Hello team,
My VLC (official repository extra, 3.0.18-6) does not open a network stream,
whilst VLC (flatpak, 3.0.18) plays the same network stream without problems.
I performed re-install, however it did not have any effect.
I am unable to uninstall that VLC due to error: could not satisfy dependency: removing vlc breaks dependency vlc required by elisa.
Questions:
- What is the difference between those two VLC players ?
- Why the official VLC can no play a network stream, whilst flatpak VLC plays the network stream ?
- I need only one, working VLC. How to get rid of the official VLC ?
VLC Log Official, unable to open stream:
-- logger module started --
main debug: VLC media player - 3.0.18 Vetinari
main debug: Copyright © 1996-2022 the VideoLAN team
main debug: revision 3.0.13-8-g41878ff4f2
main debug: configured with ./configure '--prefix=/usr' '--sysconfdir=/etc' '--with-kde-solid=/usr/share/solid/actions/' '--disable-rpath' '--enable-nls' '--enable-archive' '--enable-live555' '--enable-dc1394' '--enable-dv1394' '--enable-dvdread' '--enable-dvdnav' '--enable-bluray' '--disable-opencv' '--enable-smbclient' '--enable-sftp' '--enable-nfs' '--enable-realrtsp' '--enable-dvbpsi' '--enable-gme' '--enable-ogg' '--enable-shout' '--enable-matroska' '--enable-mod' '--enable-mpc' '--enable-mad' '--enable-mpg123' '--enable-gst-decode' '--enable-avcodec' '--enable-libva' '--enable-avformat' '--enable-postproc' '--enable-faad' '--enable-vpx' '--enable-twolame' '--disable-fdkaac' '--enable-a52' '--enable-dca' '--enable-flac' '--enable-libmpeg2' '--enable-vorbis' '--enable-speex' '--enable-opus' '--enable-oggspots' '--disable-schroedinger' '--enable-png' '--enable-jpeg' '--enable-x264' '--enable-x265' '--enable-zvbi' '--enable-libass' '--enable-kate' '--enable-tiger' '--enable-vdpau' '--enable-wayland' '--enable-sdl-image' '--enable-freetype' '--enable-fribidi' '--enable-harfbuzz' '--enable-fontconfig' '--enable-svg' '--enable-svgdec' '--enable-aa' '--enable-caca' '--enable-pulse' '--enable-alsa' '--enable-jack' '--enable-samplerate' '--enable-soxr' '--disable-chromaprint' '--enable-chromecast' '--enable-qt' '--enable-skins2' '--enable-libtar' '--enable-ncurses' '--enable-lirc' '--enable-goom' '--enable-projectm' '--enable-avahi' '--enable-mtp' '--enable-upnp' '--enable-microdns' '--enable-libxml2' '--disable-libgcrypt' '--enable-gnutls' '--enable-taglib' '--enable-secret' '--enable-kwallet' '--disable-update-check' '--enable-notify' '--enable-libplacebo' '--enable-vlc' '--enable-aribsub' '--enable-aribcam' '--enable-aom' '--enable-srt' '--enable-dav1d' 'CFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -g -ffile-prefix-map=/build/vlc/src=/usr/src/debug/vlc -flto=auto -I/usr/include/samba-4.0 -ffat-lto-objects' 'LDFLAGS=-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -flto=auto' 'CPPFLAGS= -I/usr/include/samba-4.0' 'CXXFLAGS=-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -Wp,-D_GLIBCXX_ASSERTIONS -g -ffile-prefix-map=/build/vlc/src=/usr/src/debug/vlc -flto=auto -std=c++11' 'PKG_CONFIG_PATH=/usr/lib/ffmpeg4.4/pkgconfig/:/usr/lib/ffmpeg4.4/pkgconfig' 'LUA_LIBS=-llua5.2 -lm ' 'LUAC=/usr/bin/luac5.2'
main debug: searching plug-in modules
main debug: loading plugins cache file /usr/lib/vlc/plugins/plugins.dat
main debug: recursively browsing `/usr/lib/vlc/plugins'
main warning: cannot load module `/usr/lib/vlc/plugins/stream_filter/libaribcam_plugin.so' (libaribb25.so.0: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/visualization/libgoom_plugin.so' (libgoom2.so.0: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/visualization/libprojectm_plugin.so' (libprojectM.so.3: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/demux/libts_plugin.so' (libaribb24.so.0: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/codec/libaribsub_plugin.so' (libaribb24.so.0: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/codec/libkate_plugin.so' (libtiger.so.5: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/codec/libsdl_image_plugin.so' (libSDL_image-1.2.so.0: cannot open shared object file: No such file or directory)
