VLC just stopped playing audio, did nothing, so not sure why. Anyway figured I uninstall then reinstall, anyway the pacmanager says no servers configured for repository, no idea on that, no changes were made since I updated with no issues. Hmmm, seems ok now, not sure why. Did nothing, but still no sound in VLC.
**** List of CAPTURE Hardware Devices ****
card 1: Generic [HD-Audio Generic], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic [HD-Audio Generic], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
Subdevices: 1/1
I see this is an old topic with no replies, so maybe the problem was sorted out long ago. I’m replying just in case it relates to a similar problem I’ve had. I typically Suspend/Sleep my PC rather than reboot, and if VLC or Handbrake is running and the PC “sleeps” on unattended automatic Suspend: No audio. (I have a lot of old DVDs and copy them to HDD via Handbrake for viewing with VLC)
Anyway, when the PC auto-sleeps with either of those two apps open, often (not always) there’s no sound when waking the PC. Usually it happens when the PC is crunching a DVD overnight, auto-sleeps after done, and I “wake” it again after some hours.
The issue seems related to “Dummy Audio” output.
There appears to be no way of getting HDMI going again or restarting audio.
“Dummy Audio” shows in Sound Preferences → Output.
The ONLY solution I’ve found is reboot.
What happens if You log out and log in again?
Haven’t tried it, since the PC boots in a few seconds since I installed a $70 1TB Samsung Pro nvme SSD. What I hoped for was either a fix, a way to just switch from Dummy Audio back to HDMI, or restarting the audio system so I could write a script to do it. Anyway, restart’s working passably but I posted in case restart works for others.
Try restarting PulseAudio:
systemctl --user restart pulseaudio
or reinitialising ALSA devices to default state:
sudo alsactl init
            Thanks, FediWarneck. In case anyone’s still following this, I did eventually try logout/in and it made no difference.
