VMware virtual network problem
Hello,
Recently I installed VMware using help from the official wiki page for it, and it works fine for running Windows 10 x64 inside a virtual machine, however it can’t connect to the network. Here are the errors I encounter:
from VMware Player:
Could not connect ‘Ethernet0’ to virtual network ‘/dev/vmnet1’.
Virtual devide ‘Ethernet0’ will start disconnected.
from VMware Workstation when trying to open Virtual Network Editor:
Fail
Network configuration is missing. Ensure that /etc/vmware/networking exists.
Doing the things mentioned in the following logs like starting some services didn’t change or fix the problem.
Any help would be appreciated.
System Information ( inxi ):
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=e7163391-d960-41ec-b9b2-63ffdbfd518d rw quiet
  cryptdevice=UUID=d9153841-42fb-46e0-9b03-2ede24fa9ae9:luks-d9153841-42fb-46e0-9b03-2ede24fa9ae9
  root=/dev/mapper/luks-d9153841-42fb-46e0-9b03-2ede24fa9ae9 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-14281edd-92f6-482c-b728-97bfe1826474
  udev.log_priority=3
  Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <filter>
  UEFI: American Megatrends v: X556UQK.315 date: 01/24/2019
  ID-1: BAT0 charge: 17.4 Wh condition: 17.4/38.0 Wh (46%) volts: 7.6/7.6
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
  cycles: 439
  Topology: Dual Core model: Intel Core i5-7200U socket: U3E1 bits: 64
  type: MT MCP arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9
  microcode: D6 L1 cache: 128 KiB L2 cache: 3072 KiB L3 cache: 3072 KiB
  bogomips: 21607
  Speed: 500 MHz min/max: 400/3100 MHz base/boost: 2400/8300 volts: 0.8 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5916
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:134d
  Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus ID: 1-6:4 chip ID: 13d3:5a01 serial: <filter>
  Display: server: X.Org 1.20.9 driver: intel,nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.8
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 02:00.0
  chip ID: 10ec:8168
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: AzureWave driver: ath10k_pci v: kernel port: d000 bus ID: 03:00.0
  chip ID: 168c:0042
  Local Storage: total: 931.51 GiB used: 60.66 GiB (6.5%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
  ID-1: / raw size: 918.47 GiB size: 903.06 GiB (98.32%)
  used: 60.65 GiB (6.7%) fs: ext4 block size: 4096 B dev: /dev/dm-0
  ID-1: swap-1 type: partition size: 12.74 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/dm-1
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2600
  Processes: 208 Uptime: 48m Memory: 11.58 GiB used: 2.37 GiB (20.5%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1116 lib: 340
  flatpak: 0 Shell: Bash (sudo) v: 5.0.18 running in: xfce4-terminal
  inxi: 3.1.05
System Logs ( dmesg , journalctl , /var/log/ ):
Only emergency, alert, critical, error, warn messages.
dmesg:
[    0.000000] [Firmware Bug]: TSC ADJUST: CPU0: -31231432 force to 0
[    0.004016] [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
[    0.112897]  #2
[    0.112940] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.112940]  #3
[    0.116646] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.661615] efifb: Ignoring BGRT: unexpected or invalid BMP data
[    1.500027] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[   15.089369] vboxdrv: loading out-of-tree module taints kernel.
[   15.122013] VBoxNetAdp: Successfully started.
[   15.124222] VBoxNetFlt: Successfully started.
[   18.026432] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[   18.026438] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[   18.384858] elan_i2c i2c-ELAN1000:00: supply vcc not found, using dummy regulator
[   18.718340] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[   19.902388] MXM: GUID detected in BIOS
[   19.902458] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200528/nsarguments-59)
[   19.902578] ACPI Warning: \_SB.PCI0.RP01.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200528/nsarguments-59)
[   20.005648] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[   22.795616] uvcvideo 1-6:1.0: Entity type for entity Extension 4 was not initialized!
[   22.795623] uvcvideo 1-6:1.0: Entity type for entity Processing 2 was not initialized!
[   22.795628] uvcvideo 1-6:1.0: Entity type for entity Camera 1 was not initialized!
