Virtualbox will not start with Picom installed
If I did " inxi -G --verbosity=3 | grep Gen | tail -1 I" i get only:
v: kernel arch: Gen-7 bus-ID: 00:02.0
and " `glxinfo | grep renderer":
GLX_MESA_copy_sub_buffer, GLX_MESA_gl_interop, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: Mesa Intel(R) HD Graphics 4000 (IVB GT2)
What could be wrong with my setup?
I am in unstable, if I did “picom --diagnostics” the result is that “egl” is using driver “crocus”, no driver “i915”, there are references of “i915” in the journal:
20/04/2025 12:24 kernel i915 0000:00:02.0: [drm] Found ivybridge (device ID 0162) integrated display version 7.00 stepping N/A
20/04/2025 12:24 kernel i915 0000:00:02.0: vgaarb: deactivate vga console
20/04/2025 12:24 kernel [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
20/04/2025 12:24 kernel fbcon: i915drmfb (fb0) is primary device
20/04/2025 12:24 kernel i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
20/04/2025 12:24 kernel snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
*Maybe I should open a separate thread for this.
*VirtualBox don’t start.
Agreed. I have done that for you.
Please provide full system information as described (below).
I’m sure someone will help when they are able.
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly. :eyes:
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
… perhaps also explain with some more words what the actual problem is - I couldn’t figure it out as of yet
it may be:
but that is just a guess
  Kernel: 6.14.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.14-x86_64
    root=UUID=6de4fb56-b44f-41aa-b1a4-deb54d563085 rw rootflags=subvol=@
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: plank,xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: ASRock model: H61M-HG4 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: P1.10
    date: 07/11/2013
  System RAM: total: 16 GiB available: 15.32 GiB used: 3.02 GiB (19.7%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1067 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: 0b29 part-no: KAi-D3ZU1600M serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1596 min/max: 1600/3900 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1596 2: 1596 3: 1596 4: 1596 5: 1596 6: 1596
    7: 1596 8: 1596 bogomips: 55869
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: ASRock driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0162
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.16 compositors: 1: Picom v: 12.5
    2: xfwm4 v: 4.20.0 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: crocus gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: VGA-1 model: AOC 2243W built: 2010 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
    x: 0.282 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314 y: 0.329
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1024x768,
    832x624, 800x600, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 25.0.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) device-ID: 8086:0162 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 4000 (IVB GT2) driver: mesa intel v: 25.0.3-arch1.1
    device-ID: 8086:0162 surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    x11: xprop,xrandr
    vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  API: ALSA v: k6.14.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.84 TiB used: 2 TiB (70.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 7100 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingfast model: N/A size: 111.79 GiB
    block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 7B0 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1CH162
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC47 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST1000DM003-1ER162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC45 scheme: GPT
  ID-1: / raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
    used: 28.92 GiB (25.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 6de4fb56-b44f-41aa-b1a4-deb54d563085
  ID-2: /HD.Interno1 raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 779.59 GiB (85.1%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
    label: HD.Interno1 uuid: 9deb02ee-01f3-4af4-8a78-e81b27110035
  ID-3: /SSD.Interno2 raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 775.25 GiB (84.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: cae17524-8529-49a4-9e3b-c9f7745cf7ce
  ID-4: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 600 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 4EBB-4173
  ID-5: /home raw-size: 852.89 GiB size: 839.3 GiB (98.41%)
    used: 468.56 GiB (55.8%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: /Home
    uuid: 699b293f-6d02-4a7b-ba34-a85e9e8367a2
  ID-6: /var/log raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: b6a5e76a-77c9-43bf-a133-b0271a7c26a7
  ID-1: /dev/sdc1 maj-min: 8:33 size: 63 GiB fs: ext4 label: N/A
    uuid: 5339679a-ce7b-41fb-8c07-488ae54cb8c6
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.4:3 info: Dell Universal Receiver type: keyboard,mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 413c:2519 class-ID: 0300
  System Temperatures: cpu: 27.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1534 libs: 457 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
    2: https://manjaro.kurdy.org/unstable/$repo/$arch
    3: https://mnvoip.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://ziply.mm.fcix.net/manjaro/unstable/$repo/$arch
    5: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
    6: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    7: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
    8: https://mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 271
  1: cpu: 100% command: ps pid: 52412 mem: 3.91 MiB (0.0%)
  2: cpu: 5.9% command: xfce4-terminal pid: 52289 mem: 62.0 MiB (0.3%)
  3: cpu: 5.4% command: Xorg pid: 917 mem: 114.6 MiB (0.7%)
  4: cpu: 5.2% command: firefox pid: 10849 mem: 567.0 MiB (3.6%)
  5: cpu: 2.5% command: conky pid: 1613 mem: 18.1 MiB (0.1%)
  Memory top: 5 of 271
  1: mem: 567.0 MiB (3.6%) command: firefox pid: 10849 cpu: 5.2%
  2: mem: 411.5 MiB (2.6%) command: jellyfin pid: 780 cpu: 0.4%
  3: mem: 315.5 MiB (2.0%) command: firefox pid: 11149 cpu: 0.4%
  4: mem: 311.3 MiB (1.9%) command: variety started-by: python pid: 1263
    cpu: 1.4%
  5: mem: 275.5 MiB (1.7%) command: dropbox pid: 1287 cpu: 0.5%
  Processes: 271 Power: uptime: 1h 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.12 GiB Init: systemd v: 257
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.38
VirtualBox shows only a cloudy window ( I don’t know quite the word, I see the window is there, but could not move or do anythig with it, except close).
