Hello everyone!
Here is my concern, I recently installed virtualbox under manjaro, latest version of GNOME, ok, and I have an error with the following command:
“sudo systemctl enable --now vboxservice.service”
The command returned is :
“Failed to enable unit : Unit file vboxservice.service does not exist”
No matter how hard I look, I can’t find the solution at all, and one last thing…
When I run a VM, the startup stops at 20% and freezes… I can’t do anything, so if any of you have a solution ![]()
