Can anybody confirm?
Since yesterday VLC doesn’t load the Icecast Radio Directory anymore.
But https://dir.xiph.org/ is working.
VLC uses dir.xiph.org/yp.xml to get station listing for Icecast Radio Directory
$ grep http /usr/share/doc/vlc/lua/sd/icecast.lua
local tree = simplexml.parse_url("http://dir.xiph.org/yp.xml")
The URL to fetch yp.xml file is not working at the moment
XML Parsing Error: no element found
Line Number 1, Column 77199:
But VLC can still play icecast stream URLs listed at dir.xiph.org
Today working again.
