Vpn connection problem
Today my vpn can’t connect `journalctl -b -u NetworkManager --no-hostname --no-pager
-- Logs begin at Sun 2020-11-15 22:19:26 EET, end at Wed 2020-11-18 16:26:13 EET. --
Νοε 18 16:07:11 systemd[1]: Starting Network Manager...
Νοε 18 16:07:11 NetworkManager[546]: <info>  [1605708431.7772] NetworkManager (version 1.26.4-1) is starting... (for the first time)
Νοε 18 16:07:11 NetworkManager[546]: <info>  [1605708431.7773] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Νοε 18 16:07:11 systemd[1]: Started Network Manager.
Νοε 18 16:07:11 NetworkManager[546]: <info>  [1605708431.8023] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Νοε 18 16:07:11 NetworkManager[546]: <info>  [1605708431.8133] manager[0x55c848d1e030]: monitoring kernel firmware directory '/lib/firmware'.
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3293] hostname: hostname: using hostnamed
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3293] hostname: hostname changed from (none) to "kostas-w251esqw270esq"
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3301] dns-mgr[0x55c848cf7220]: init: dns=default,systemd-resolved rc-manager=symlink
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3324] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0/ieee80211/phy0/rfkill0) (driver rtl8723ae)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3327] manager[0x55c848d1e030]: rfkill: Wi-Fi hardware radio set disabled
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3328] manager[0x55c848d1e030]: rfkill: WWAN hardware radio set enabled
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3469] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-ovs.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3489] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wifi.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3521] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wwan.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3660] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-team.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3672] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-adsl.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3699] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-bluetooth.so)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3705] manager: rfkill: Wi-Fi disabled by radio killswitch; disabled by state file
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3706] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3708] manager: Networking is enabled by state file
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3718] dhcp-init: Using DHCP client 'internal'
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3729] settings: Loaded settings plugin: keyfile (internal)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3773] device (lo): carrier: link connected
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3776] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3792] manager: (enp5s0f2): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3821] settings: (enp5s0f2): created default wired connection 'Ενσύρματη σύνδεση 1'
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.3830] device (enp5s0f2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.5854] device (wlp4s0): driver supports Access Point (AP) mode
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.5865] manager: (wlp4s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.5885] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.5896] device (wlp4s0): set-hw-addr: set MAC address to 36:BB:C6:D4:C1:9E (scanning)
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.6012] ovsdb: Αδυναμία σύνδεσης: Δεν υπάρχει τέτοιο αρχείο ή κατάλογος
Νοε 18 16:07:12 NetworkManager[546]: <info>  [1605708432.6088] modem-manager: ModemManager available
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7297] device (enp5s0f2): carrier: link connected
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7302] device (enp5s0f2): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7313] policy: auto-activating connection 'Ενσύρματη σύνδεση 1' (c5ea2dfb-613c-353f-b5de-da5365cf5d09)
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7322] device (enp5s0f2): Activation: starting connection 'Ενσύρματη σύνδεση 1' (c5ea2dfb-613c-353f-b5de-da5365cf5d09)
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7324] device (enp5s0f2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7330] manager: NetworkManager state is now CONNECTING
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7333] device (enp5s0f2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7340] device (enp5s0f2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:14 NetworkManager[546]: <info>  [1605708434.7376] dhcp4 (enp5s0f2): activation: beginning transaction (timeout in 45 seconds)
Νοε 18 16:07:17 NetworkManager[546]: <info>  [1605708437.0632] agent-manager: agent[d3f76f9d50260a92,:1.36/org.freedesktop.nm-applet/1000]: agent registered
Νοε 18 16:07:17 NetworkManager[546]: <info>  [1605708437.1871] dhcp6 (enp5s0f2): activation: beginning transaction (timeout in 45 seconds)
Νοε 18 16:07:17 NetworkManager[546]: <info>  [1605708437.2090] dhcp6 (enp5s0f2): option dhcp6_name_servers   => 'fe80::1'
Νοε 18 16:07:17 NetworkManager[546]: <info>  [1605708437.2091] dhcp6 (enp5s0f2): state changed unknown -> bound
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.2890] device (enp5s0f2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.2940] device (enp5s0f2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.2956] device (enp5s0f2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.2987] manager: NetworkManager state is now CONNECTED_LOCAL
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.3039] manager: NetworkManager state is now CONNECTED_SITE
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.3046] policy: set 'Ενσύρματη σύνδεση 1' (enp5s0f2) as default for IPv6 routing and DNS
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.3149] device (enp5s0f2): Activation: successful, device activated.
