I am using Wayland fractional scaling. By default it starts in Xwayland and blurry. If I run it with the following command, it is not blurry, but it has no window border. Is this a bug of VS Code itself? Can it be fixed?
I think Wayland is close to be being usable. At least with GTK apps. It is mostly just apps that use other technologies like QT, Electron, Java, etc, that have problems. I had problems with X11, like screen tearing and no per-screen DPI, etc, so I do not want to go back.
Well, if there currently is no way to fix this, then I can just use it as it is until they finally fix it. I can still press alt+space and invoke the move command.