[   24.387785] kauditd_printk_skb: 8 callbacks suppressed
[   29.411599] kauditd_printk_skb: 10 callbacks suppressed
[   32.407598] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[   35.256360] kauditd_printk_skb: 1 callbacks suppressed
[   41.045142] kauditd_printk_skb: 1 callbacks suppressed
[   60.313857] kauditd_printk_skb: 9 callbacks suppressed
[ 1185.467587] kauditd_printk_skb: 1 callbacks suppressed
[ 1358.843543] kauditd_printk_skb: 1 callbacks suppressed
[ 1924.484827] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2135.681337] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2666.571891] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2732.724742] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2830.907881] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2868.724495] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
[ 2908.887876] nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
journalctl:
-- Logs begin at Sun 2020-10-18 21:41:21 +0330, end at Mon 2020-10-19 19:22:41 +0330. --
Oct 18 21:41:23 mypc kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Oct 18 21:41:25 mypc kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
Oct 18 21:41:32 mypc kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 619444 [ IBUS ]
Oct 18 21:42:20 mypc lightdm[1032]: pam_systemd_home(lightdm:auth): User name not set.
Oct 18 21:44:39 mypc lightdm[1033]: gkr-pam: unable to locate daemon control file
Oct 18 21:48:23 mypc kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
Oct 18 21:48:23 mypc systemd-cryptsetup[1814]: Device luks-d9153841-42fb-46e0-9b03-2ede24fa9ae9 is still in use.
Oct 18 21:48:23 mypc systemd-cryptsetup[1814]: Failed to deactivate: Device or resource busy
Oct 18 21:48:24 mypc systemd-cryptsetup[1822]: device-mapper: remove ioctl on luks-14281edd-92f6-482c-b728-97bfe1826474  failed: Device or resource busy
Oct 18 21:48:24 mypc kernel: watchdog: watchdog0: watchdog did not stop!
$ cat/var/log/pacman.log:
[2020-10-19T00:56:37+0330] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2020-10-19T00:56:37+0330] [PACMAN] synchronizing package lists
[2020-10-19T00:56:38+0330] [ALPM] transaction started
[2020-10-19T00:56:38+0330] [ALPM] installed xf86-video-ati (1:19.1.0-2)
[2020-10-19T00:56:38+0330] [ALPM] installed xf86-video-amdgpu (19.1.0-2)
[2020-10-19T00:56:38+0330] [ALPM] installed libxvmc (1.0.12-3)
[2020-10-19T00:56:38+0330] [ALPM] installed xf86-video-intel (1:2.99.917+908+g7181c5a4-1)
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET] >>> This driver now uses DRI3 as the default Direct Rendering
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]     Infrastructure. You can try falling back to DRI2 if you run
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]     into trouble. To do so, save a file with the following
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]     content as /etc/X11/xorg.conf.d/20-intel.conf :
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]       Section "Device"
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]         Identifier  "Intel Graphics"
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]         Driver      "intel"
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]         Option      "DRI" "2"             # DRI3 is now default
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]         #Option      "AccelMethod"  "sna" # default
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]         #Option      "AccelMethod"  "uxa" # fallback
[2020-10-19T00:56:38+0330] [ALPM-SCRIPTLET]       EndSection
[2020-10-19T00:56:38+0330] [ALPM] installed xf86-video-nouveau (1.0.16-2)