As I said, I am using picom, in the Xfce.
So:
my guess was right?
This is about something not working as expected in VirtualBox?
Still not sure. :man_shrugging:
Even less about what the actual problem might be.
Use words to explain what the perceived problem is.
just for example:
picom is used in the host - or in the guest?
I have never had problems replacing the xfce4 compositor with picom :man_shrugging:
I have done that in the past - for reasons I forgot.
There was never a problem - but that was a long time ago.
I also stopped using VirtualBox - in favor of kvm/qemu (virt-manager)
Your general setup seems
OK
  • You have swap enabled with more than your ram :ok:
Off topic
  • You missed the chance to use RAID with btrfs :man_shrugging:
    • If you have more than one physical device, you can create a raid setup with btrfs. This way, if one of the devices fails, you do not loose any data.
:footprints:
in the host. I don’t have any other computer.
If disable picom, the VirtualBox appears but I could not had any machine.
Yes, I was thinking about this, It’s time to try another virtual-manager.
I always wanted to do this, and soon I will do it. Not now.
Xfce4 and picom as compositor on the host …
That should not have any impact on the guest.
That is all I know.
What the f is the problem?
The problem is that VirtualBox don’t start and with the problems with drives in the [Stable Updates] 2025-04-12 - Kernels, Plasma, Systemd, Mesa, Grub, Wine3 - #106 by Aragorn I thought it was related.
*I think my computer is going obsolete. Picom is using egl driver “crocus”. Last time I did “picom --diagnostics” it was “i915”, if I am not wrong.
I don’t think so.
I still don’t know what that is supposed to mean.
What is your freaking problem?
Just say it - just describe what is vs what you expect to happen.
Describe the situation in detail.
What is it that you want to do?
which apparently doesn’t work the way you think it should
I don’t know how to ask for more precise info.
So there is no problem with Picom using this driver and the VirtualBox not appearing? Other things works good with Xfce.
I have no freaking idea.
You have not given nearly enough information.
… still not - after repeated requests …
good luck with solving whatever your ill defined problem is stemming from
picom is a compositor and xfce4 provides it’s own compositor.
If you are using both - the result is unpredictable and may cause blurry windows - especially with a hypervisor.
First ensure you only use one compositor - I suggest you prefer xfce4 - but if you really want picom - you need to disable xfce4 compositor and configure picom to exclude virtualbox.
[root tip] [How To] VirtualBox - Installation - USB - Shared Folder
I am using only Picom.
Please see the topic linked above - the last section contains some troubleshooting tips related to distorted background in virtual machines running on VirtualBox.
If I understand properly, you are trying to tell us that Virtualbox doesn’t start when running picom, and it does when you disable it, is that correct?
If so (and as @linux-aarhus mentioned) , XFCE already has it’s own compositor, and you should ideally be using it.
The “cloudy window” you mentioned (whatever that means) might be easier to diagnose with Manjaro as close to stock as possible.
In any case, I have renamed the topic to something that better reflects the issue at hand.
Feel free to change it again if needed.
I will give up to VirtualBox, I think is not the compositors.
Do you require further assistance or would you like us to close this topic?
You can close this topic. “Cloudy window” means it the window is opaque. because of this I thought it was the compositor, but if I disable any compositor the window appears and I could add a new iso of OS but then it stop to work and freeze. That’s why I thought it was some changes in the driver or my system have stop to accept what was new in the VirtualBox.
*I have enabled Intel Virtualization.
