I just installed a new Manjaro KDE and tried to customize the theme which included some fiddling with some packages. I don’t know what did I mess up (or even if it is my fault) but VLC crashes as soon as I try to play a video file. Following the instructions on this topic, here are some debugging info:
int DBusMenuExporterDBus::GetLayout(int, int, const QStringList&, DBusMenuLayoutItem&): Condition failed: menu
[Thread 0x7fff637ff6c0 (LWP 17390) exited]
[Thread 0x7fff8015e6c0 (LWP 17387) exited]
[New Thread 0x7fff629ff6c0 (LWP 17397)]
[New Thread 0x7fff621fe6c0 (LWP 17398)]
[New Thread 0x7fff619fd6c0 (LWP 17399)]
[New Thread 0x7fff611fc6c0 (LWP 17400)]
[New Thread 0x7fff609fb6c0 (LWP 17401)]
[New Thread 0x7fff4bfff6c0 (LWP 17402)]
[New Thread 0x7fff637ff6c0 (LWP 17403)]
[New Thread 0x7fff8015e6c0 (LWP 17408)]
[New Thread 0x7fff491ff6c0 (LWP 17409)]
[New Thread 0x7fff489fe6c0 (LWP 17410)]
[New Thread 0x7fff415ff6c0 (LWP 17411)]
[New Thread 0x7fff40dfe6c0 (LWP 17412)]
[New Thread 0x7fff3bfff6c0 (LWP 17413)]
[New Thread 0x7fff3b7fe6c0 (LWP 17414)]
[New Thread 0x7fff3affd6c0 (LWP 17415)]
[New Thread 0x7fff3a7fc6c0 (LWP 17416)]
[New Thread 0x7fff39ffb6c0 (LWP 17417)]
[New Thread 0x7fff397fa6c0 (LWP 17418)]
[New Thread 0x7fff38ff96c0 (LWP 17419)]
[New Thread 0x7fff17fff6c0 (LWP 17420)]
[New Thread 0x7fff177fe6c0 (LWP 17421)]
[New Thread 0x7fff16ffd6c0 (LWP 17422)]
[00007fff58020200] gl gl: Initialized libplacebo v5.229.0 (API v229)
libva error: /usr/lib/dri/i965_drv_video.so init failed
[00007fff58020200] glconv_vaapi_x11 gl error: vaInitialize: unknown libva error
[Thread 0x7fff812f96c0 (LWP 17361) exited]
[Thread 0x7fff81afa6c0 (LWP 17360) exited]
[Thread 0x7fff822fb6c0 (LWP 17359) exited]
[Thread 0x7fff9d7fa6c0 (LWP 17358) exited]
[00007fff58020200] glconv_vaapi_drm gl error: vaInitialize: unknown libva error
Thread 43 "vlc" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff8015e6c0 (LWP 17408)]
XDisplayString (dpy=0x0) at /usr/src/debug/libx11/libX11-1.8.4/src/Macros.c:119
119 char *XDisplayString(Display *dpy) { return (DisplayString(dpy)); }
(gdb) bt
#0 XDisplayString (dpy=0x0) at /usr/src/debug/libx11/libX11-1.8.4/src/Macros.c:119
#1 0x00007fff802afa1d in __vaDriverInit_1_13 () at /usr/lib/dri/nvidia_drv_video.so
#2 0x00007fff702c49c3 in () at /usr/lib/libva.so.2
#3 0x00007fff702c7cd0 in vaInitialize () at /usr/lib/libva.so.2
#4 0x00007fff8033a7d3 in () at /usr/lib/vlc/plugins/video_output/libglconv_vaapi_drm_plugin.so
#5 0x00007ffff7ca069f in () at /usr/lib/libvlccore.so.9
#6 0x00007ffff7ca35f4 in vlc_module_load () at /usr/lib/libvlccore.so.9
#7 0x00007fff804f2054 in () at /usr/lib/vlc/plugins/video_output/libgl_plugin.so
#8 0x00007fff804f621d in () at /usr/lib/vlc/plugins/video_output/libgl_plugin.so
#9 0x00007ffff7ca069f in () at /usr/lib/libvlccore.so.9
#10 0x00007ffff7ca35f4 in vlc_module_load () at /usr/lib/libvlccore.so.9
#11 0x00007ffff7d3b1b1 in () at /usr/lib/libvlccore.so.9
#12 0x00007ffff7cf610b in () at /usr/lib/libvlccore.so.9
#13 0x00007ffff7cf9377 in () at /usr/lib/libvlccore.so.9
#14 0x00007ffff7e08bb5 in start_thread (arg=<optimized out>) at pthread_create.c:444
#15 0x00007ffff7e8ad90 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
(gdb)
I didn’t bore you with all the logs before I open the video file, only after.
BTW, I do have a an Nvidia GPU but my display output is not connected to it. It’s connected rather to the iGPU. And the video file is recorded by cellphone and later re-encoded using handbrake.
Any help is appreciated.
