After the update, the VM was just automatically being “paused”, when I tried to boot it.
No password-prompt for the encrypted VM. Just kept hanging in “paused”-state. When “unpausing” the VM, the cursor started blinking again … but nothing else would happen.
Then, I did:
pacman -Rc virtualbox virtualbox-dkms
pacman -Scc
pacman -Syyuu
pacman -S virtualbox virtualbox-dkms
And then installed the current Extension-package from here:
https://www.virtualbox.org/wiki/Downloads
After that, the VM booted again. Everything seemed to run fine, but I noticed glitches, here and there (e.g. when hovering on any random element of a website, a purple rectangle would appear and almost instantly disappear again … or rectangles, that showed content from other tabs, etc … in short: gfx-glitches).
Especially when playing a video on youtube (inside the VM) … and then suddenly the image froze and I could do nothing anymore (no hotkeys … no mouse-clicks … sometimes, I’d be able to see the scrollbars highlight, when I hovered over them with my mouse-pointer, but that would be all).
I’ve had 3D-acceleration enabled (in the virtualbox-settings for the VM) and it crashed over and over again. Now, I’ve disabled 3D-acceleration and it still crashes.
I haven’t even touched Firefox or youtube (was using Brave on reddit, when it recently happened again … twice in a row, when I was just typing a post … nothing, that would put any strain on my graphics-card).
So, I don’t know, if it has anything to do with the browsers, I use … or the websites, I’m trying to use … or if it’s just gonna keep happening, randomly, no matter what I do …
Before the update, I had zero problems, with that VM.
If you need more data to help, just ask … I’ll try to make it as easy as possible.
Is this a bug or can I fix this myself, somehow?
