I have installed VMWare Player in my Windows 10 and The problem is that every time I power off the virtual machine everything is lost. I mean every program I install or folder i save or anything else is lost completely. And when I start the again the virtual machine is like newly installed.
Is there an option to change this (strange) behaviour?
If your OS is Windows 10 and you have problems with running that program,
VMWare Player,
then this here is the wrong forum to ask for support.
If you mean, however, that you installed Windows 10 in VMWare Player running on Manjaro Linux, then someone might have some advice.
This is a Manjaro forum.
No matter the host or guest - did you remember to remove the installation ISO from the virtual machine?
