In the USB settings, USB controller is hard-enabled, I can’t untick it.
And it is set to USB 1.1
I cannot select USB 2 or USB 3.
It seems that this happened when I updated the Extension Pack to 6.1.36-1
VB version VirtualBox Graphical User Interface Version 6.1.34 r150636.
~ inxi -F ✔ 9s
Host: shmuel-manjaro Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 42.3.1 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/10/2019
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 4500 min/max: 800/4700 cores: 1: 4467 2: 4490 3: 4492
4: 4490 5: 4432 6: 4495 7: 4559 8: 4575
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo
Display: wayland server: X.Org v: 22.1.3 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting gpu: i915
resolution: 1: 1920x1080~120Hz 2: 1600x900~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 22.1.3
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.56 running: yes
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
Device-2: Realtek 802.11ac NIC type: USB driver: N/A
driver: btusb
Local Storage: total: 2.26 TiB used: 787.52 GiB (34.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 249.62 GiB used: 110.31 GiB (44.2%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 96 MiB used: 37.8 MiB (39.3%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 318 Uptime: 3h 37m Memory: 15.49 GiB used: 10.58 GiB (68.3%)
Shell: Zsh inxi: 3.3.19
