VMPK (Virtual MIDI Piano Keyboard) won't launch after 2025-06-23 Stable Update
Hi there.
After the 2025-06-23 Stable Update, VMPK (0.9.1-1) won’t launch on my system.
Before this update I’ve been using VMPK daily without a problem.
I haven’t found any other problems after the update, so far.
journalctl output when trying to launch:
systemd[1624]: Started Application launched by gnome-shell.
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm_dsnoop.c:567:(snd_pcm_dsnoop_open) unable to open slave
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm_dmix.c:1000:(snd_pcm_dmix_open) unable to open slave
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
net.sourceforge.VMPK.desktop[9962]: Cannot connect to server socket err = No existe el fichero o el directorio
net.sourceforge.VMPK.desktop[9962]: Cannot connect to server request channel
net.sourceforge.VMPK.desktop[9962]: jack server is not running or cannot be started
net.sourceforge.VMPK.desktop[9962]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm_oss.c:404:(_snd_pcm_oss_open) Cannot open device /dev/dsp
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm_a52.c:1036:(_snd_pcm_a52_open) a52 is only for playback
net.sourceforge.VMPK.desktop[9962]: ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
net.sourceforge.VMPK.desktop[9962]: ALSA lib pcm_usb_stream.c:481:(_snd_pcm_usb_stream_open) Invalid card 'card'
rtkit-daemon[1062]: Supervising 12 threads of 8 processes of 1 users.
vmpk[9962]: qt.qpa.wayland: Failed to create popup. Ensure popup  QWidgetWindow(0x564c1195ac40, name="qtooltip_labelWindow") has a transientParent set.
gnome-shell[1720]: WL: error in client communication (pid 9962)
net.sourceforge.VMPK.desktop[9962]: [destroyed object]: error 1: xdg_surface destroyed before constructed
vmpk[9962]: The Wayland connection experienced a fatal error: Error de protocolo
systemd[1624]: app-gnome-net.sourceforge.VMPK-9962.scope: Consumed 443ms CPU time, 302.8M memory peak.
Here is inxi -SMGAa output, for what it’s worth:
  Host: haplo Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 15.1.1 clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=2ca3fa2b-1243-44de-881c-cdb742ad5dae rw quiet splash apparmor=1
  Desktop: GNOME v: 48.2 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Mobo: ASUSTeK model: PRIME B550M-K v: Rev X.0x
    UEFI: American Megatrends v: 3302 date: 08/01/2023
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
    XT/6600M] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3
    empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 0d:00.0 chip-ID: 1002:73ff
    class-ID: 0300
    compositor: gnome-shell driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 model: BenQ RL2455 serial: YBF05188SL0 built: 2015
    res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73")
    diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: DP-3 model: BenQ RL2455 serial: 1CF03884SL0 built: 2015
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
    LLVM 20.1.6 DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-smi x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 0d:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: nsmd status: off
    tools: jack_control,qjackctl
  Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active
Thanks in advance for your support.
Welcome to the Manjaro community @0p3r4t4
I just installed vmpk v0.9.1-1 on my Plasma Wayland testing branch system. It successfully opened, and I was able to play a tune, so it is obviously not a problem with the vmpk package (which is the same version across all repos & on Arch):
Output of: mbn info vmpk -q | grep -Ev 'Name|Repository|Packager'
Branch         : archlinux
Version        : 0.9.1-1
Build Date     : Mon 13 Jan 2025 05:02:24
Branch         : unstable
Version        : 0.9.1-1
Branch         : testing
Version        : 0.9.1-1
Branch         : stable
Version        : 0.9.1-1
mbn can be found in the manjaro-check-repos package
The inxi output you provided doesn’t provide uptime information (which is why inxi -zv8 is usually preferred), so I do have to ask the question:
Did you reboot after updating?
Hi, @scotty65. It’s nice to be in the Manjaro Community.
I rebooted several times since the update. Still not working.
I don’t think the problem originates from vmpk package (that remains the same since January) but, perhaps (and based on the errors produced on launch), from its dependency on qt6-base (6.9.1-1), that, as far as I understand, is updated on the last stable update. Just guessing.