main warning: cannot load module `/usr/lib/vlc/plugins/access/liblive555_plugin.so' (libliveMedia.so.107: cannot open shared object file: No such file or directory)
main debug: plug-ins loaded: 521 modules
main debug: opening config file (/home/tomas/.config/vlc/vlcrc)
main debug: looking for logger module matching "any": 4 candidates
file debug: opening logfile `/home/tomas/.vlc_official_error'
main debug: using logger module "file"
main debug: translation test: code is "C"
main debug: looking for keystore module matching "memory": 4 candidates
main debug: using keystore module "memory"
main debug: CPU has capabilities MMX MMXEXT SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX FPU
main debug: Creating an input for 'Media Library'
main debug: Input is a meta file: disabling unneeded options
main debug: using timeshift granularity of 50 MiB
main debug: using default timeshift path
main debug: `file/directory:///home/tomas/.local/share/vlc/ml.xspf' gives access `file' demux `directory' path `/home/tomas/.local/share/vlc/ml.xspf'
main debug: creating demux: access='file' demux='directory' location='/home/tomas/.local/share/vlc/ml.xspf' file='/home/tomas/.local/share/vlc/ml.xspf'
main debug: looking for access_demux module matching "file": 18 candidates
main debug: no access_demux modules matched
main debug: creating access: file:///home/tomas/.local/share/vlc/ml.xspf
main debug: (path: /home/tomas/.local/share/vlc/ml.xspf)
main debug: looking for access module matching "file": 30 candidates
main debug: using access module "filesystem"
main debug: looking for stream_filter module matching "prefetch,cache_read": 26 candidates
cache_read debug: Using stream method for AStream*
cache_read debug: starting pre-buffering
cache_read debug: received first data after 0 ms
cache_read debug: pre-buffering done 296 bytes in 0s - 5454 KiB/s
main debug: using stream_filter module "cache_read"
main debug: looking for stream_filter module matching "any": 26 candidates
playlist debug: using XSPF playlist reader
main debug: using stream_filter module "playlist"
main debug: stream filter added to 0x555b99c0d450
main debug: no stream_filter modules matched
main debug: looking for stream_directory module matching "any": 1 candidates
main debug: no stream_directory modules matched
main debug: attachment of directory-extractor failed for file:///home/tomas/.local/share/vlc/ml.xspf
main debug: looking for stream_filter module matching "record": 26 candidates
main debug: using stream_filter module "record"
main debug: looking for demux module matching "directory": 53 candidates
main debug: using demux module "directory"
main debug: looking for meta reader module matching "any": 2 candidates
lua debug: Trying Lua scripts in /home/tomas/.local/share/vlc/lua/meta/reader
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/reader
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/reader/filename.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/reader
main debug: no meta reader modules matched
main debug: `file/directory:///home/tomas/.local/share/vlc/ml.xspf' successfully opened
main debug: looking for xml reader module matching "any": 1 candidates
main debug: using xml reader module "xml"
main debug: EOF reached
main debug: removing module "directory"
main debug: removing module "record"
main debug: removing module "playlist"
main debug: removing module "cache_read"
main debug: removing module "filesystem"
main debug: creating audio output
main debug: looking for audio output module matching "any": 6 candidates
vlcpulse debug: using library version 16.1.0
vlcpulse debug: (compiled with version 16.1.0, protocol 35)
vlcpulse debug: connected locally to /run/user/1000/pulse/native as client #23
vlcpulse debug: using protocol 35, server protocol 35
pulse debug: adding sink 0: alsa_output.pci-0000_00_1b.0.analog-stereo (Built-in Audio Analog Stereo)
main debug: using audio output module "pulse"
main debug: keeping audio output
main debug: looking for interface module matching "dbus,none": 19 candidates
dbus debug: listening on dbus as: org.mpris.MediaPlayer2.vlc
main debug: using interface module "dbus"
main debug: no running VLC instance - continuing normally...