[2020-10-19T00:56:38+0330] [ALPM] installed vulkan-intel (20.1.8-1)
[2020-10-19T00:56:38+0330] [ALPM] installed vulkan-radeon (20.1.8-1)
[2020-10-19T00:56:38+0330] [ALPM] installed mesa-vdpau (20.1.8-1)
[2020-10-19T00:56:38+0330] [ALPM] installed lib32-vulkan-intel (20.1.8-1)
[2020-10-19T00:56:38+0330] [ALPM] installed lib32-vulkan-radeon (20.1.8-1)
[2020-10-19T00:56:38+0330] [ALPM] installed lib32-mesa-vdpau (20.1.8-1)
[2020-10-19T00:56:43+0330] [ALPM] transaction completed
[2020-10-19T00:56:43+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T00:56:43+0330] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau'
[2020-10-19T00:57:49+0330] [PACMAN] Running 'pacman -Syy'
[2020-10-19T00:57:49+0330] [PACMAN] synchronizing package lists
[2020-10-19T00:58:14+0330] [PACMAN] Running 'pacman -R --noconfirm amd-ucode'
[2020-10-19T00:58:14+0330] [ALPM] transaction started
[2020-10-19T00:58:15+0330] [ALPM] removed amd-ucode (20200923.r1716.afbfb5f-1)
[2020-10-19T00:58:16+0330] [ALPM] transaction completed
[2020-10-19T00:58:16+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T00:58:21+0330] [PACMAN] Running 'pacman -S --noconfirm --config /opt/mhwd/pacman-mhwd.conf libreoffice-still'
[2020-10-19T00:58:28+0330] [ALPM] transaction started
[2020-10-19T00:58:28+0330] [ALPM] installed librevenge (0.0.4-3)
[2020-10-19T00:58:29+0330] [ALPM] installed libwpd (0.10.3-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libwps (0.4.12-1)
[2020-10-19T00:58:29+0330] [ALPM] installed rasqal (1:0.9.33-3)
[2020-10-19T00:58:29+0330] [ALPM] installed redland (1:1.0.17-8)
[2020-10-19T00:58:29+0330] [ALPM] installed lpsolve (5.5.2.5-4)
[2020-10-19T00:58:29+0330] [ALPM] installed libwpg (0.3.3-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libvisio (0.1.7-3)
[2020-10-19T00:58:29+0330] [ALPM] installed liblangtag (0.6.3-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libetonyek (0.1.9-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libodfgen (0.1.7-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libcdr (0.1.6-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libmspub (0.1.4-7)
[2020-10-19T00:58:29+0330] [ALPM] installed clucene (2.3.3.4-11)
[2020-10-19T00:58:29+0330] [ALPM] installed libpagemaker (0.0.4-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libabw (0.1.3-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libmwaw (0.3.17-1)
[2020-10-19T00:58:29+0330] [ALPM] installed libe-book (0.1.3-7)
[2020-10-19T00:58:29+0330] [ALPM] installed libexttextcat (3.4.5-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libcmis (0.5.2-4)
[2020-10-19T00:58:29+0330] [ALPM] installed libixion (0.15.0-1)
[2020-10-19T00:58:29+0330] [ALPM] installed liborcus (0.15.4-1)
[2020-10-19T00:58:29+0330] [ALPM] installed libtommath (1.2.0-3)
[2020-10-19T00:58:29+0330] [ALPM] installed libzmf (0.0.2-8)
[2020-10-19T00:58:29+0330] [ALPM] installed libatomic_ops (7.6.10-2)
[2020-10-19T00:58:29+0330] [ALPM] installed libnumbertext (1.0.6-1)
[2020-10-19T00:58:29+0330] [ALPM] installed libfreehand (0.1.2-3)
[2020-10-19T00:58:29+0330] [ALPM] installed libstaroffice (0.0.7-1)
[2020-10-19T00:58:30+0330] [ALPM] installed libepubgen (0.1.1-2)
[2020-10-19T00:58:30+0330] [ALPM] installed libqxp (0.0.2-4)
[2020-10-19T00:58:31+0330] [ALPM] installed libreoffice-still (6.4.6-2)
[2020-10-19T00:58:32+0330] [ALPM] transaction completed
[2020-10-19T00:58:32+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T00:58:32+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-19T00:58:33+0330] [ALPM] running 'update-desktop-database.hook'...
[2020-10-19T00:58:33+0330] [ALPM] running 'update-mime-database.hook'...