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.3177] manager: startup complete
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.4489] manager: NetworkManager state is now CONNECTED_GLOBAL
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7725] dhcp4 (enp5s0f2): option dhcp_lease_time      => '86400'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7726] dhcp4 (enp5s0f2): option domain_name_servers  => '192.168.1.1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7726] dhcp4 (enp5s0f2): option expiry               => '1605794836'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7727] dhcp4 (enp5s0f2): option ip_address           => '192.168.1.8'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7727] dhcp4 (enp5s0f2): option requested_broadcast_address => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7727] dhcp4 (enp5s0f2): option requested_domain_name => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7728] dhcp4 (enp5s0f2): option requested_domain_name_servers => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7728] dhcp4 (enp5s0f2): option requested_domain_search => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7728] dhcp4 (enp5s0f2): option requested_host_name  => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7729] dhcp4 (enp5s0f2): option requested_interface_mtu => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7729] dhcp4 (enp5s0f2): option requested_ms_classless_static_routes => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7729] dhcp4 (enp5s0f2): option requested_nis_domain => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7730] dhcp4 (enp5s0f2): option requested_nis_servers => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7730] dhcp4 (enp5s0f2): option requested_ntp_servers => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7730] dhcp4 (enp5s0f2): option requested_rfc3442_classless_static_routes => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7731] dhcp4 (enp5s0f2): option requested_root_path  => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7731] dhcp4 (enp5s0f2): option requested_routers    => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7731] dhcp4 (enp5s0f2): option requested_static_routes => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7732] dhcp4 (enp5s0f2): option requested_subnet_mask => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7732] dhcp4 (enp5s0f2): option requested_time_offset => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7732] dhcp4 (enp5s0f2): option requested_wpad       => '1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7733] dhcp4 (enp5s0f2): option routers              => '192.168.1.1'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7733] dhcp4 (enp5s0f2): option subnet_mask          => '255.255.255.0'
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7733] dhcp4 (enp5s0f2): state changed unknown -> bound
Νοε 18 16:07:18 NetworkManager[546]: <info>  [1605708438.7767] policy: set 'Ενσύρματη σύνδεση 1' (enp5s0f2) as default for IPv4 routing and DNS
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.0729] audit: op="connection-activate" uuid="23b4bff7-28ce-4916-b659-c8e6ec8226ef" name="Σύνδεση VPN 1" pid=1052 uid=1000 result="success"
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.0795] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Started the VPN service, PID 1264
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.0919] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Saw the service appear; activating connection
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.1235] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN connection: (ConnectInteractive) reply received
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.2466] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: starting (3)
Νοε 18 16:07:46 pppd[1270]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:07:46 NetworkManager[1270]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:07:46 pppd[1270]: pppd 2.4.7 started by root, uid 0
Νοε 18 16:07:46 pppd[1270]: Using interface ppp0
Νοε 18 16:07:46 NetworkManager[1270]: Using interface ppp0
Νοε 18 16:07:46 NetworkManager[1270]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:07:46 pppd[1270]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:07:46 NetworkManager[546]: <info>  [1605708466.2809] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/4)
Νοε 18 16:07:46 pptp[1275]: nm-pptp-service-1264 log[main:pptp.c:353]: The synchronous pptp option is NOT activated
Νοε 18 16:08:17 pppd[1270]: LCP: timeout sending Config-Requests
Νοε 18 16:08:17 NetworkManager[1270]: LCP: timeout sending Config-Requests
Νοε 18 16:08:17 NetworkManager[1270]: Connection terminated.
Νοε 18 16:08:17 pppd[1270]: Connection terminated.
Νοε 18 16:08:17 NetworkManager[546]: <warn>  [1605708497.3106] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: failed: connect-failed (1)
Νοε 18 16:08:17 NetworkManager[546]: <info>  [1605708497.3107] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: stopping (5)
Νοε 18 16:08:17 NetworkManager[546]: <info>  [1605708497.3134] vpn-connection[0x55c848df40d0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN service disappeared
Νοε 18 16:08:17 pppd[1270]: Terminating on signal 15
Νοε 18 16:08:17 NetworkManager[1270]: Terminating on signal 15
Νοε 18 16:08:17 NetworkManager[1270]: Modem hangup
Νοε 18 16:08:17 pppd[1270]: Modem hangup
Νοε 18 16:08:17 pppd[1270]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1264 (pid 1275) terminated with signal 15
Νοε 18 16:08:17 NetworkManager[1270]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1264 (pid 1275) terminated with signal 15
Νοε 18 16:08:17 pppd[1270]: Exit.