main debug: looking for interface module matching "hotkeys,none": 19 candidates
main debug: using interface module "hotkeys"
main debug: looking for interface module matching "globalhotkeys,none": 19 candidates
main debug: using interface module "xcb_hotkeys"
main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
main debug: looking for interface module matching "any": 19 candidates
dbus debug: Getting All properties
main debug: looking for extension module matching "any": 1 candidates
lua debug: Opening Lua Extension module
lua debug: Trying Lua scripts in /home/tomas/.local/share/vlc/lua/extensions
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/extensions
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/extensions/VLSub.luac
lua debug: Scanning Lua script /usr/lib/vlc/lua/extensions/VLSub.luac
lua debug: Script /usr/lib/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
lua debug: Trying Lua scripts in /usr/share/vlc/lua/extensions
main debug: using extension module "lua"
main debug: looking for services probe module matching "any": 11 candidates
main debug: no services probe modules matched
qt debug: Sorting by column -1, order 0
main debug: using interface module "qt"
main: playlist is empty
main debug: nothing to play
main debug: processing request item: 3638, node: Playlist, skip: 0
main debug: rebuilding array of current - root Playlist
main debug: rebuild done - 1 items, index 0
main debug: starting playback of new item
main debug: resyncing on 3638
main debug: 3638 is at 0
main debug: creating new input thread
main debug: Creating an input for '3638'
main debug: requesting art for new input thread
main debug: `http://local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638' gives access `http' demux `any' path `local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638'
main debug: creating demux: access='http' demux='any' location='local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638' file='(null)'
main debug: looking for access_demux module matching "http": 18 candidates
main debug: creating access: http://local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638
main debug: looking for access module matching "http": 30 candidates
main debug: looking for meta fetcher module matching "any": 1 candidates
lua debug: Trying Lua scripts in /home/tomas/.local/share/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/fetcher
main debug: no meta fetcher modules matched
main debug: looking for art finder module matching "any": 2 candidates
qt debug: IM: Setting an input
lua debug: Trying Lua scripts in /home/tomas/.local/share/vlc/lua/meta/art
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/meta/art
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: skipping script (unmatched scope) /usr/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/meta/art
main debug: no art finder modules matched
dbus debug: Getting property Position
http debug: resolving local.xnetwork.club ...
http debug: outgoing request:
GET /hWIMZooClb/RsQxkYIzJk/3638 HTTP/1.1
Host: local.xnetwork.club:8000
Accept: */*
Accept-Language: en_US
User-Agent: VLC/3.0.18 LibVLC/3.0.18
Range: bytes=0-
http debug: incoming response:
HTTP/1.1 302 Found
Server: nginx
Date: Fri, 24 Mar 2023 14:44:38 GMT
Content-Type: text/html; charset=UTF-8
Connection: close
Access-Control-Allow-Origin: *
Location: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bUA9XVQdbVwpdBQhWVFMGC1VRAwcBUlJRB1VcU1cFBQ4UGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQBWXQcYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwcFVxJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
http debug: connection failed
main debug: no access modules matched
main debug: redirecting to: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bUA9XVQdbVwpdBQhWVFMGC1VRAwcBUlJRB1VcU1cFBQ4UGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQBWXQcYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwcFVxJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
main debug: creating access: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bUA9XVQdbVwpdBQhWVFMGC1VRAwcBUlJRB1VcU1cFBQ4UGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQBWXQcYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwcFVxJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
http debug: resolving cznl2.hopto.org ...
