I am having some problems with the volume control. The volume seems to jump suddenly from minimum to maximum, without being able to set intermediate values.
Hi there,
Please see this guide on how to post and then include some basic system information,
such as by inxi -Fazy
And, @GrandFunkR – Welcome to the Manjaro forum.
Please post more information about audio cards and output sinks
pactl list cards; pactl list sinks
Thanks for your patience, I’ll try to provide some additional information
pactl list cards; pactl list sinks 2 ✘
Card #0
Driver: module-alsa-card.c
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0x987c8000 irq 84"
device.bus_path = "pci-0000:72:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:72:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "1640"
device.product.name = "Rembrandt Radeon High Definition Audio Controller"
device.string = "0"
device.description = "Rembrandt Radeon High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
Card #1
Owner Module: 7
Properties:
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0x987c0000 irq 85"
device.bus_path = "pci-0000:72:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:72:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h HD Audio Controller"
device.string = "1"
device.description = "Family 17h/19h HD Audio Controller"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 34068, available: yes)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34133, available: yes)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 33968, available: yes)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 34033, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, not available)
Properties:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
Properties:
Sink #0
State: SUSPENDED
Description: Family 17h/19h HD Audio Controller Analog Stereo
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 7
Mute: no
Volume: front-left: 313 / 0% / -139,26 dB, front-right: 313 / 0% / -139,26 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: alsa_output.pci-0000_72_00.6.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC287 Analog"
alsa.id = "ALC287 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "front:1"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h/19h HD Audio Controller Analog Stereo"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, not available)
Active Port: analog-output-speaker
Formats:
pcm
inxi -Fazy ✔
Kernel: 6.6.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=366ac5b7-b513-4c57-861f-778160378270 rw quiet splash apparmor=1
security=apparmor resume=UUID=8b13c4f3-43fc-4353-a568-23c02297cd67
udev.log_priority=3
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: LENOVO product: 83AU v: Yoga Pro 7 14ARP8
serial: <superuser required> Chassis: type: 10 v: Yoga Pro 7 14ARP8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: LNCN17WW date: 03/14/2023
ID-1: BAT0 charge: 22.7 Wh (31.0%) condition: 73.2/73.0 Wh (100.2%)
power: 7.5 W volts: 15.1 min: 15.5 model: Sunwoda L22D4PF4 type: Li-poly
serial: <filter> status: discharging cycles: 5
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 591 high: 1495 min/max: 400/4829 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 1495 7: 1366 8: 400 9: 400 10: 400 11: 1397 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 102251
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, HDMI-A-1 bus-ID: 72:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 37.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 174f:181d
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x7aa7 built: 2022 res: 2560x1600
dpi: 208 gamma: 1.2 size: 312x195mm (12.28x7.68") diag: 368mm (14.5")
ratio: 16:10 modes: max: 2560x1600 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.6.7-1-MANJARO) device-ID: 1002:1681 memory: 1.95 GiB
unified: no display-ID: :0.0
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 72:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 72:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 72:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: 1: pipewire-media-session
status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Bluetooth Adapter driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0489:e0d8
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 40.47 GiB (8.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk
model: SKHynix HFS512GEJ4X112N size: 476.94 GiB block-size: physical: 512 B
fw-rev: 51030C31 temp: 28.9 C scheme: GPT
ID-1: / raw-size: 461.96 GiB size: 453.64 GiB (98.20%) used: 40.44 GiB (8.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 32.3 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 14.68 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 39.5 C mobo: 30.0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): N/A
Processes: 350 Uptime: 1d 3h 52m wakeups: 11 Memory: total: 16 GiB note: est.
available: 13.34 GiB used: 3.91 GiB (29.3%) Init: systemd v: 254
Packages: 1397 pm: pacman pkgs: 1385 libs: 441
tools: gnome-software,pamac,yay pm: flatpak pkgs: 12 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.31
solved.
edited this file:
/usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf.common
changed from:
[Element PCM]
switch = mute
volume = merge
override-map.1 = all
override-map.2 = all-left,all-right
to:
[Element PCM]
switch = mute
volume = ignore
volume-limit = 0.01