Νοε 18 16:09:56 NetworkManager[1278]: nm-pptp-service-1264 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:09:56 NetworkManager[1278]: nm-pptp-service-1264 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:09:56 pptp[1278]: nm-pptp-service-1264 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:09:56 pptp[1278]: nm-pptp-service-1264 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.7729] audit: op="connection-activate" uuid="23b4bff7-28ce-4916-b659-c8e6ec8226ef" name="Σύνδεση VPN 1" pid=1052 uid=1000 result="success"
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.7780] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Started the VPN service, PID 1397
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.7898] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Saw the service appear; activating connection
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.7965] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN connection: (ConnectInteractive) reply received
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.8982] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: starting (3)
Νοε 18 16:12:27 pppd[1401]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:12:27 NetworkManager[1401]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:12:27 pppd[1401]: pppd 2.4.7 started by root, uid 0
Νοε 18 16:12:27 pppd[1401]: Using interface ppp0
Νοε 18 16:12:27 NetworkManager[1401]: Using interface ppp0
Νοε 18 16:12:27 pptp[1404]: nm-pptp-service-1397 log[main:pptp.c:353]: The synchronous pptp option is NOT activated
Νοε 18 16:12:27 pppd[1401]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:12:27 NetworkManager[546]: <info>  [1605708747.9155] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/5)
Νοε 18 16:12:27 NetworkManager[1401]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:12:58 pppd[1401]: LCP: timeout sending Config-Requests
Νοε 18 16:12:58 NetworkManager[1401]: LCP: timeout sending Config-Requests
Νοε 18 16:12:58 NetworkManager[1401]: Connection terminated.
Νοε 18 16:12:58 pppd[1401]: Connection terminated.
Νοε 18 16:12:58 NetworkManager[546]: <warn>  [1605708778.9426] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: failed: connect-failed (1)
Νοε 18 16:12:58 NetworkManager[546]: <info>  [1605708778.9427] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: stopping (5)
Νοε 18 16:12:58 NetworkManager[546]: <info>  [1605708778.9427] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: stopped (6)
Νοε 18 16:12:58 NetworkManager[546]: <info>  [1605708778.9476] vpn-connection[0x55c848df42e0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN service disappeared
Νοε 18 16:12:58 pppd[1401]: Terminating on signal 15
Νοε 18 16:12:58 NetworkManager[1401]: Terminating on signal 15
Νοε 18 16:12:58 NetworkManager[1401]: Modem hangup
Νοε 18 16:12:58 NetworkManager[1401]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1397 (pid 1404) terminated with signal 15
Νοε 18 16:12:58 pppd[1401]: Modem hangup
Νοε 18 16:12:58 pppd[1401]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1397 (pid 1404) terminated with signal 15
Νοε 18 16:12:58 pppd[1401]: Exit.
Νοε 18 16:14:38 NetworkManager[1406]: nm-pptp-service-1397 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:14:38 NetworkManager[1406]: nm-pptp-service-1397 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:14:38 pptp[1406]: nm-pptp-service-1397 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:14:38 pptp[1406]: nm-pptp-service-1397 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:18:06 NetworkManager[546]: <info>  [1605709086.5342] audit: op="connection-update" uuid="c5ea2dfb-613c-353f-b5de-da5365cf5d09" name="Ενσύρματη σύνδεση 1" args="802-3-ethernet.auto-negotiate,802-3-ethernet.mtu,connection.timestamp,ipv6.ip6-privacy" pid=1860 uid=1000 result="success"
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.7674] audit: op="connection-activate" uuid="23b4bff7-28ce-4916-b659-c8e6ec8226ef" name="Σύνδεση VPN 1" pid=1052 uid=1000 result="success"
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.7799] vpn-connection[0x55c848df44f0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Started the VPN service, PID 1949
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.7878] vpn-connection[0x55c848df44f0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Saw the service appear; activating connection
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.7951] vpn-connection[0x55c848df44f0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN connection: (ConnectInteractive) reply received
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.8962] vpn-connection[0x55c848df44f0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: starting (3)
Νοε 18 16:18:13 pppd[1953]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:18:13 NetworkManager[1953]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:18:13 pppd[1953]: pppd 2.4.7 started by root, uid 0
Νοε 18 16:18:13 NetworkManager[546]: <info>  [1605709093.9088] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/6)
Νοε 18 16:18:13 pppd[1953]: Using interface ppp0
Νοε 18 16:18:13 NetworkManager[1953]: Using interface ppp0
Νοε 18 16:18:13 pppd[1953]: Connect: ppp0 <--> /dev/pts/1
Νοε 18 16:18:13 NetworkManager[1953]: Connect: ppp0 <--> /dev/pts/1
Νοε 18 16:18:13 pptp[1956]: nm-pptp-service-1949 log[main:pptp.c:353]: The synchronous pptp option is NOT activated
Νοε 18 16:18:44 pppd[1953]: LCP: timeout sending Config-Requests
Νοε 18 16:18:44 NetworkManager[1953]: LCP: timeout sending Config-Requests
Νοε 18 16:18:44 NetworkManager[1953]: Connection terminated.