GET /hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bUA9XVQdbVwpdBQhWVFMGC1VRAwcBUlJRB1VcU1cFBQ4UGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQBWXQcYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwcFVxJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk= HTTP/1.1
Host: cznl2.hopto.org:25461
Accept: */*
Range: bytes=0-
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 24 Mar 2023 14:44:39 GMT
Content-Type: video/mp2t
Connection: close
main debug: using access module "access"
main debug: looking for stream_filter module matching "prefetch,cache_block": 26 candidates
prefetch debug: using 16777216 bytes buffer, 16777216 bytes read
main debug: using stream_filter module "prefetch"
lua debug: Trying Lua scripts in /home/tomas/.local/share/vlc/lua/playlist
lua debug: Trying Lua scripts in /usr/lib/vlc/lua/playlist
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/anevia_streams.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/anevia_xml.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/appletrailers.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/bbc_co_uk.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/cue.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/dailymotion.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/jamendo.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/koreus.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/liveleak.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/newgrounds.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/rockbox_fm_presets.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/soundcloud.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/twitch.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/vimeo.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/vocaroo.luac
lua debug: Trying Lua playlist script /usr/lib/vlc/lua/playlist/youtube.luac
lua debug: Trying Lua scripts in /usr/share/vlc/lua/playlist
main debug: attachment of directory-extractor failed for http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bUA9XVQdbVwpdBQhWVFMGC1VRAwcBUlJRB1VcU1cFBQ4UGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQBWXQcYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwcFVxJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
main debug: creating demux: access='http' demux='ts' location='local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638' file='(null)'
main debug: looking for demux module matching "ts": 53 candidates
main debug: no demux modules matched
main debug: removing module "prefetch"
prefetch debug: end of stream
main debug: removing module "access"
main debug: dead input
main debug: changing item without a request (current 0/1)
qt debug: IM: Deleting the input
VLC Flatpak, network stream opening, playing
main debug: revision 3.0.18-0-ge9eceae
main debug: configured with ./configure '--prefix=/app' 'BUILDCC=/usr/bin/gcc -std=gnu99' '--disable-a52' 'CFLAGS=-O2 -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer ' 'LDFLAGS=-L/app/lib -Wl,-z,relro,-z,now -Wl,--as-needed ' 'CXXFLAGS=-O2 -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -fexceptions -fstack-protector-strong -grecord-gcc-switches -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer ' 'PKG_CONFIG_PATH=/app/lib/pkgconfig:/app/share/pkgconfig:/usr/lib/pkgconfig:/usr/share/pkgconfig'
main debug: loading plugins cache file /app/lib/vlc/plugins/plugins.dat
main debug: recursively browsing `/app/lib/vlc/plugins'
main debug: plug-ins loaded: 511 modules
main debug: opening config file (/home/tomas/.var/app/org.videolan.VLC/config/vlc/vlcrc)
file debug: opening logfile `.vlc-flatpak_ok'
main debug: `file/directory:///home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf' gives access `file' demux `directory' path `/home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf'
main debug: creating demux: access='file' demux='directory' location='/home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf' file='/home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf'
main debug: looking for access_demux module matching "file": 20 candidates
main debug: creating access: file:///home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf
main debug: (path: /home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf)
main debug: looking for access module matching "file": 29 candidates
cache_read debug: pre-buffering done 296 bytes in 0s - 6423 KiB/s
main debug: stream filter added to 0x5600399e9e50
main debug: attachment of directory-extractor failed for file:///home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf
