Visual glitches in Apps menu
In the Apps menu, if I scroll the lists, the caption starts to break. The same happens not only with folders, but also in general if you scroll through the whole list of applications.
ASUS Vivobook S 15 M5506WA_M5506WA
AMD Ryzen AI 9 HX 370
AMD Radeon 880M / 890M [Integrated]
Linux 6.14.0-1-MANJARO
GNOME 48.0
Built-in display
Resolution: 2880 x 1620
Scale: 175%
External display:
Resolution: 3440 x 1440
Scale: 100%
I’ve tried changing the scaling, including disabling it completely, but it doesn’t help.
EDIT: It happens only on external display, if i turn it off than on built-in display everything works fine.
EDIT 2: Added inxi output.
Screencast
  Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=a72d381b-e8cb-4965-9e6b-856be8c46f14 rw zswap.enabled=0 quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ASUS Vivobook S 15 M5506WA_M5506WA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: M5506WA v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: M5506WA.313
    date: 03/19/2025
  ID-1: BAT1 charge: 60.3 Wh (80.7%) condition: 74.7/74.9 Wh (99.8%)
    volts: 16.6 min: 16.0 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 30.46 GiB used: 7.56 GiB (24.8%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 7500 MT/s volts: curr: 0.5 min: 0.5
    max: 0.5 width (bits): data: 32 total: 32 manufacturer: Micron Technology
    part-no: MT62F2G32D4DS-026 WT serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen AI 9 HX 370 w/ Radeon 890M bits: 64 type: MT MCP
    arch: N/A level: v4 note: check family: 0x1A (26) model-id: 0x24 (36)
    stepping: 0 microcode: 0xB20401B
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 24 MiB desc: 1x16 MiB, 1x8 MiB
  Speed (MHz): avg: 2006 min/max: 599/5157:3289 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2006 2: 2006 3: 2006
    4: 2006 5: 2006 6: 2006 7: 2006 8: 2006 9: 2006 10: 2006 11: 2006 12: 2006
    13: 2006 14: 2006 15: 2006 16: 2006 17: 2006 18: 2006 19: 2006 20: 2006
    21: 2006 22: 2006 23: 2006 24: 2006 bogomips: 95811
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Strix [Radeon 880M / 890M]
    vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4, DP-5, DP-6,
    DP-7, HDMI-A-1, Writeback-1 bus-ID: 63:00.0 chip-ID: 1002:150e
    class-ID: 0380 temp: 47.0 C
  Device-2: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 3277:0060
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Mi Monitor built: 2020 res: 3440x1440 dpi: 110
    gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green: x: 0.286 y: 0.639 blue:
    x: 0.133 y: 0.075 white: x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15")
    diag: 864mm (34") modes: 3440x1440, 2560x1080, 1720x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: eDP-1 model: Samsung 0x4180 built: 2021 res: 2880x1620 dpi: 213
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
    x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 2880x1620, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
    gfx1150 LLVM 19.1.7 DRM 3.61 6.14.0-1-MANJARO) device-ID: 1002:150e
    memory: 500 MiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 63:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    driver: snd_acp_pci v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 63:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 63:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: FIFINE 683 Microphone driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4:5 chip-ID: 3142:0031
    class-ID: 0102
  API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 62:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp98s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0489:e0f5
  Local Storage: total: 953.87 GiB used: 145.15 GiB (15.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: MTFDKBA1T0QFM-1BD1AABGB size: 953.87 GiB block-size: physical: 512 B
    fw-rev: V3MA101 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 250 GiB size: 245.02 GiB (98.01%) used: 145.06 GiB (59.2%)
    fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: a72d381b-e8cb-4965-9e6b-856be8c46f14
    used: 85.2 MiB (88.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 34FC-2D27
  ID-1: swap-1 type: zram size: 30.46 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
    dev: /dev/zram0
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 703.12 GiB fs: ntfs label: N/A
    uuid: C600FDCE00FDC589
  ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 650 MiB fs: ntfs label: N/A
    uuid: 7C18E38D18E344AC
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 1-1:2 info: Shinetech USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0060 class-ID: fe01
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Hub-4: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-5: 3-1.1:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 3-1.4:5 info: FIFINE 683 Microphone type: audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 3142:0031 class-ID: 0102
  Device-2: 3-4:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0f5 class-ID: e001 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 4-1:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-8: 4-1.1:3 info: Realtek Hub ports: 4 rev: 3.2
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 50.2 C mobo: 38.0 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (rpm): N/A
  Packages: 1278 pm: pacman pkgs: 1231 libs: 325 tools: pamac pm: flatpak
    pkgs: 47
    1: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    4: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    5: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    6: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 517
  1: cpu: 3.4% command: gnome-shell pid: 49968 mem: 491.5 MiB (1.5%)
  2: cpu: 3.3% command: chrome pid: 55628 mem: 268.8 MiB (0.8%)
  3: cpu: 3.0% command: Discord pid: 52318 mem: 325.5 MiB (1.0%)
  4: cpu: 1.9% command: telegram-desktop pid: 52006 mem: 1013.1 MiB (3.2%)
  5: cpu: 1.1% command: chrome pid: 51623 mem: 322.7 MiB (1.0%)
  Memory top: 5 of 517
  1: mem: 1013.1 MiB (3.2%) command: telegram-desktop pid: 52006 cpu: 1.9%
  2: mem: 607.7 MiB (1.9%) command: firefox pid: 52633 cpu: 0.7%
  3: mem: 499.1 MiB (1.6%) command: chrome pid: 51547 cpu: 0.8%
  4: mem: 491.5 MiB (1.5%) command: gnome-shell pid: 49968 cpu: 3.4%
  5: mem: 484.3 MiB (1.5%) command: firefox pid: 52931 cpu: 1.1%
  Processes: 517 Power: uptime: 4h 43m states: freeze,mem,disk suspend: s2idle
    image: 12.16 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: gnome-terminal
    inxi: 3.3.38
Mod edit:- Please always enclose code or command output as preformatted text. This has been done for you by way of example - in future, you are expected to apply the formatting accordingly - see relevant link(s) (also below).
Please provide system information as descibed (below).
Once that is done it might be easier for those wishing to help, to form an opinion (or an educated guess).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
