Hello!
I’m wondering if it’s possible to set up virtualization with GPU passthrough on an APU.
If so, how would i go about it? The main reason i want to do this is so i can use Affinity software for work, and it doesn’t work with wine, bottles or anything like that, people have tried, so i need it run “natively” in a virtual machine.
Trying to fully switch to linux, this is kind of the final piece of the puzzle… For now, i still have windows 10 installed on another drive when i need those applications. Which Manjaro casually recognized and set up in grub so i don’t have to boot from bios which is very nice, i like that already! ![]()
But i’m trying to get rid of windows cause windows 11 is testing my limits for various tracking stuff. Kinda want to get out of the building before the dumpster fire sets it ablaze you know?
But having it installed just for affinit AND in a virtual machine is good enough for me to use windows that way.
Or if there’s a way to “skip” windows desktop and have affinity windows appear as if they’re part of manjaro desktop, that would be super, but baby steps…
Back to virtualization - i’ve hear also that you need to have 2 GPUs for GPU passthrough to work, is that correct? And that APU is impossible because GPU passthrough needs a PCIE card?
If that’s the case - i do have an old (but officially not supported anymore) AMD card, R7 260x which was good enough for Affinity when i used it on windows, will that work for GPU passthrough?
And if i install it in my computer, i want to keep using the APU as my main GPU for manjaro and all its programs and games, will i be able to do that or will it automatically want to use the PCIE one?
Bottom line is - i’m very new at this, i dabbled with virtualbox, boxes, bottles and vwware player (which i couldn’t get to work), but nothing ever as complex or fancy as i’m trying to do now.
Where do i start?
I guess here, on the forums, but i’m also looking for info, guides, maybe help troubleshooting if needed.
Thank you for reading, and thanks in advance for any help!
EDIT: System info in case it’s needed.
Kernel: 6.1.0-x64v1-xanmod1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-manjaro-xanmod
root=UUID=3c103b00-38b2-448f-963d-b21e21c8d003 rw rootflags=subvol=@ quiet
resume=UUID=2e8c475c-b939-46e7-bf7f-71596d247bbe udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
UEFI: American Megatrends LLC. v: P2.30 date: 02/24/2022
RAM: total: 15.01 GiB used: 5.41 GiB (36.1%)
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3677 high: 3900 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3067 2: 3900
3: 3900 4: 3900 5: 3900 6: 2971 7: 3900 8: 2993 9: 3900 10: 3900 11: 3900
12: 3900 bogomips: 93426
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm)
built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: DP-1,HDMI-A-1 empty: DP-2 bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 30.0 C
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x1440
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.0-x64v1-xanmod1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: bus-ID: 3-2.4:5 chip-ID: 1235:8200 gen: 3 speed: 8 GT/s
class-ID: 0103 lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i4 USB type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.1.0-x64v1-xanmod1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 3-2.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 698.65 GiB used: 189.82 GiB (27.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: SBI02102 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 rev: ZL0C dev-links: cdrom
ID-1: / raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
used: 189.82 GiB (42.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 3c103b00-38b2-448f-963d-b21e21c8d003
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: BE32-0B52
ID-3: /home raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
ID-4: /var/cache raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
ID-5: /var/log raw-size: 448.97 GiB size: 448.97 GiB (100.00%)
Kernel: swappiness: 30 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 16.5 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 2e8c475c-b939-46e7-bf7f-71596d247bbe
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 4679-8A08
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 232.27 GiB fs: ntfs label: N/A
uuid: DCCC7B38CC7B0C50
ID-4: /dev/sda4 maj-min: 8:4 size: 510 MiB fs: ntfs label: N/A
uuid: CC006C1E006C122E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Sunplus Innovation Gaming Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 1bcf:08a6 class-ID: 0300
Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-8:4 info: ASRock LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 3-2.1:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 3-2.3:4 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Device-3: 3-2.4:5 info: Focusrite-Novation Scarlett 2i4 USB type: Audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 1235:8200 class-ID: 0103
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-8: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.5 C mobo: N/A gpu: amdgpu temp: 30.0 C
Processes: 345 Uptime: 24m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1717 libs: 478 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
