VirtualBox is stuck at 20%
My system froze, so I had to perform a forced reboot. Afterward, VirtualBox started acting up. I thought that the files may be corrupt, so I reinstalled VirtualBox. I’m still running into trouble. I tried to create a new Win7 virtual machine and it is stuck at 20%.
Here is the VBox.log:
00:00:01.422820 VirtualBox VM 7.2.2 r170484 linux.amd64 (Sep 11 2025 11:31:33) release log
00:00:01.422822 Log opened 2025-10-21T23:59:56.357045000Z
00:00:01.422823 Build Type: release
00:00:01.422824 OS Product: Linux
00:00:01.422825 OS Release: 6.15.0-3-rt2-MANJARO
00:00:01.422826 OS Version: #1 SMP PREEMPT_RT Fri Aug 15 13:17:15 UTC 2025
00:00:01.422858 DMI Product Name: HP Z840 Workstation
00:00:01.422870 DMI Product Version:
00:00:01.422878 Firmware type: BIOS
00:00:01.422919 Host RAM: 64304MB (62.7GB) total, 62723MB (61.2GB) available
00:00:01.422922 Executable: /usr/lib/virtualbox/VirtualBoxVM
00:00:01.422923 Process ID: 3132
00:00:01.422923 Package type: LINUX_64BITS_GENERIC (OSE)
00:00:01.438879 Installed Extension Packs:
00:00:01.438896   None installed!
00:00:01.440657 Console: Machine state changed to 'Starting'
00:00:01.440981 GUI: Qt version: 6.9.2
00:00:01.440988 GUI: X11 Window Manager code: 4
00:00:01.440992 GUI: HID LEDs sync is not supported on this platform
00:00:01.455814 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:01.456153 X Server details: vendor: The X.Org Foundation, release: 12101018, protocol version: 11.0, display string: :0
00:00:01.456159 Using XKB for keycode to scan code conversion
00:00:01.458315 SUP: seg #0: R   0x00000000 LB 0x00050000
00:00:01.458340 SUP: seg #1: R X 0x00050000 LB 0x00247000
00:00:01.458343 SUP: seg #2: R   0x00297000 LB 0x00073000
00:00:01.458346 SUP: seg #3: RW  0x0030a000 LB 0x0002db08
00:00:01.518149 GUI: UIDesktopWidgetWatchdog::sltHandleHostScreenAvailableGeometryCalculated: Screen 0 work area is actually resized to: 0x0 x 1629x995
00:00:01.526322 GUI: UIDesktopWidgetWatchdog::sltHandleHostScreenAvailableGeometryCalculated: Screen 1 work area is actually resized to: 1680x0 x 1629x1018
00:00:01.901148 GUI: UIMediumEnumerator: Medium-enumeration finished!
I’m running Manjaro MATE with the 6.15.0-3-rt2-MANJARO kernel.
Other system stats:
CPU: Intel Xeon E5-2620 v3 (24) @ 3.200GHz
GPU: NVIDIA Quadro K4200
I need this VM to run a couple of old Windows programs for work.
This may well have been the precursor to your issues. It is possible to avoid hard resets or shutdowns using REISUB/REISUO:
Note that kernel 6.15 reached EOL five months ago and updates are no longer provided from the Manjaro repositories.
It is strongly suggested to switch to another kernel at your earliest convenience – current viable options include kernels 6.17 or 6.12 (LTS) – the latter is generally recommended.
Which programs might they be? Perhaps someone will have an alternative to suggest, or a WINE based solution.
Please provide system information as described (below) which may allow others to identify other possible contributors to the problem.
I’m sure someone will help when they are able.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
It is impossible to guess what happened … but your issue look like - albeit which another origin
→ Since May/June 2025: VirtualBox - cannot create new VMs and add existing VMs
→ Virtualbox: cannot create new VMs nor add existing VMs
I don’t know if your use of an RT kernel is necessary - but if it is - you can get a supported kernel.
I suggest you switch to a supported kernel.
sudo mhwd-kernel -i linux617-rt
Or the LTS version
sudo mhwd-kernel -i linux612-rt
There are reasons to want to run a real time kernel.
For most people it is not a good idea.
Try installing and booting a “normal” one.
I tried to run that command and got this error:
johnblood@dreadnought ~> sudo mhwd-kernel -i linux617-rt
Error: Please make sure if the given kernel(s) exist(s).
available kernels:
   * linux510
   * linux515
   * linux54
   * linux61
   * linux612
   * linux616
   * linux617
   * linux66
   * linux61-rt
   * linux612-rt
   * linux615-rt
   * linux616-rt
   * linux66-rt
These are the kernels listed in my Manjaro Settings Manager:
Then choose one of the
preferably one that has not got a -rt extension to it’s name
(unless you actually do need to use a -rt kernel for your specific purpose)
Yes - I see - 6.17-rt is in testing.
But as I suggested - you also have the option 6.12 as rt.
Nope. I’m just a normal user.
A realtime kernel is typically used for specific professional application; music production (as one example), and even then very rarely.
Do you have a valid reason for using a realtime kernel?
If not, I’d strongly suggest using a standard kernel – as mentioned earlier, kernel 6.12 (LTS) or 6.17 are viable.
Of course, older LTS kernels are also available but the presumption is that you don’t want any of those.
I believe the intention was to convey that you shouldn’t be using 6.15…
Note that linux617-rt is not (yet) available to Stable branch, but it is in Unstable and Testing. You *could’ switch to either of these branches to use that kernel immediately; or you could wait until it reaches Stable.
https://wiki.manjaro.org/index.php/Manjaro_Kernels
Edit:-
A realtime kernel gives you no advantage;
Use one of the initially suggested kernels instead.
Just to add my 2p worth:
A while back I tried a real-time Kernel and found that VirtualBox would not run correctly (locked up after a short period).
I have done some superficial research on the topic of a default Linux kernel and the real-time kernel - dubbed (RT).
I won’t pretend I know a lot - but from my reading - I got the bigger picture.
Some applications are very sensitive to the timing when receiving and processing data from multiple sources - the completion time must be known beforehand.
One example is an A/V mixing application which may receive input from numerous sources at the same time - thus such application may benefit from RT kernel.
I am saying may because recent kernels have some built in configuration which makes it next to obsolete to use a special RT kernel.
So my initial suggest still stands - remove the RT kernel - unless you specifically know you require a kernel compiled for RT for use with a given application.
As per you own comment - you don’t need an RT kernel - and with reference to
It is the advise to remove the RT kernel and use the default provided in the repo either the current mainline stable linux617 or the current LTS linux612.
Check the running kernel
mhwd-kernel -li
Then - if the running kernel is linux615-rt - run the following command
sudo pacman -Syu
sudo mhwd-kernel -i linux617 rmc
Otherwise run
Finally restart your system - ensure you hit grub menu using a hotkey and verify if the issue persist.
Sorry for not replying sooner. I switched to the 6.17 kernel and now VirtualBox works. I didn’t realize that it would cause an issue because I’ve been on an rt kernel for several months without issue. Thanks for all your help.
Glad it’s working now; however, it is customary to mark the post which most helped you as the Solution.
Cheers :wink:
Then let’s mark the post that makes better sense as the solution, shall we.
