Hello. I am experiencing the same issue as OP.
I am running kernel 6.12
I have done the exact same thing as described in the previous posts and still have the same issues.
On sudo vboxreload i get
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/6.12.19-1-MANJARO
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/6.12.19-1-MANJARO
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/6.12.19-1-MANJARO
Please do not post your issue on another member’s topic; that’s usually referred to as hijacking; and especially not a topic that’s a year old, typically referred to as necrobumping.
Yes, there’s probably a name for everything.
Please list everything you have done to solve your issue.
Note that;
doesn’t particularly help anyone understand a problem specific to your environment. Telling us directly, will go further toward that goal.
Please also provide system information as described (below). It might also be beneficial to re-familiarise yourself with forum rules, generally.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
It might have been obvious from the topic you attempted to hijack that those instructions may not have been complete; or, that those helping were only responding to specific parts of the process.
The best resource is invariably The Wiki (either Arch or Manjaro). It’s only if you need help with those instructions that a Support topic might be needed.
I see that you are running kernel 6.12. Please read the following:
“In [Linux] kernel 6.12, KVM initializes virtualization on module
loading by default. This prevents VirtualBox VMs from starting,”
said the devs. “In order to avoid this, either add
“kvm.enable_virt_at_load=0″ parameter
into kernel command line or unload the
corresponding kvm_XXX module.”
So, try adding the kernel parameter to grub:
Virtualbox Kernel 6.12 kernel command line parameter in GRUB:
Then sudo update-grub
Reboot for good measure and see if any progress was made.
Also, do you have linux612-headers and linux612-virtualbox-host-modules installed?
@anon60967430 The source was at the following url, but when this issue first arose, I think it was also mentioned on the virtualbox website.
That is quite strange - on my laptop with Linux 6.12 - I have an ubuntu vm running in virtualbox - they have never heard of this - they just work.
I am not aware this should be added on a host running Manjaro - apparently SUSE had issues - I have no record of it being an issue on Manjaro.
This is pure speculation - theoretically it could be an issue - perhaps even necessary if you were to extend the CPUs virtual capabilities onto the vm - something like running a vm inside a vm - but such scenario is highly specialised and not likely to happen with a Manjaro Linux host system.
Thank you for the clear instructions.
Yes I posted on that thread thinking is was still active. (was a little fast and didn’t register that is was from 2024).
I have tried all instructions and variants listed in both the Manjaro wiki and the Arch wiki. Still getting the same issue.
I have not tried to change kernel, but will do that as next step
Thanks. Based on your comment, I removed the kernel parameter and virtualbox is working fine without it. I haven’t checked with 6.12 as I am running 6.14. I do recall needing the kernel parameter to get virtualbox to run on my Manjaro Host at one time. It didn’t occur to me to test a few months down the road now, without the kernel parameter.
