
maxPerStageDescriptorInputAttachments = 8
maxPerStageResources = 53268
maxDescriptorSetSamplers = 4000
maxDescriptorSetUniformBuffers = 72
maxDescriptorSetUniformBuffersDynamic = 72
maxDescriptorSetStorageBuffers = 4096
maxDescriptorSetStorageBuffersDynamic = 16
maxDescriptorSetSampledImages = 98304
maxDescriptorSetStorageImages = 98304
maxDescriptorSetInputAttachments = 8
maxVertexInputAttributes = 32
maxVertexInputBindings = 32
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 120
maxTessellationControlTotalOutputComponents = 4216
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 128
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 1024
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 128
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 16
maxComputeSharedMemorySize = 49152
maxComputeWorkGroupCount: count = 3
2147483647
65535
65535
maxComputeWorkGroupInvocations = 1536
maxComputeWorkGroupSize: count = 3
1536
1024
64
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 15
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32768
viewportSubPixelBits = 8
minMemoryMapAlignment = 64
minTexelBufferOffsetAlignment = 0x00000100
minUniformBufferOffsetAlignment = 0x00000100
minStorageBufferOffsetAlignment = 0x00000020
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferNoAttachmentsSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageDepthSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
storageImageSampleCounts: count = 4
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_2_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 1
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
1
189.875
lineWidthRange: count = 2
0.5
10
pointSizeGranularity = 0.125
lineWidthGranularity = 0.125
strictLines = true
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000001
optimalBufferCopyRowPitchAlignment = 0x00000001
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = true
residencyStandard2DMultisampleBlockShape = true
residencyStandard3DBlockShape = true
residencyAlignedMipSize = true
residencyNonResidentStrict = false
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
maxDiscardRectangles = 8
VkPhysicalDeviceIDPropertiesKHR:
deviceUUID = b7ac7687-469f-aec6-56f0-c2d54c9e245c
driverUUID = 26f0e5ec-2f09-7cc9-231d-0e8898648323
deviceNodeMask = 1
deviceLUIDValid = false
VkPhysicalDevicePointClippingPropertiesKHR:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
Device Extensions: count = 33
VK_EXT_depth_range_unrestricted : extension revision 1
VK_EXT_discard_rectangles : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_KHR_16bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_maintenance1 : extension revision 1
VK_KHR_maintenance2 : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 1
VK_KHR_sampler_ycbcr_conversion : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_variable_pointers : extension revision 1
VK_KHX_device_group : extension revision 2
VK_KHX_multiview : extension revision 1
VK_NVX_device_generated_commands : extension revision 3
VK_NVX_multiview_per_view_attributes : extension revision 1
VK_NV_dedicated_allocation : extension revision 1
VK_NV_glsl_shader : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 16
queueFlags = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
timestampValidBits = 64
present support = true
queueProperties[1]:
queueCount = 1
queueFlags = QUEUE_TRANSFER
present support = false
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 2
memoryHeaps[0]:
size = 2147483648 (0x80000000) (2.00 GiB)
budget = 0 (0x00000000) (0.00 B)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryHeaps[1]:
size = 12548293632 (0x2ebefc400) (11.69 GiB)
flags: count = 0
None
memoryTypes: count = 11
memoryTypes[0]:
heapIndex = 1
propertyFlags = 0x0000: count = 0
None
usable for:
IMAGE_TILING_OPTIMAL:
None
IMAGE_TILING_LINEAR:
color images
(non-sparse, non-transient)
memoryTypes[1]:
heapIndex = 1
None
usable for:
color images
(non-sparse)
None
memoryTypes[2]:
heapIndex = 1
None
usable for:
FORMAT_D16_UNORM
(non-sparse)
None
