I noticed since the Anh-Linh update VMware Workstation has been exhibiting some instability, notably the session minimizing etc. I decided to try X11 instead of Wayland. This seems to have solved the problem.
As noted in other posts X11 SDDM screen menu option can be installed using
Just remember it is a temporary solution and in about one year Plasma will throw x11 completely out of the window.
But maybe until then something in vmware will be updated.
