VPN Keeps asking for password
I’ve had surfshark vpn for 3 weeks. Started OK every time then yesterday at boot it keeps asking for the credential password. It rejects the password every time. Even in network manager if I add the password for all users it is still rejected. After pulling out a lot of hair I found a fix for linux (hopefully) here.
``https://support.surfshark.com/hc/en-us/articles/360021037760-How-to-configure-custom-DNS-on-a-Linux-device``
I’ve only rebooted a couple of times but it seems to be behaving. Hope it helps someone.
Back to the drawing board. It keeps asking for the password again. Damn.
Tried this:
``` ``How to disable IPv6 on a Linux device – Surfshark Customer Support `````
Disabling IPv6 seems to have “fixed” it. Rebooted 10 times without an issue.
Again I kept having the same issue. I’m running xfce.
Seems the issue is something to do with ‘networkmanager’. That was what was asking for the password even tough it was set for all users. As a work around I disabled auto connect in surfshark.
Now I boot up. Wait a few seconds then connect surfshark. Connects straight away. No issues.
Don’t believe it. Five minutes after posting the above the password prompt started again. Ahhhhhh.
I give up.
Mod edit:- Posts merged. No charge.
See #21: No Power-Posting/Empty Posts
So do you actually want help?
If so…
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Could it be related to a polkit rule?
polkit NetworkManager asks for root PW every time the VPN client connects or disconnects [solved]
I interpret that as abandoning the topic; it will now be closed.
@Hipster
If you still require assistance with your issue please ask a Moderation staff member (via PM) to re-open this topic.
Also, please note the link kindly given by @limprimble which may potentially lead you toward a resolution.