[2020-10-18T21:52:58+0330] [PAMAC] synchronizing package lists
[2020-10-18T22:04:12+0330] [PACMAN] Running 'pacman -S neofetch'
[2020-10-18T22:04:18+0330] [ALPM] transaction started
[2020-10-18T22:04:18+0330] [ALPM] installed neofetch (7.1.0-1)
[2020-10-18T22:04:19+0330] [ALPM] transaction completed
[2020-10-18T22:04:19+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T22:07:13+0330] [PAMAC] synchronizing package lists
[2020-10-18T22:07:53+0330] [ALPM] transaction started
[2020-10-18T22:07:54+0330] [ALPM] upgraded matcha-gtk-theme (20200727-1 -> 20200928-1)
[2020-10-18T22:07:55+0330] [ALPM] transaction completed
[2020-10-18T22:07:55+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T22:11:00+0330] [PACMAN] Running 'pacman -Syu unbound'
[2020-10-18T22:11:00+0330] [PACMAN] synchronizing package lists
[2020-10-18T22:11:01+0330] [PACMAN] starting full system upgrade
[2020-10-18T22:11:13+0330] [ALPM] transaction started
[2020-10-18T22:11:13+0330] [ALPM] installed fstrm (0.6.0-2)
[2020-10-18T22:11:14+0330] [ALPM] installed hiredis (1.0.0-1)
[2020-10-18T22:11:14+0330] [ALPM] installed unbound (1.11.0-2)
[2020-10-18T22:11:14+0330] [ALPM] transaction completed
[2020-10-18T22:11:14+0330] [ALPM] running '20-systemd-sysusers.hook'...
[2020-10-18T22:11:14+0330] [ALPM-SCRIPTLET] Creating group unbound with gid 966.
[2020-10-18T22:11:14+0330] [ALPM-SCRIPTLET] Creating user unbound (unbound) with uid 966 and gid 966.
[2020-10-18T22:11:15+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-18T22:11:15+0330] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-10-18T22:11:15+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T22:11:48+0330] [PACMAN] Running 'pacman -S openvpn dialog python-pip python-setuptools'
[2020-10-18T22:12:15+0330] [ALPM] transaction started
[2020-10-18T22:12:15+0330] [ALPM] reinstalled openvpn (2.4.9-2)
[2020-10-18T22:12:15+0330] [ALPM] installed dialog (1:1.3_20200327-1)
[2020-10-18T22:12:15+0330] [ALPM] reinstalled python-setuptools (1:50.3.0-1)
[2020-10-18T22:12:16+0330] [ALPM] reinstalled python-pip (20.1.1-1)
[2020-10-18T22:12:16+0330] [ALPM] transaction completed
[2020-10-18T22:12:16+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-18T22:12:16+0330] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-10-18T22:12:16+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T22:36:05+0330] [PACMAN] Running 'pacman -Syu virtualbox linux54-virtualbox-host-modules'
[2020-10-18T22:36:05+0330] [PACMAN] synchronizing package lists
[2020-10-18T22:36:06+0330] [PACMAN] starting full system upgrade
[2020-10-18T22:39:46+0330] [PACMAN] Running 'pacman -Syu virtualbox linux58-virtualbox-host-modules'
[2020-10-18T22:39:46+0330] [PACMAN] synchronizing package lists
[2020-10-18T22:39:48+0330] [PACMAN] starting full system upgrade
[2020-10-18T22:48:56+0330] [ALPM] transaction started
[2020-10-18T22:48:56+0330] [ALPM] installed linux58-virtualbox-host-modules (6.1.14-6)
[2020-10-18T22:48:56+0330] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2020-10-18T22:48:56+0330] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2020-10-18T22:49:13+0330] [ALPM] installed virtualbox (6.1.14-1)
[2020-10-18T22:49:13+0330] [ALPM] transaction completed
[2020-10-18T22:49:13+0330] [ALPM] running '20-systemd-sysusers.hook'...
[2020-10-18T22:49:13+0330] [ALPM-SCRIPTLET] Creating group vboxusers with gid 108.
[2020-10-18T22:49:13+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-18T22:49:13+0330] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-10-18T22:49:13+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T22:49:13+0330] [ALPM] running '60-depmod.hook'...
[2020-10-18T22:49:13+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-18T22:49:14+0330] [ALPM] running 'update-desktop-database.hook'...
[2020-10-18T22:49:14+0330] [ALPM] running 'update-mime-database.hook'...
