Hi:
I cannot use the win10 virtual machine in my newly installed manjaro system.The following is my environment and part of the log.
Package version:
[daijh@daijh-pc ~]$ pacman -Qs virtualbox
local/linux510 5.10.53-1
The Linux510 kernel and modules
local/linux512 5.12.19-1
The Linux512 kernel and modules
local/linux512-virtualbox-host-modules 6.1.24-1 (linux512-extramodules)
Host kernel modules for VirtualBox
local/linux513 5.13.5-1
The Linux513 kernel and modules
local/virtualbox 6.1.24-1
Powerful x86 virtualization for enterprise as well as home use
local/virtualbox-guest-iso 6.1.24-1
The official VirtualBox Guest Additions ISO image
local/virtualbox-guest-utils 6.1.24-1
VirtualBox Guest userspace utilities
This topic suggests an issue with your VM machine settings or a saved state.
NS_ERROR_FAILURE (0x80004005) is a general failure message when loading a VM. Subsequent lines in the error dialog will give the exact cause of the error. You do NOT have the same error just because you see the generic leader. If you don’t provide a log or the supplemental error description then we can’t help you.
