Virtualbox - Virtual Media Manager missing choice
I have a virtual machine that I want to make larger and the instructions I found state I need to go to the File menu and select “Virtual Media Manager”. But when I select File menu there is no choice there for Virtual Media Manager.
Do I need to install something else?
Hi @MAYBL8,
You didn’t specify in what software you use the Virtual Machine. I’m guessing Virtualbox since QEMU is most, if not completely CLI.
I do not know. Please provide the output of:
pamac search --installed virtualbox
[demo@Manjaro ~]$ pamac search --installed virtualbox
virtualbox-host-dkms  7.1.4-2        extra
    VirtualBox Host kernel modules sources
virtualbox-guest-utils  7.1.4-2        extra
    VirtualBox Guest userspace utilities
virtualbox-guest-iso  7.1.4-1        extra
    The official VirtualBox Guest Additions ISO image
virtualbox  7.1.4-2        extra
    Powerful x86 virtualization for enterprise as well as home use
Hmmm…
I quickly checked and couldn’t find anything, and I don’t really use Virtual machines, but maybe this helps:
https://www.baeldung.com/linux/virtualbox-resize-hard-disk
Ok I think I figured it out.
If you goto Tools then Media there is a slider bar at the bottom.
This is different than the other instructions I found.
Thanks