[2020-10-18T23:02:21+0330] [ALPM] transaction started
[2020-10-18T23:02:21+0330] [ALPM] installed pkgconf (1.7.3-1)
[2020-10-18T23:02:21+0330] [ALPM] installed libmicrohttpd (0.9.71-1)
[2020-10-18T23:02:21+0330] [ALPM] installed elfutils (0.181-1)
[2020-10-18T23:02:22+0330] [ALPM] installed binutils (2.35-2)
[2020-10-18T23:02:22+0330] [ALPM] installed libmpc (1.1.0-2)
[2020-10-18T23:02:22+0330] [ALPM] installed gcc (10.2.0-2)
[2020-10-18T23:02:22+0330] [ALPM] installed gc (8.0.4-4)
[2020-10-18T23:02:23+0330] [ALPM] installed guile (2.2.6-2)
[2020-10-18T23:02:23+0330] [ALPM] installed make (4.3-3)
[2020-10-18T23:02:23+0330] [ALPM] installed patch (2.7.6-8)
[2020-10-18T23:02:23+0330] [ALPM] installed dkms (2.8.3-1.1)
[2020-10-18T23:02:23+0330] [ALPM] installed m4 (1.4.18-3)
[2020-10-18T23:02:23+0330] [ALPM] installed flex (2.6.4-3)
[2020-10-18T23:02:23+0330] [ALPM] installed fakeroot (1.24-2)
[2020-10-18T23:02:24+0330] [ALPM] installed bison (3.6.4-1)
[2020-10-18T23:02:24+0330] [ALPM] installed autoconf (2.69-7)
[2020-10-18T23:02:24+0330] [ALPM] installed automake (1.16.2-3)
[2020-10-18T23:02:24+0330] [ALPM] transaction completed
[2020-10-18T23:02:24+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T23:02:24+0330] [ALPM] running 'texinfo-install.hook'...
[2020-10-18T23:02:45+0330] [ALPM] transaction started
[2020-10-18T23:02:45+0330] [ALPM] installed vmware-keymaps (1.0-1)
[2020-10-18T23:02:46+0330] [ALPM] transaction completed
[2020-10-18T23:02:46+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T23:19:22+0330] [ALPM] transaction started
[2020-10-18T23:19:23+0330] [ALPM] installed vmware-workstation (16.0.0-1)
[2020-10-18T23:19:23+0330] [ALPM-SCRIPTLET]
[2020-10-18T23:19:23+0330] [ALPM-SCRIPTLET] ==> Before using VMware, you need to reboot or load vmw_vmci and vmmon kernel modules (in a terminal on root: modprobe -a vmw_vmci vmmon)
[2020-10-18T23:19:23+0330] [ALPM-SCRIPTLET] ==> You may also need to enable some of these services:
[2020-10-18T23:19:23+0330] [ALPM-SCRIPTLET] - vmware-networks.service: to have network access inside VMs
[2020-10-18T23:19:23+0330] [ALPM-SCRIPTLET] - vmware-usbarbitrator.service: to connect USB devices inside VMs
[2020-10-18T23:19:25+0330] [ALPM] transaction completed
[2020-10-18T23:19:25+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-18T23:19:25+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-18T23:19:25+0330] [ALPM] running '70-dkms-install.hook'...
[2020-10-18T23:19:25+0330] [ALPM-SCRIPTLET] ==> Unable to install module vmware-workstation/16.0.0_16894299 for kernel 5.8.11-1-MANJARO: Missing kernel headers.
[2020-10-18T23:19:25+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-18T23:19:25+0330] [ALPM] running 'update-desktop-database.hook'...
[2020-10-18T23:19:25+0330] [ALPM] running 'update-mime-database.hook'...
[2020-10-19T00:46:14+0330] [ALPM] running '70-dkms-upgrade.hook'...
[2020-10-19T00:46:14+0330] [ALPM-SCRIPTLET] ==> Unable to remove module vmware-workstation/16.0.0_16894299 for kernel 5.8.11-1-MANJARO: Not found in dkms status output.
