Testing VirtualBox after today’s big upgrade, I noticed it was crashing when I tried to start a VM.
However, doing some restores on my “playground” root partition suggests that the problem may have been introduced in 2022-01-02, as it only starts working again when I restore back to before that update (I only occasionally use VirtualBox, so hadn’t tried it this year).
The journal shows:
Jan 24 15:55:21 kernel: SUPR0GipMap: fGetGipCpu=0xb
Jan 24 15:55:22 kernel: vboxdrv: 00000000d6420fc8 VMMR0.r0
Jan 24 15:55:22 kernel: vboxdrv: 000000003f8181d0 VBoxDDR0.r0
Jan 24 15:55:23 kernel: vboxdrv: 000000008f84d873 VBoxEhciR0.r0
Jan 24 15:55:23 kernel: VMSVGA FIFO[3556]: segfault at f8 ip 00007f7cb041c159 sp 00007f7c32d8bbd0 error 4 in libX11.so.6.4.0[7f7cb041a000+8a000]
So it seems that something doesn’t like libX11.
I’ve tried downgrading the various VirtualBox packages but the problem still persists, so I can only assume it’s due to something else that it interfaces with that’s changed.
I’ve edited /bin/VBox so it runs /usr/lib/virtualbox/VirtualBox through gdb, but that doesn’t give any useful information because it isn’t compiled with debugging symbols. So I’m somewhat stumped as to what to try next to debug this problem. I’d appreciate any pointers as to other things I can try.
Mine is working perfectly. If you have virtualbox-ext-oracle installed, check if its version is the same than the version of virtualbox.
pacman -Q | grep virtualbox
All packages in the output of this command should have the same version. Not always, but sometimes an earlier version of virtualbox-ext-oracle can trigger errors when launching VMs.
I think you’ve hit on it. Thanks.
As you surmised, virtualbox-ext-oracle seems to be the problem. I’ll try reinstalling it to see if that updates it.
[Edit]: that didn’t help, so I tried removing virtualbox-ext-oracle, which broke my printer as that package provides USB2 support. Looks like I’ll need to go over to the AUR version of Virtualbox to get everything in sync.
Thanks again for pointing me in the right direction.