Here goes the inxi -zv8 output:
  Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    base: Arch Linux
  System RAM: total: 32 GiB available: 31.25 GiB used: 6.6 GiB (21.1%)
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M2E3200C16 serial: N/A
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3777 min/max: 566/4471 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3777 2: 3777 3: 3777
    4: 3777 5: 3777 6: 3777 7: 3777 8: 3777 9: 3777 10: 3777 11: 3777 12: 3777
    bogomips: 84004
    xsaves xtopology
    affected
    class-ID: 0300
  Monitor-1: DP-2 model: BenQ RL2455 serial: <filter> built: 2015
    res: 1920x1080 dpi: 92 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.314 y: 0.620 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-2: DP-3 model: BenQ RL2455 serial: <filter> built: 2015
    640x480, 720x400
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 4.55 TiB used: 447.16 GiB (9.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 44.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Crucial model: CT4000P3SSD8
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 41.9 C
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 447.16 GiB (48.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 2ca3fa2b-1243-44de-881c-cdb742ad5dae
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 3F99-173A
  Device-1: 1-2:2 info: Microsoft Xbox 360 Wireless Receiver for Windows
    type: <vendor specific> driver: xpad interfaces: 8 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 260mA
    chip-ID: 045e:0291 class-ID: ff00
  Device-1: 3-2:2 info: Corsair K60 RGB PRO Low Profile Mechanical Gaming
    Keyboard type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
    chip-ID: 1b1c:1bad class-ID: 0301 serial: <filter>
  Device-2: 3-3:3 info: Corsair SABRE PRO Gaming Mouse type: mouse,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1b1c:1b7a class-ID: 0300 serial: <filter>
  Device-3: 3-4:4 info: Valve Wireless Steam Controller type: keyboard,HID
    driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 28de:1142 class-ID: 0300
  System Temperatures: cpu: 41.0 C mobo: 36.0 C gpu: amdgpu temp: 50.0 C
    mem: 48.0 C
  Fan Speeds (rpm): fan-1: 960 fan-2: 1148 fan-3: 0 fan-7: 0 gpu: amdgpu
    fan: 0
  Packages: 1949 pm: pacman pkgs: 1935 libs: 542 tools: gnome-software,pamac
    pm: flatpak pkgs: 14
    1: https://mirror.init7.net/manjaro/stable/$repo/$arch
    2: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    5: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    8: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 357
  1: cpu: 4.5% command: firefox pid: 2624 mem: 943.2 MiB (2.9%)
  2: cpu: 2.2% command: firefox pid: 33726 mem: 325.0 MiB (1.0%)
  3: cpu: 2.2% command: gnome-terminal-server pid: 34351
    mem: 66.1 MiB (0.2%)
  4: cpu: 2.0% command: gnome-shell pid: 1684 mem: 453.8 MiB (1.4%)
  5: cpu: 2.0% command: firefox pid: 4749 mem: 784.1 MiB (2.4%)
  Memory top: 5 of 357
  1: mem: 1085.6 MiB (3.3%) command: pamac-manager pid: 32755 cpu: 0.9%
  2: mem: 943.2 MiB (2.9%) command: firefox pid: 2624 cpu: 4.5%
  3: mem: 784.1 MiB (2.4%) command: firefox pid: 4749 cpu: 2.0%
  4: mem: 474.4 MiB (1.4%) command: firefox pid: 24023 cpu: 0.4%
  5: mem: 453.8 MiB (1.4%) command: gnome-shell pid: 1684 cpu: 2.0%
  Processes: 357 Power: uptime: 6h 37m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 20.1.6 gcc: 15.1.1 alt: 13/14 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.38
Hi there.
An update on the subject.
Deleting its configuration makes VMPK to work.
So I started configuring it to my needs until it stopped working again.
Repeating the process step by step, I’ve found that it you close the program with volume control selected (as shown in the image), it stops working.
Closing VMPK with this control selected leads, in my case, to a saved configuration file containing these lines:
[Instrument13]
Bank=-1
Controller=7
Program=0
Just replacing 7 with 1 (or other valid value) brings VMPK back to normal.
So I’m not sure if the update causes the problem or if it exists before and I just closed VMPK with this control selected the day before.
But, at least, if someone has the same problem, there’s a way to solve the situation.
Best regards.