lua debug: Trying Lua scripts in /home/tomas/.var/app/org.videolan.VLC/data/vlc/lua/meta/reader
lua debug: Trying Lua scripts in /app/lib/vlc/lua/meta/reader
lua debug: Trying Lua playlist script /app/lib/vlc/lua/meta/reader/filename.luac
lua debug: Trying Lua scripts in /app/share/vlc/lua/meta/reader
main debug: `file/directory:///home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf' successfully opened
vlcpulse debug: using library version 16.0.0
vlcpulse debug: (compiled with version 16.0.0, protocol 35)
vlcpulse debug: connected locally to unix:/run/flatpak/pulse/native as client #21
main debug: looking for interface module matching "dbus,none": 18 candidates
main debug: looking for interface module matching "hotkeys,none": 18 candidates
main debug: looking for interface module matching "globalhotkeys,none": 18 candidates
main debug: looking for interface module matching "any": 18 candidates
lua debug: Trying Lua scripts in /home/tomas/.var/app/org.videolan.VLC/data/vlc/lua/extensions
lua debug: Trying Lua scripts in /app/lib/vlc/lua/extensions
lua debug: Trying Lua playlist script /app/lib/vlc/lua/extensions/VLSub.luac
lua debug: Scanning Lua script /app/lib/vlc/lua/extensions/VLSub.luac
lua debug: Script /app/lib/vlc/lua/extensions/VLSub.luac has the following capability flags: 0x5
lua debug: Trying Lua scripts in /app/share/vlc/lua/extensions
main debug: looking for access_demux module matching "http": 20 candidates
main debug: looking for access module matching "http": 29 candidates
lua debug: Trying Lua scripts in /home/tomas/.var/app/org.videolan.VLC/data/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /app/lib/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /app/share/vlc/lua/meta/fetcher
lua debug: Trying Lua scripts in /home/tomas/.var/app/org.videolan.VLC/data/vlc/lua/meta/art
lua debug: Trying Lua scripts in /app/lib/vlc/lua/meta/art
lua debug: Trying Lua playlist script /app/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: skipping script (unmatched scope) /app/lib/vlc/lua/meta/art/00_musicbrainz.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: skipping script (unmatched scope) /app/lib/vlc/lua/meta/art/01_googleimage.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: skipping script (unmatched scope) /app/lib/vlc/lua/meta/art/02_frenchtv.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: skipping script (unmatched scope) /app/lib/vlc/lua/meta/art/03_lastfm.luac
lua debug: Trying Lua scripts in /app/share/vlc/lua/meta/art
Accept: */*
Range: bytes=0-
HTTP/1.1 302 Found
Server: nginx
Date: Fri, 24 Mar 2023 14:39:42 GMT
Connection: close
Location: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bVAJUCVNaDQwPAVkDVAEODVYBBAALCVICUlAAVVNVVwAUGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQFRXQsYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwQCVRJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
main debug: redirecting to: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bVAJUCVNaDQwPAVkDVAEODVYBBAALCVICUlAAVVNVVwAUGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQFRXQsYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwQCVRJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
main debug: creating access: http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bVAJUCVNaDQwPAVkDVAEODVYBBAALCVICUlAAVVNVVwAUGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQFRXQsYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwQCVRJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
GET /hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bVAJUCVNaDQwPAVkDVAEODVYBBAALCVICUlAAVVNVVwAUGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQFRXQsYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwQCVRJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk= HTTP/1.1
Accept: */*
Range: bytes=0-
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 24 Mar 2023 14:39:43 GMT
Connection: close
lua debug: Trying Lua scripts in /home/tomas/.var/app/org.videolan.VLC/data/vlc/lua/playlist
lua debug: Trying Lua scripts in /app/lib/vlc/lua/playlist
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/anevia_streams.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/anevia_xml.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/appletrailers.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/bbc_co_uk.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/cue.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/dailymotion.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/jamendo.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/koreus.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/liveleak.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/newgrounds.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/rockbox_fm_presets.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/soundcloud.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/twitch.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/vimeo.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/vocaroo.luac
