I’m experiencing a strange and annoying issue when running VirtualBox guests on Manjaro. When using key combinations like Alt+Tab, Alt+F4 etc., those are interpreted by both KDE Plasma and the currently running VM.
For example, when running a Windows guest and pressing Win+E, both Windows’ Explorer and KDE Plasma’s Dolphin are launched. When pressing Alt+F4, both Virtualbox’s dialog for shutting down the VM and Windows’ shutdown dialog appears.
Now there is an option in VirtualBox’s settings which is directly related to this: Input → Extended Features: Auto Capture Keyboard
When enabled, behavior is like mentioned above. When disabled, only KDE Plasma receives the key combination and the guest does not react at all.
I’m not sure when this behavior started, but I know that it was different in the past. Does anyone have any ideas how this might be fixed?
System Information:
KDE Plasma Version: 6.1.5
KDE Frameworks Version: 6.6.0
Qt Version: 6.7.2
Kernel Version: 6.10.13-3-MANJARO (64-bit)
Graphics Platform: X11
Processors: AMD Ryzen
Graphics Processor: NVIDIA
Virtualbox: 7.1.2