Νοε 18 16:18:44 pppd[1953]: Connection terminated.
Νοε 18 16:18:44 NetworkManager[546]: <info>  [1605709124.9401] vpn-connection[0x55c848df44f0,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN service disappeared
Νοε 18 16:18:44 pppd[1953]: Terminating on signal 15
Νοε 18 16:18:44 pppd[1953]: Modem hangup
Νοε 18 16:18:44 NetworkManager[1953]: Terminating on signal 15
Νοε 18 16:18:44 NetworkManager[1953]: Modem hangup
Νοε 18 16:18:44 NetworkManager[1953]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1949 (pid 1956) terminated with signal 15
Νοε 18 16:18:44 pppd[1953]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-1949 (pid 1956) terminated with signal 15
Νοε 18 16:18:44 pppd[1953]: Exit.
Νοε 18 16:20:22 NetworkManager[1959]: nm-pptp-service-1949 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:20:22 NetworkManager[1959]: nm-pptp-service-1949 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:20:22 pptp[1959]: nm-pptp-service-1949 warn[open_inetsock:pptp_callmgr.c:352]: connect: Connection timed out
Νοε 18 16:20:22 pptp[1959]: nm-pptp-service-1949 fatal[callmgr_main:pptp_callmgr.c:134]: Could not open control connection to 172.111.227.1
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.2888] audit: op="connection-activate" uuid="23b4bff7-28ce-4916-b659-c8e6ec8226ef" name="Σύνδεση VPN 1" pid=1052 uid=1000 result="success"
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.2944] vpn-connection[0x55c848df4700,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Started the VPN service, PID 2387
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.3107] vpn-connection[0x55c848df4700,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: Saw the service appear; activating connection
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.3175] vpn-connection[0x55c848df4700,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN connection: (ConnectInteractive) reply received
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.4188] vpn-connection[0x55c848df4700,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN plugin: state changed: starting (3)
Νοε 18 16:25:42 pppd[2391]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:25:42 NetworkManager[2391]: Plugin /usr/lib/pppd/2.4.7/nm-pptp-pppd-plugin.so loaded.
Νοε 18 16:25:42 pppd[2391]: pppd 2.4.7 started by root, uid 0
Νοε 18 16:25:42 NetworkManager[546]: <info>  [1605709542.4349] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/7)
Νοε 18 16:25:42 pppd[2391]: Using interface ppp0
Νοε 18 16:25:42 NetworkManager[2391]: Using interface ppp0
Νοε 18 16:25:42 NetworkManager[2391]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:25:42 pppd[2391]: Connect: ppp0 <--> /dev/pts/0
Νοε 18 16:25:42 pptp[2394]: nm-pptp-service-2387 log[main:pptp.c:353]: The synchronous pptp option is NOT activated
Νοε 18 16:26:13 pppd[2391]: LCP: timeout sending Config-Requests
Νοε 18 16:26:13 NetworkManager[2391]: LCP: timeout sending Config-Requests
Νοε 18 16:26:13 NetworkManager[2391]: Connection terminated.
Νοε 18 16:26:13 pppd[2391]: Connection terminated.
Νοε 18 16:26:13 NetworkManager[546]: <info>  [1605709573.4616] vpn-connection[0x55c848df4700,23b4bff7-28ce-4916-b659-c8e6ec8226ef,"Σύνδεση VPN 1",0]: VPN service disappeared
Νοε 18 16:26:13 pppd[2391]: Terminating on signal 15
Νοε 18 16:26:13 NetworkManager[2391]: Terminating on signal 15
Νοε 18 16:26:13 NetworkManager[2391]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-2387 (pid 2394) terminated with signal 15
Νοε 18 16:26:13 NetworkManager[2391]: Modem hangup
Νοε 18 16:26:13 pppd[2391]: Child process /sbin/pptp 172.111.227.1 --nolaunchpppd --loglevel 0 --logstring nm-pptp-service-2387 (pid 2394) terminated with signal 15
Νοε 18 16:26:13 pppd[2391]: Modem hangup
Νοε 18 16:26:13 pppd[2391]: Exit.
Try downgrading openvpn as mentioned in the Testing Update thread.
He’s using pptp though.
You are right. It seems pptp has not been updated in the last year, so maybe it’s a library issue.
iproute2 was updated recently and is a dependency of pptp. /shrug
what i should do?
Try using Ivacy vpn, it will surely solve the problem.
How do I do that?