lua debug: Trying Lua playlist script /app/lib/vlc/lua/playlist/youtube.luac
lua debug: Trying Lua scripts in /app/share/vlc/lua/playlist
main debug: attachment of directory-extractor failed for http://cznl2.hopto.org:25461/hWIMZooClb/RsQxkYIzJk/3638?token=HxMNWURdQw8bVAJUCVNaDQwPAVkDVAEODVYBBAALCVICUlAAVVNVVwAUGkNDF0pRWFRsUQVEXgQPVV0fFkdCVBZuDFwVD0MNChQaQ0QKVVEbAwIOVl9SAQFRXQsYEEFYABNfGgUNVQMIFBpDVRtMUUtXUlQ+AgFBUAUAEQ5cRF0IHUdXWWoFUFRXWAUSWRoEGxURURIWRg1XEwlfGBBTWBBDBExSF1sXCwQCVRJPGldWTF1MEx9GDRslPxEYEFRJEFQLS15aDxcDFEISEk8aXUpmQV0SEhZSWAsAQRYIEwBGHUdVVk0+VlZYWARTF1FbV0oRAkNUUQcbSkdeW1xYRQtDOkheUUMPGwcGUgJSGkk=
ts debug: Standard set to Auto
main debug: using demux module "ts"
ts debug: DEMUX_SET_GROUP 0 (nil)
main debug: `http://local.xnetwork.club:8000/hWIMZooClb/RsQxkYIzJk/3638' successfully opened
ts debug: pid[17] unknown
ts debug: first packet for pid=0 cc=0x9
ts debug: PATCallBack called
ts debug: new PAT ts_id=1 version=0 current_next=1
ts debug: * number=1 pid=4096
ts debug: temporary receiving program 1
ts debug: first packet for pid=4096 cc=0x9
ts debug: PMTCallBack called for program 1
ts debug: new PMT program number=1 version=0 pid_pcr=256
ts debug: * pid=256 type=0x1b AVC video stream as defined in ITU-T Rec. H.264
ts debug: => pid 256 has now es fcc=h264
main debug: selecting program id=1
main debug: looking for packetizer module matching "any": 25 candidates
main debug: using packetizer module "h264"
main debug: looking for video decoder module matching "any": 17 candidates
avcodec debug: using ffmpeg Lavc58.134.100
avcodec debug: CPU flags: 0x000053db
avcodec debug: allowing 5 thread(s) for decoding
avcodec debug: codec (h264) started
avcodec debug: using frame thread mode with 5 threads
main debug: using video decoder module "avcodec"
ts debug: Default program is 1
ts debug: * pid=257 type=0x3 ISO/IEC 11172 Audio
ts debug: - ES descriptor tag 0xa
ts debug: found language: eng
ts debug: => pid 257 has now es fcc=mpga
main debug: using packetizer module "mpegaudio"
main debug: looking for audio decoder module matching "any": 17 candidates
mpg123 debug: mpga->f32l, bits per sample: 32
main debug: using audio decoder module "mpg123"
ts debug: * pid=258 type=0x3 ISO/IEC 11172 Audio
ts debug: found language: cze
ts debug: => pid 258 has now es fcc=mpga
ts debug: * pid=17 listening for SDT
ts debug: enabling pid 256 from program 1
ts debug: enabling pid 257 from program 1
ts debug: enabling pid 258 from program 1
ts debug: enabling pcr pid 256 from program 1
ts debug: first packet for pid=256 cc=0x2
main debug: Buffering 0%
main debug: Buffering 4%
h264 debug: found NAL_SPS (sps_id=0)
h264 debug: found NAL_PPS (pps_id=0 sps_id=0)
h264 debug: Seen SEI recovery point, 0 recovery frames
h264 debug: Recovering using SEI, prerolling 0 reference pics
h264 debug: Recovery from SEI recovery point complete
main debug: restarting module due to input format change
main debug: Buffering 8%
main debug: removing module "avcodec"
main debug: Buffering 12%
main debug: Buffering 16%
ts debug: first packet for pid=257 cc=0xb
ts debug: first packet for pid=17 cc=0x1
ts debug: SDTCallBack called
ts debug: * pid=18 listening for EIT
ts debug: * pid=20 listening for TDT
ts debug: new SDT ts_id=1 version=0 current_next=1 network_id=65281
ts debug: * service id=1 eit schedule=0 present=0 running=4 free_ca=0
avcodec debug: available hardware decoder output format 100 (vdpau)
avcodec debug: available hardware decoder output format 46 (vaapi_vld)
avcodec debug: available software decoder output format 0 (yuv420p)
ts debug: - type=1 provider=FFmpeg name=Service01
avcodec debug: trying format vaapi_vld
main debug: EsOutProgramMeta: number=1
mpegaudio debug: MPGA channels:2 samplerate:48000 bitrate:160
ts debug: first packet for pid=258 cc=0x3
main debug: removing module "mpg123"
main debug: Buffering 20%
main debug: Buffering 24%
main debug: reusing audio output
main debug: Buffering 28%
pulse debug: using stereo channel map
main debug: Buffering 32%
main debug: Buffering 36%
main debug: Buffering 40%
main debug: Buffering 44%
main debug: looking for text renderer module matching "any": 3 candidates
freetype debug: Building font databases.
