I’m new to linux and i have a laptop with AMD A8-7410 APU with AMD Radeon R5 Graphics. If i check my vram memory size in Windows 10 ( I have a dual boot with manjaro ) is 1024M which can be extended to 2048M in BIOS . If i check my vram size in manjaro by running lspci -vv its showing me the result
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Mullins [Radeon R4/R5 Graphics] (rev 45) (prog-if 00 [VGA controller])
Subsystem: Hewlett-Packard Company Device 80cb
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 43
Region 0: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 2: Memory at f0000000 (64-bit, prefetchable) [size=8M]
Region 4: I/O ports at 3000 [size=256]
Region 5: Memory at f0d00000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
Its showing me that i just have 256M of vram.
IDK what to do.
Device: AMD KABINI (DRM 2.50.0, 5.10.56-1-MANJARO, LLVM 12.0.1) (0x9851)
Video memory: 1024MB
Unified memory: no
Dedicated video memory: 1024 MB
Total available memory: 3067 MB
Currently available dedicated video memory: 0 MB
Its showing me this. So , now manjaro have 1024M of VRAM ?
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 1454
Latency: 0
Interrupt: pin A routed to IRQ 29
Region 0: Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at e000 [size=128]
Expansion ROM at fe000000 [virtual] [disabled] [size=512K]
Kernel driver in use: nvidia
Oh wait no, i have more:
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 4096 MB
Currently available dedicated video memory: 3778 MB
