It doesn’t seem to help. I’ve read through that article. The issue is that for some reason virtualbox doesn’t have permission to browse the file system unless I run as root. I’ve added my current user to the vboxusers group. It seems like the vboxusers group itself does not have permission to read files
Did you log out and back in or reboot the system. Oppening GUI applications as root is not a good approach.
Open it from terminal and share the errors you get there.
Gnome, stable release. I installed polkit as it was not installed, rebooted, verified it was running with ps aux | grep “polkit” attempted to open virtualbox from the terminal and load installation media and nothing happened when I clicked add
Not that i want to antagonize … but first of all, polkit is installed by default on all Manjaro releases.
When creating a new Virtual macine, the virtual optical disk is always there … so i wonder how did you installed Manjaro, Gnome and how you handle the VM creation part. But since you solve it, good for you.
I know i might be late but i had the same problem. I solved it by moving the windows iso to the home/virtualbox vms . Then i opened virtual box i pressed chose a disk file and typed the name in the promt