memoryTypes[3]:
heapIndex = 1
None
usable for:
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D24_UNORM_S8_UINT
(non-sparse)
None
memoryTypes[4]:
heapIndex = 1
None
usable for:
FORMAT_D32_SFLOAT
(non-sparse)
None
memoryTypes[5]:
heapIndex = 1
None
usable for:
FORMAT_D32_SFLOAT_S8_UINT
(non-sparse)
None
memoryTypes[6]:
heapIndex = 1
None
usable for:
None
None
memoryTypes[7]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
(non-sparse)
color images
memoryTypes[8]:
heapIndex = 0
usable for:
None
None
memoryTypes[9]:
heapIndex = 1
propertyFlags = 0x0006: count = 2
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
None
color images
memoryTypes[10]:
heapIndex = 1
propertyFlags = 0x000e: count = 3
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
None
color images
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = true
shaderStorageImageReadWithoutFormat = false
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = true
shaderInt64 = true
shaderInt16 = false
shaderResourceResidency = false
shaderResourceMinLod = false
sparseBinding = true
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeaturesKHR:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDeviceSamplerYcbcrConversionFeaturesKHR:
samplerYcbcrConversion = true
VkPhysicalDeviceVariablePointersFeaturesKHR:
variablePointersStorageBuffer = true
variablePointers = true
piece of Steam log when running game with Proton
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to ShowLaunchOption with ""
GameAction [AppID 235540, ActionID 3] : LaunchApp waiting for user response to ShowLaunchOption ""
wine client error:0: version mismatch 691/621.
Your wine binary was not upgraded correctly,
or you have an older one somewhere in your PATH.
Or maybe the wrong wineserver is still running?
File "/home/krvl1911/.local/share/Steam/steamapps/common/Proton 5.0/proton", line 712, in <module>
path = subprocess.check_output([g_proton.wine_bin, "winepath", "-w", sys.argv[2]], env=g_session.env, stderr=g_session.log_file)
File "/usr/lib/python3.9/subprocess.py", line 424, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/home/krvl1911/.local/share/Steam/steamapps/common/Proton 5.0/dist/bin/wine', 'winepath', '-w', '/home/krvl1911/.local/share/Steam/steamapps/common/Warhammer End Times Vermintide']' returned non-zero exit status 1.
subprocess.CalledProcessError: Command '['/home/krvl1911/.local/share/Steam/steamapps/common/Proton 5.0/dist/bin/wine', 'winepath', '-w', '/home/krvl1911/.local/share/Steam/steamapps/common/Steamworks Shared']' returned non-zero exit status 1.
src/clientdll/installscript_posix.cpp (357) : Assertion Failed: strCommonRedistForeignInstallPath != ""
Installing breakpad exception handler for appid(steam)/version(1616532526)
crash_20210402104759_52.dmp[18667]: Uploading dump (out-of-process)
/tmp/dumps/crash_20210402104759_52.dmp
crash_20210402104759_52.dmp[18667]: Finished uploading minidump (out-of-process): success = yes
crash_20210402104759_52.dmp[18667]: response: CrashID=bp-32000b6a-8ac6-4d08-b2d9-718832210401
crash_20210402104759_52.dmp[18667]: file ''/tmp/dumps/crash_20210402104759_52.dmp'', upload yes: ''CrashID=bp-32000b6a-8ac6-4d08-b2d9-718832210401''
GameAction [AppID 235540, ActionID 3] : LaunchApp continues with user response "1"
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to ProcessingShaderCache with ""
Fossilize INFO: Setting autogroup scheduling.
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 235540, ActionID 3] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 235540, ActionID 3] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 235540: 0
Game update: AppID 235540 "", ProcID 18691, IP 0.0.0.0:0
ERROR: ld.so: object '/home/krvl1911/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 235540
>>> Adding process 18691 for game ID 235540
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to WaitingGameWindow with ""
>>> Adding process 18692 for game ID 235540
GameAction [AppID 235540, ActionID 3] : LaunchApp changed task to Completed with ""
>>> Adding process 18693 for game ID 235540