freetype debug: Took -11214 microseconds
pulse debug: changed buffer metrics: maxlength=4194304, tlength=46080, prebuf=0, minreq=15360
pulse debug: connected to sink alsa_output.pci-0000_00_1b.0.analog-stereo
main debug: output 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
main debug: looking for audio volume module matching "any": 2 candidates
main debug: using audio volume module "float_mixer"
main debug: input 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
pulse debug: changing sink 0: alsa_output.pci-0000_00_1b.0.analog-stereo (Built-in Audio Analog Stereo)
main debug: looking for audio filter module matching "scaletempo": 16 candidates
scaletempo debug: format: 48000 rate, 2 nch, 4 bps, fl32
scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
scaletempo debug: 1.000 scale, 1440.000 stride_in, 1440 stride_out, 1152 standing, 288 overlap, 672 search, 2400 queue, fl32 mode
main debug: using audio filter module "scaletempo"
main debug: conversion: 'f32l'->'f32l' 48000 Hz->48000 Hz Stereo->Stereo
main debug: conversion pipeline complete
main debug: looking for audio resampler module matching "any": 3 candidates
main debug: using text renderer module "freetype"
main debug: looking for video converter module matching "any": 23 candidates
main debug: using audio resampler module "samplerate"
main debug: Buffering 48%
main debug: Buffering 52%
main debug: Buffering 56%
swscale debug: 32x32 (32x32) chroma: YUVA -> 16x16 (16x16) chroma: RGBA with scaling using Bicubic (good quality)
main debug: using video converter module "swscale"
yuvp debug: YUVP to YUVA converter
main debug: using video converter module "yuvp"
main debug: Deinterlacing available
main debug: deinterlace -1, mode auto, is_needed 0
main debug: looking for vout window module matching "qt,any": 4 candidates
qt debug: requesting video window...
main debug: using vout window module "qt"
main debug: resized to 720x576
main debug: looking for inhibit module matching "any": 2 candidates
dbus_screensaver debug: found service org.freedesktop.ScreenSaver
main debug: using inhibit module "dbus_screensaver"
main debug: Opening vout display wrapper
main debug: looking for vout display module matching "any": 11 candidates
main debug: VoutDisplayEvent 'resize' 720x576
qt debug: Logical video size: 1047x576
main debug: looking for opengl module matching "any": 2 candidates
main debug: resized to 1047x576
main debug: VoutDisplayEvent 'resize' 1047x576
main debug: Buffering 60%
main debug: Buffering 64%
main debug: Buffering 68%
main debug: Buffering 72%
main debug: Buffering 76%
main debug: Buffering 80%
egl_x11 debug: EGL version 1.5 by Mesa Project
egl_x11 debug: extensions: EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_CHROMIUM_sync_control EGL_ANGLE_sync_control_rate EGL_EXT_buffer_age EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_swap_buffers_with_damage EGL_IMG_context_priority EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_NOK_texture_from_pixmap EGL_WL_bind_wayland_display
main debug: Buffering 84%
main debug: using opengl module "egl_x11"
main debug: looking for glconv module matching "any": 3 candidates
main debug: Buffering 88%
main debug: Buffering 92%
main debug: using glconv module "glconv_vaapi_x11"
main debug: Buffering 96%
main debug: using vout display module "gl"
main debug: original format sz 720x576, of (0,0), vsz 720x576, 4cc VAOP, sar 16:11, msk r0x0 g0x0 b0x0
main debug: removing module "freetype"
freetype debug: Took -13617 microseconds
main debug: looking for hw decoder module matching "any": 3 candidates
main debug: using hw decoder module "vaapi"
avcodec: Using Intel i965 driver for Intel(R) Ivybridge Mobile - 2.4.1 for hardware decoding
main debug: Received first picture
main debug: Buffering 100%
main debug: Detected interlaced video
main debug: deinterlace -1, mode auto, is_needed 1
main debug: Adding 'deinterlace' as static
main debug: looking for video filter module matching "deinterlace,chain": 50 candidates
vaapi_filters debug: using x deinterlace method
main debug: using video filter module "vaapi_filters"
main debug: Filter 'deinterlace' (0x7fbc80887f90) appended to chain
main debug: Stream buffering done (1040 ms in 292 ms)
main debug: Decoder wait done in 0 ms
pulse debug: cannot synchronize start
pulse debug: deferring start (776642 us)
pulse debug: deferring start (752373 us)
pulse debug: deferring start (727730 us)
