I’m not entirely sure under which topic to report this. Anyway, as per subject, I applied the latest update to Vivaldi, on KDE. When the app is opened, the window appears briefly, but then crashes out. Run from the command line I get as reported below.
Seemingly a problem with the Calendar (which I have never used).
For now I have downgraded back to 5.2.2623.26-1.1, which runs perfectly OK…
$ vivaldi-stable
[12360:12416:0414/114902.723646:ERROR:database.cc(1784)] Calendar SQLite error: code 1 errno 0: no such column: task sql: UPDATE events SET end = due WHERE task = true
[12360:12416:0414/114902.723664:ERROR:calendar_database.cc(49)] Calendar DB failed to migrate from version 11. Calendar API will be disabled.
[12360:12416:0414/114902.723723:ERROR:calendar_backend.cc(124)] INIT_TOO_NEW
[12360:12360:0414/114902.885448:ERROR:system_web_app_manager.cc(320)] Exceeded SWA install retry attempts. Skipping installation, will retry on next OS update or when locale changes.
[12360:12360:0414/114904.673461:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673537:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673584:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673630:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673675:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673720:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[12360:12360:0414/114904.673764:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[0414/114904.730230:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0414/114904.730988:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0414/114904.731090:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0414/114904.731142:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0414/114904.731348:ERROR:elf_dynamic_array_reader.h(64)] tag not found
zsh: segmentation fault (core dumped) vivaldi-stable
Thanks very much for the suggestion, I was able to open with --incognito, disable everything there, then try again … but unfortunately with the exact same result.
Opening in incognito gives me the error messages below. What is baffling me here is that I do not have any extensions enabled now, and I do not have an extension anywhere I can see in my profile with ID mpognobbkildjkofajifpdfhcoklimli
$ vivaldi-stable --incognito
[25283:25341:0414/145122.030469:ERROR:database.cc(1784)] Calendar SQLite error: code 1 errno 0: no such column: task sql: UPDATE events SET end = due WHERE task = true
[25283:25341:0414/145122.030507:ERROR:calendar_database.cc(49)] Calendar DB failed to migrate from version 11. Calendar API will be disabled.
[25283:25341:0414/145122.030628:ERROR:calendar_backend.cc(124)] INIT_TOO_NEW
[25283:25283:0414/145122.148437:ERROR:system_web_app_manager.cc(320)] Exceeded SWA install retry attempts. Skipping installation, will retry on next OS update or when locale changes.
[25283:25283:0414/145123.844146:ERROR:CONSOLE(1)] "syncDetachedTabInformation: The message port closed before a response was received.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/bundle.js (1)
[25283:25283:0414/145123.850740:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Unknown error.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/browser.html (0)
[25283:25283:0414/145124.661469:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://extensions/". Extension manifest must request permission to access this host.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/browser.html (0)
[25283:25283:0414/145124.661789:ERROR:CONSOLE(0)] "Unchecked runtime.lastError: Cannot access contents of url "chrome://extensions/". Extension manifest must request permission to access this host.", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/browser.html (0)
[25283:25283:0414/145126.251084:ERROR:CONSOLE(1)] "Uncaught (in promise) [object Object]", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/background-common-bundle.js (1)
[25283:25283:0414/145126.251367:ERROR:CONSOLE(1)] "Uncaught (in promise) [object Object]", source: chrome-extension://mpognobbkildjkofajifpdfhcoklimli/background-common-bundle.js (1)
I should add: I actually get the same error messages when I downgrade to the previous version (with extensions disabled). Except it does not do the segmentation fault.
Thank you for that suggestion. Interesting … it still complains about the extension I don’t have and certainly don’t have enabled, but it doesn’t complain about the Calendar, and it does not segfault.
However if I switch back to Person 1 (so imaginatively named ), back to all same error messages, and it segfaults.
I suppose I am going to have to face up to the facts and re-install … ach, all those passwords and extensions to restore
This shows that it’s a user profile / config issue; not a system nor Vivaldi issue. Somewhere in your “Person 1” profile folder is an errant config file, possibly.
Why reinstall? Are you referring to reinstalling Manjaro? Reinstalling Vivaldi?
Sorry, yes I just mean re-install Vivaldi. I know I could be smarter and just create a new profile, but to be honest I think it’s ultimately less work to just save my bookmarks and start from scratch, and besides, I am not quite sure what part of Vivaldi configs I’ve broken, when or how.
I marked as solved, but as a postscript: running version 5.2.2623.34, which came out just a couple of hours ago, gives the same error messages but does not crash
Vivaldi was crashing for me this morning but only on my Default profile. So I knew nothing drastic needed to be done like reinstalling or deleting everything. I figured that it probably had something to do with restoring tabs/session, so what worked for me was going to .config/vivaldi/Default/Sessions and deleting the following files: Session_123456789 and Tabs_123456789. I might not have needed to delete both those files but that’s what I did .
Thanks ydar, and winnie again, if I could mark both as solutions I would. ydar’s solution is certainly much less dramatic than a re-install. (Although I was lucky and did not actually re-install, given the newer update just worked.)
@drfear, if you don’t give me back my hard-earned Solution trophy, then you will know the true meaning of fear! Mark my words I wi-. Ohhhhhh. Your name is “Dr. Fear”? Nevermind then. I thought you were “DRF Ear”.
I apologize again! Although in a way now the whole question has become redundant, I rather suspect it might crop up again in a future release. A while back I had a problem with opening Sessions saved in a previous version (using the Save all tabs as session thing) causing the newer version to crash. Seems the code is a bit sensitive on this feature.
I overcame that one by not using the feature at all, preferring Bookmark all tabs (which puts a lot less strain on the system too).
Last but not least, people do assume my username is some kind of gamer tag, but actually Dr Fear is my real name
