Virtualbox-dkms compile failed with 7.1 kernel
Hi, not sure if this is the right place for this. I installed the update no problem. Then I installed kernel 7.1 and had a problem there. The DKMS compile of the virtualbox driver(s) failed. I fell back to 6.18. Here is the log:
Tue Jun 23 08:38:40 AM EDT 2026
Building module(s)
# command: make -j12 KERNELRELEASE=7.1.1-3-MANJARO -C /usr/lib/modules/7.1.1-3-MANJARO/build M=/var/lib/dkms/vboxhost/7.2.8_OSE/build
make: Entering directory '/usr/lib/modules/7.1.1-3-MANJARO/build'
make[1]: Entering directory '/var/lib/dkms/vboxhost/7.2.8_OSE/build'
  CC [M]  vboxdrv/linux/SUPDrv-linux.o
  CC [M]  vboxnetflt/linux/VBoxNetFlt-linux.o
  CC [M]  vboxnetadp/linux/VBoxNetAdp-linux.o
  CC [M]  vboxdrv/SUPDrv.o
  CC [M]  vboxnetflt/VBoxNetFlt.o
  CC [M]  vboxnetadp/VBoxNetAdp.o
  CC [M]  vboxdrv/SUPDrvGip.o
  CC [M]  vboxnetflt/SUPR0IdcClient.o
  CC [M]  vboxnetflt/SUPR0IdcClientComponent.o
  CC [M]  vboxdrv/SUPDrvSem.o
  CC [M]  vboxnetflt/linux/SUPR0IdcClient-linux.o
  CC [M]  vboxdrv/SUPDrvTracer.o
  CC [M]  vboxdrv/SUPLibAll.o
  CC [M]  vboxdrv/common/string/strformatrt.o
  CC [M]  vboxdrv/combined-agnostic1.o
  CC [M]  vboxdrv/combined-agnostic2.o
  CC [M]  vboxdrv/combined-os-specific.o
vboxdrv/linux/SUPDrv-linux.c:213:19: error: ā€˜kvm_enable_virtualization’ undeclared here (not in a function); did you mean ā€˜kvm_arch_enable_virtualization’?
  213 | static __typeof__(kvm_enable_virtualization)   *g_pfnKvmEnableVirtualization;
  LD [M]  vboxnetadp/vboxnetadp.o
vboxdrv/linux/SUPDrv-linux.c:215:19: error: ā€˜kvm_disable_virtualization’ undeclared here (not in a function); did you mean ā€˜kvm_arch_disable_virtualization’?
  215 | static __typeof__(kvm_disable_virtualization)  *g_pfnKvmDisableVirtualization;
vboxdrv/linux/SUPDrv-linux.c: In function ā€˜supdrvOSEnableHwvirt’:
vboxdrv/linux/SUPDrv-linux.c:1962:24: error: called object ā€˜g_pfnKvmEnableVirtualization’ is not a function or function pointer
 1962 |         int const rc = g_pfnKvmEnableVirtualization();
vboxdrv/linux/SUPDrv-linux.c:213:49: note: declared here
vboxdrv/linux/SUPDrv-linux.c:1975:9: error: called object ā€˜g_pfnKvmDisableVirtualization’ is not a function or function pointer
 1975 |         g_pfnKvmDisableVirtualization();
vboxdrv/linux/SUPDrv-linux.c:215:49: note: declared here
make[4]: *** [/usr/lib/modules/7.1.1-3-MANJARO/build/scripts/Makefile.build:289: vboxdrv/linux/SUPDrv-linux.o] Error 1
make[4]: *** Waiting for unfinished jobs....
  LD [M]  vboxnetflt/vboxnetflt.o
make[3]: *** [/usr/lib/modules/7.1.1-3-MANJARO/build/scripts/Makefile.build:548: vboxdrv] Error 2
make[2]: *** [/usr/lib/modules/7.1.1-3-MANJARO/build/Makefile:2144: .] Error 2
make[1]: *** [/usr/lib/modules/7.1.1-3-MANJARO/build/Makefile:248: __sub-make] Error 2
make[1]: Leaving directory '/var/lib/dkms/vboxhost/7.2.8_OSE/build'
make: *** [Makefile:248: __sub-make] Error 2
make: Leaving directory '/usr/lib/modules/7.1.1-3-MANJARO/build'
# exit code: 2
# elapsed time: 00:00:03
And my inxi -zv8
  Kernel: 6.18.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=f0812a05-f95b-47a2-a7a3-d652d9b60591 rw
    resume=UUID=5052202f-aca8-4237-92d4-ae513ec48917 udev.log_priority=3
    sysrq_always_enabled=1 acpi_pstate=active kvm.enable_virt_at_load=0
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: A320M-HDV R4.0
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: P7.00 date: 11/15/2021
  System RAM: total: 32 GiB available: 31.27 GiB used: 4.21 GiB (13.5%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4DFRA32A.M16FE serial: <filter>
  Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2200 min/max: 2200/4208 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    bogomips: 86240
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Micro-Star MSI driver: amdgpu
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
    DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:67df
    class-ID: 0300 temp: 52.0 C
  Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-2 model: Dell U3818DW serial: <filter> built: 2020 res:
    mode: 3840x1600 hz: 60 scale: 100% (1) dpi: 111 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 880x367mm (34.65x14.45") diag: 953mm (37.5")
    modes: 3840x1600, 2560x1440, 1920x1600, 2560x1080, 1920x1080, 1600x1200,
    1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 90
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.2-arch1.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi polaris10
    ACO DRM 3.64 6.18.36-1-MANJARO) device-ID: 1002:67df memory: 3.91 GiB
    unified: no display-ID: :0.0
  API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 26.1.2-arch1.2
    device-ID: 1002:67df surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top,lact
    wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.18.36-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: br-7791cf9f7135 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: nm-bridge state: down mac: <filter>
  IF-ID-4: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0aa7
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
    lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 2.95 TiB used: 997.17 GiB (33.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30D temp: 41.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0400 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A02 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10JMVW-11AJGS4 size: 931.48 GiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1014 scheme: GPT
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
    used: 414.17 GiB (45.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f0812a05-f95b-47a2-a7a3-d652d9b60591
    used: 32.2 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 0CA7-2825
  ID-3: /mnt/backup raw-size: 931.48 GiB size: 915.79 GiB (98.32%)
    used: 386.5 GiB (42.2%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: Backup 2 uuid: 81e8188b-2dd5-4765-bf21-423d90b654c5
  ID-4: /mnt/data raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
    used: 196.46 GiB (21.1%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
    label: Datanew uuid: 242621D92621AD2C
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 5052202f-aca8-4237-92d4-ae513ec48917
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 222.77 GiB fs: ntfs label: N/A
    uuid: 7682CA5282CA1711
  ID-3: /dev/sda3 maj-min: 8:3 size: 803 MiB fs: ntfs label: N/A
    uuid: DE3A55253A54FC49
  ID-4: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
  Device-1: 1-7:2 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Device-1: 3-2:2 info: HP PSC 1400 type: printer driver: usblp
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 2mA chip-ID: 03f0:4d11 class-ID: 0701 serial: <filter>
  Hub-4: 3-4:3 info: Texas Instruments ports: 6 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8442
  Device-1: 3-4.2:4 info: Logitech Logitech Mechanical keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 250mA
    chip-ID: 046d:c341 class-ID: 0300 serial: <filter>
  Device-2: 3-4.3:5 info: Keychron Link type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3434:d030 class-ID: 0300
  Device-3: 3-4.5:6 info: Texas Instruments type: HID
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:82ff
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Device-1: 4-1:2 info: Western Digital Elements 25A2 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:25a2 class-ID: 0806
    serial: <filter>
  Hub-6: 4-4:3 info: Texas Instruments ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0451:8440
  System Temperatures: cpu: 59.2 C mobo: N/A gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1168
  Packages: 1974 pm: pacman pkgs: 1957 libs: 486 tools: pamac,yay pm: rpm
    pkgs: 1 pm: flatpak pkgs: 16
    1: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    2: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    3: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    5: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    6: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    8: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    9: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    10: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    11: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    12: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    13: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    14: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 404
  1: cpu: 4.1% command: thunderbird pid: 1883 mem: 555.8 MiB (1.7%)
  2: cpu: 3.7% command: variety started-by: python pid: 1899
    mem: 142.6 MiB (0.4%)
  3: cpu: 3.1% command: brave pid: 2829 mem: 280.7 MiB (0.8%)
  4: cpu: 2.4% command: brave pid: 1863 mem: 496.7 MiB (1.5%)
  5: cpu: 2.2% command: kwin_wayland pid: 1335 mem: 398.0 MiB (1.2%)
  Memory top: 5 of 404
  1: mem: 555.8 MiB (1.7%) command: thunderbird pid: 1883 cpu: 4.1%
  2: mem: 496.7 MiB (1.5%) command: brave pid: 1863 cpu: 2.4%
  3: mem: 435.4 MiB (1.3%) command: plasmashell pid: 1566 cpu: 1.2%
  4: mem: 398.0 MiB (1.2%) command: kwin_wayland pid: 1335 cpu: 2.2%
  5: mem: 340.0 MiB (1.0%) command: brave pid: 2732 cpu: 2.2%
  Processes: 404 Power: uptime: 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 260 default: graphical tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: konsole inxi: 3.3.40
You forgot the linux71-headers package - dkms depends on it.
It appears you may be in an unsupported, partial upgrade state. The current version of virtualbox is 7.2.10.
EDIT: Hang on, I think there may be mismatched package versions in the latest testing update. Investigating…
@Yochanan , @ManjaroDevOps I will make sure to install the headers. I do that as a matter of course, but I’m not above screwing it up.
I’ll also reinstall virtualbox and the virtualbox DKMS package and see if that helps.
I was just about to say that pacman is determined to install 7.2.8. Ok, I’ll wait for an update.
The plot thickens (maybe). When I try to install virtualbox-host-dkms, 7.2.8 is what comes up there too.
Might need to update with sudo pacman -Syuu to allow downgrades:
dkms package won’t compile on 7.1 series unless you patch it: patched PKGBUILD
Thanks, @philm , the patch works.
