after i install windows 8.1 on virtualbox i try to run virtualbox guest addistion and i get error
error execution / file VboxDrvInst.exe
This is not directly related to manjaro, so:
Maybe you will get better support for this in virtualbox forum.
You should try Windows support, since the issue is in the guest Windows 8.1.