pulse debug: deferring start (703115 us)
pulse debug: deferring start (678308 us)
pulse debug: deferring start (653620 us)
pulse debug: deferring start (628850 us)
pulse debug: deferring start (604167 us)
pulse debug: deferring start (579460 us)
pulse debug: deferring start (554782 us)
pulse debug: deferring start (530115 us)
pulse debug: deferring start (505410 us)
pulse debug: deferring start (480360 us)
pulse debug: deferring start (455536 us)
pulse debug: deferring start (430783 us)
pulse debug: deferring start (405909 us)
pulse debug: deferring start (381216 us)
pulse debug: deferring start (356463 us)
pulse debug: deferring start (331745 us)
pulse debug: deferring start (306954 us)
pulse debug: deferring start (282190 us)
pulse debug: deferring start (257503 us)
pulse debug: deferring start (232836 us)
pulse debug: deferring start (208147 us)
pulse debug: deferring start (183341 us)
pulse debug: deferring start (158642 us)
pulse debug: deferring start (133839 us)
pulse debug: deferring start (109138 us)
pulse debug: deferring start (84281 us)
pulse debug: deferring start (59568 us)
pulse debug: deferring start (34665 us)
pulse debug: deferring start (9924 us)
pulse warning: starting late (-14817 us)
main warning: playback way too early (-752266): playing silence
main debug: inserting 36108 zeroes
pulse debug: started
main debug: auto hiding mouse cursor
qt debug: video widget is orphaned
qt warning: orphaned video window
main debug: exiting
main debug: exiting
main debug: removing all interfaces
main debug: removing module "qt"
main debug: deactivating the playlist
main debug: incoming request - stopping current input
main debug: killing decoder fourcc `h264'
main debug: saving a free vout
main debug: reusing provided vout
main debug: removing module "h264"
main debug: killing decoder fourcc `mpga'
main debug: removing module "samplerate"
main debug: removing module "scaletempo"
main debug: removing module "float_mixer"
main debug: removing module "mpegaudio"
main debug: removing module "ts"
main debug: Program doesn't contain anymore ES
main debug: destroying useless vout
main debug: removing module "gl"
main debug: removing module "glconv_vaapi_x11"
main debug: removing module "egl_x11"
main debug: removing module "vaapi_filters"
main debug: Filter 0x7fbc80887f90 removed from chain
dbus_screensaver debug: got cookie 7222
main debug: removing module "dbus_screensaver"
qt debug: releasing video...
qt debug: video widget is released
main debug: removing module "yuvp"
main debug: removing module "swscale"
main debug: removing module "pulse"
qt debug: requesting exit...
qt debug: waiting for UI thread...
qt debug: QApp exec() finished
qt debug: Killing extension dialog provider
qt debug: ExtensionsDialogProvider is quitting...
main debug: removing module "lua"
main debug: removing module "xcb_hotkeys"
main debug: removing module "hotkeys"
main debug: removing module "dbus"
main debug: saving media library to file /home/tomas/.var/app/org.videolan.VLC/data/vlc/ml.xspf.tmp2
main debug: looking for playlist export module matching "export-xspf": 4 candidates
main debug: using playlist export module "export"
main debug: removing module "export"
main debug: deleting item `Media Library'
main debug: deleting item `3638'
main debug: deleting item `Playlist'
main debug: removing module "memory"
-- logger module stopped --
Official VLC(problematic)
vlc -l | grep ts ✔
VLC media player 3.0.18 Vetinari (revision 3.0.13-8-g41878ff4f2)
podcast Podcasts
podcast Podcasts
access_realrtsp Real RTSP
concat Concatenated inputs
textst HDMV TextST subtitles decoder
oggspots OggSpots video decoder
oggspots OggSpots video packetizer
i420_10_p010 YUV 10-bits planar to semiplanar 10-bits conversions
mux_ts TS muxer (libdvbpsi)
stats Writes statistic info about stream
rtsp Legacy RTSP VoD server
stats Stats encoder function
stats Stats decoder function
stats Stats demux function
secret Secrets are stored via libsecret
kwallet Secrets are stored via KWallet
file Secrets are stored on a file without any encryption
memory Secrets are stored in memory
netsync Network synchronization
dts DTS audio packetizer
lua Fetch meta data using lua scripts
lua Read meta data using lua scripts
lua Fetch artwork using lua scripts
Flatpak VLC (good)
flatpak run org.videolan.VLC -l | grep ts ✔ 4s
VLC media player 3.0.18 Vetinari (revision 3.0.18-0-ge9eceae)
podcast Podcasts
podcast Podcasts
ts MPEG Transport Stream demuxer