[2020-10-19T00:46:14+0330] [ALPM] transaction started
[2020-10-19T00:46:21+0330] [ALPM] reinstalled vmware-workstation (16.0.0-1)
[2020-10-19T00:46:22+0330] [ALPM] transaction completed
[2020-10-19T00:46:22+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-19T00:46:23+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T00:46:23+0330] [ALPM] running '70-dkms-install.hook'...
[2020-10-19T00:46:23+0330] [ALPM-SCRIPTLET] ==> Unable to install module vmware-workstation/16.0.0_16894299 for kernel 5.8.11-1-MANJARO: Missing kernel headers.
[2020-10-19T00:46:23+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-19T00:46:23+0330] [ALPM] running 'update-desktop-database.hook'...
[2020-10-19T00:46:23+0330] [ALPM] running 'update-mime-database.hook'...
[2020-10-19T00:59:58+0330] [PACMAN] Running 'pacman -S linux-headers'
[2020-10-19T01:01:15+0330] [ALPM] transaction started
[2020-10-19T01:01:17+0330] [ALPM] installed linux58-headers (5.8.11-1)
[2020-10-19T01:01:18+0330] [ALPM] transaction completed
[2020-10-19T01:01:18+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T01:01:18+0330] [ALPM] running '60-depmod.hook'...
[2020-10-19T01:01:36+0330] [ALPM] running '70-dkms-install.hook'...
[2020-10-19T01:01:36+0330] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m vmware-workstation -v 16.0.0_16894299 -k 5.8.11-1-MANJARO
[2020-10-19T01:01:49+0330] [ALPM-SCRIPTLET] ==> depmod 5.8.11-1-MANJARO
[2020-10-19T01:06:42+0330] [ALPM] running '70-dkms-upgrade.hook'...
[2020-10-19T01:06:42+0330] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod -m vmware-workstation -v 16.0.0_16894299 -k 5.8.11-1-MANJARO
[2020-10-19T01:06:43+0330] [ALPM] transaction started
[2020-10-19T01:06:44+0330] [ALPM] reinstalled vmware-workstation (16.0.0-1)
[2020-10-19T01:06:49+0330] [ALPM] transaction completed
[2020-10-19T01:06:50+0330] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-10-19T01:06:50+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T01:06:50+0330] [ALPM] running '70-dkms-install.hook'...
[2020-10-19T01:06:50+0330] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m vmware-workstation -v 16.0.0_16894299 -k 5.8.11-1-MANJARO
[2020-10-19T01:06:58+0330] [ALPM-SCRIPTLET] ==> depmod 5.8.11-1-MANJARO
[2020-10-19T01:07:06+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-19T01:07:09+0330] [ALPM] running 'update-desktop-database.hook'...
[2020-10-19T01:07:09+0330] [ALPM] running 'update-mime-database.hook'...
[2020-10-19T11:41:48+0330] [PACMAN] Running 'pacman -S vim'
[2020-10-19T11:42:30+0330] [ALPM] transaction started
[2020-10-19T11:42:30+0330] [ALPM] installed vim-runtime (8.2.1704-1)
[2020-10-19T11:42:30+0330] [ALPM] installed vim (8.2.1704-1)
[2020-10-19T11:42:31+0330] [ALPM] transaction completed
[2020-10-19T11:42:31+0330] [ALPM] running '30-systemd-update.hook'...
[2020-10-19T11:42:31+0330] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-10-19T11:42:31+0330] [ALPM] running 'update-desktop-database.hook'...
Think you need virtual network editor, it should come with vmware workstation if I remember correctly. I installed vmware workstation 16.0.0-1 from the aur and that gives me vmware player and virtual network editor
I already have it, as I stated in my post:
I had the same error and I can’t remember how I fixed it, it was so long ago. It may have been vmware tools, you have rebooted after installing the kernel modules?
Yes, rebooted for many times.
And you have vmware tools installed as well?
Yes. It was one of the first things I tried.
After enabling AUR support and doing some updates, it got fixed automatically.
But for providing helpful information on what was causing the problem and how it got fixed, I don’t know what to post here. How to find the real culprit?
